Post by dusty350 on Jul 14, 2020 7:05:41 GMT 1
Why not fit a button head hex bolt, going in from the swingarm side - that will reduce the height of the nut and overlong bolt you currently have ? Or space your main hanger off the frame a touch more ? Dusty
Post by russpuss on Jul 14, 2020 7:17:16 GMT 1
Why not fit a button head hex bolt, going in from the swingarm side - that will reduce the height of the nut and overlong bolt you currently have ? Or space your main hanger off the frame a touch more ? Dusty The main hanger is symmetrical to the other hanger, would mess with my OCD! 😂 I like the looks of the hex head on the outside, I’ll just make 3 spacers to ensure it misses. Will sort tonight, just keep taking pictures as I go and uploading so people can see things in real-time. It’s easy to just show things done as if no problems are hit.
Post by marrcel on Jul 14, 2020 8:01:15 GMT 1
The footrest isnt foldable for using the kickstart. I lost to many skin on my right leg. 😤 So i am curious how does your kickstart line up with the footrest?
Post by Tobyjugs on Jul 14, 2020 8:37:22 GMT 1
Hi Russ not sure how it would look, but I have a suggestion for your rear master cylinder alignment.
Mount a shim on the top fixing hole between master cylinder and fixing plate. This will cause the top of the cylinder to move towards the wheel and the bottom part to move away from the swing arm.
Post by russpuss on Jul 14, 2020 8:53:44 GMT 1
Hi Russ not sure how it would look, but I have a suggestion for your rear master cylinder alignment. Mount a shim on the top fixing hole between master cylinder and fixing plate. This will cause the top of the cylinder to move towards the wheel and the bottom part to move away from the swing arm. And have it c**k-eyed! Argh my OCD! 😂 I’ll sort this tonight when I get back in the cave with 3 spacers 👍🏻
Post by russpuss on Jul 14, 2020 8:54:29 GMT 1
The footrest isnt foldable for using the kickstart. I lost to many skin on my right leg. 😤 So i am curious how does your kickstart line up with the footrest? At the moment there’s lots of clearance but thinking of going down the DTR125 route with the kicker so watch this space.
Post by Tobyjugs on Jul 14, 2020 10:51:51 GMT 1
Hi Russ not sure how it would look, but I have a suggestion for your rear master cylinder alignment. Mount a shim on the top fixing hole between master cylinder and fixing plate. This will cause the top of the cylinder to move towards the wheel and the bottom part to move away from the swing arm. And have it c**k-eyed! Argh my OCD! 😂 I’ll sort this tonight when I get back in the cave with 3 spacers 👍🏻 Yeah if it's c**k-eyed it would be shocking
Post by russpuss on Jul 14, 2020 17:31:09 GMT 1
Sorted after 1/2 hour on the lathe Just need to shorten those 2 bolts
Post by russpuss on Jul 14, 2020 17:40:24 GMT 1
Grips came, nice and sky like
Post by russpuss on Jul 15, 2020 19:56:11 GMT 1
Measured and ordered the cables, trying this for hydraulic clutch. Ordered a bleed nipple bolt, currently pulls about 10mm, didn’t test with cable, any idea’s how much a cable pulls? There’s half a lever before it starts to move so hopefully when fully bled I’ll get more movement.
Post by russpuss on Jul 21, 2020 17:22:18 GMT 1
Post by russpuss on Jul 22, 2020 18:47:29 GMT 1
Post by russpuss on Jul 22, 2020 18:48:08 GMT 1
She starts, runs and stops, time to strip it down.
Post by russpuss on Jul 23, 2020 18:34:45 GMT 1
Prototype billet headlight bracket sorted, now it’s time to get it apart and get it built for real. Might be a while for an update. Can’t upload pics, gone over Tapatalk limit.
2taol
Post by 2taol on Jul 24, 2020 12:16:06 GMT 1
excellent, now the real fun begins !
didnt know there was a limit on images..
Post by russpuss on Aug 9, 2020 22:02:42 GMT 1
Quick update, current mood beer, everything at powder coaters, side stand off to have nipple for spring moved, £200 tyres ordered avon storm 3D. Discs, rear sprocket, clocks cases and headlight bucket gone for wet paint. Need to nip to Barnsley to get the ohlins juiced and gassed. Tidied man cave ready for it coming back. Bagged and tagged all the bits ready to throw back on. Off to platers tomorrow to get some stuff done in yellow passivate. Just need mutts to come up trumps with the side case as hopefully I’ll be ready for it in about 3 weeks then it can have the quick shifter fitted at the same time. And breath, hope the weather holds up for some runs out for people to gasp in horror at me ruining yet another classic!
Post by russpuss on Aug 10, 2020 10:02:23 GMT 1
Side stand ready to go to coaters now top work by Bri again
Post by russpuss on Aug 12, 2020 13:28:30 GMT 1
Next day turnaround on the yellow passivate, pleased with the outcome as they were tatty to start with
Post by russpuss on Aug 19, 2020 19:50:33 GMT 1
Mick Gardner Racing at Barnsley, dropped these off Friday and picked up today, had him check my work and juice them up and fill with nitrogen. £120 all in. So they stand me at around £320 finished. Can’t argue with that as they’re about £1300 to buy.
Post by flames on Aug 19, 2020 20:07:53 GMT 1
Lush and a bargain to boot. What more could you want?.
Post by russpuss on Aug 25, 2020 13:44:02 GMT 1
Arm back from Metmachex swingarms. Bits cut off, holes welded up and polished. Can’t grumble.
Post by russpuss on Aug 25, 2020 16:49:51 GMT 1
Powdercoater just sent these, frame next he says. Should be done tomorrow
Post by Tobyjugs on Aug 25, 2020 17:23:19 GMT 1
Looks Nice. Who is the bike for Zippy or Bungo? I guess Zippy with that engine.
Post by russpuss on Aug 25, 2020 18:38:44 GMT 1
Looks Nice. Who is the bike for Zippy or Bungo? I guess Zippy with that engine. There’s me thinking it might look a bit boring when done?
Post by russpuss on Aug 26, 2020 8:45:51 GMT 1
Best get dressed and go pick some parts up
Post by flames on Aug 26, 2020 9:31:07 GMT 1
Nice...... which wheels going in? Looks like ones yellow and the other style is gold? Or are you going multi coloured with this bike for a change? 😁
Post by russpuss on Aug 26, 2020 13:06:01 GMT 1
Nice...... which wheels going in? Looks like ones yellow and the other style is gold? Or are you going multi coloured with this bike for a change? 😁 The gold was another customers
Post by russpuss on Aug 26, 2020 13:06:38 GMT 1
New boots are on
Post by flames on Aug 26, 2020 13:08:48 GMT 1
Can't wait for bodywork......I love your colour schemes.😁
Post by russpuss on Aug 26, 2020 14:09:27 GMT 1
New bearings and seals fitted
