2taol
Post by 2taol on Sept 2, 2020 7:12:51 GMT 1
a nice splash of green, i loke the disc edges in green also
Post by russpuss on Sept 2, 2020 15:12:37 GMT 1
Took all morning to bleed the bloody brake, shit in the holes in the master cylinder from blasting and coating but now it’s sorted.
Post by russpuss on Sept 2, 2020 15:57:10 GMT 1
Graham sorted me again
Post by russpuss on Sept 2, 2020 16:38:49 GMT 1
Post by russpuss on Sept 2, 2020 18:12:00 GMT 1
Waiting for the 10mm fine bolts in stainless to come for the brakes to attach but you get the drift
Post by flames on Sept 2, 2020 18:21:17 GMT 1
Ooooo....... another bit of wee came out.....this soooo exciting.
Post by Tobyjugs on Sept 2, 2020 20:28:43 GMT 1
Russ that bike is trippin, and happy birthday fella
2taol
Post by 2taol on Sept 2, 2020 20:33:44 GMT 1
well cool
Post by russpuss on Sept 2, 2020 20:33:46 GMT 1
Russ that bike is trippin, and happy birthday fella Thanks, all that LSD I had in the 90’s gives me flashbacks
Post by russpuss on Sept 2, 2020 20:36:58 GMT 1
There’s probably a day or two left to finish this when the parts come back. Stumbling point will be the seat as waiting for the nod from the upholstery to take it for its cover. Should be done next Friday all being well apart from that, fingers crossed
Post by flames on Sept 2, 2020 21:55:33 GMT 1
Beautiful.
Post by flames on Sept 2, 2020 21:56:58 GMT 1
All that polishness looks awesome against the paintwork on frame
Post by russpuss on Sept 5, 2020 20:12:15 GMT 1
Post by flames on Sept 5, 2020 20:27:32 GMT 1
That is luuuuurrrrvvvveeeelllllyyyyy.
Post by veg on Sept 5, 2020 21:30:18 GMT 1
Russ I don’t know what you’re smoking, drinking or necking but one thing we can always agree on is you sure as shit don’t do subtle ( ignore the x7). I love your builds completely unique and never a dull moment 👍
Post by russpuss on Sept 5, 2020 21:34:31 GMT 1
Russ I don’t know what you’re smoking, drinking or necking but one thing we can always agree on is you sure as shit don’t do subtle ( ignore the x7). I love your builds completely unique and never a dull moment 👍 I just have to have a conversation starter, I love it as people just have to stop whether they like it or not. Why build the norm that everyone already has?
Post by loctite on Sept 5, 2020 22:15:34 GMT 1
Great bike looks sweet
Post by 4l04ever on Sept 6, 2020 9:30:31 GMT 1
Looking sweet! Only thing I would check is if the rad grill will cause any restriction in flow through the radiator.
If you run a digital temperature gauge, you can see where you are once you are up and running and can try with and without the grill for comparison.
Keep up the great work! :-)
Post by russpuss on Sept 6, 2020 9:31:45 GMT 1
Looking sweet! Only thing I would check is if the rad grill will cause any restriction in flow through the radiator. If you run a digital temperature gauge, you can see where you are once you are up and running and can try with and without the grill for comparison. Keep up the great work! :-) It’s a super large rad, fingers crossed it’s ok
Post by russpuss on Sept 6, 2020 10:36:52 GMT 1
1 missing piece collected this morning
Post by russpuss on Sept 6, 2020 17:25:59 GMT 1
That’s a job done just needs polishing now
Post by russpuss on Sept 6, 2020 17:26:13 GMT 1
2taol
Post by 2taol on Sept 6, 2020 18:31:58 GMT 1
looking class, love the rear setup, very different.
love thos clear clutch covers, something i would like to do at some stage.
Post by flames on Sept 6, 2020 18:38:29 GMT 1
The back end is always the best view, its all most people see.😁
Post by loctite on Sept 6, 2020 19:13:26 GMT 1
That’s a job done just needs polishing now hi russ is this your work,looks good.
Post by russpuss on Sept 6, 2020 19:15:12 GMT 1
That’s a job done just needs polishing now hi russ is this your work,looks good. If only! Metmachex swingarms chris there did it me
Post by russpuss on Sept 9, 2020 16:13:06 GMT 1
Stainless spacer for the dtr kicker
Post by russpuss on Sept 10, 2020 20:05:43 GMT 1
So I had a go on the polishing mop to match the machined outer case to the other bits, it’s a dirty job I’m black. But it’s a satisfying job when it looks nice.
Post by flames on Sept 10, 2020 20:38:44 GMT 1
Very impressive. Shiny and colourful. Perfect mix
2taol
Post by 2taol on Sept 11, 2020 22:28:53 GMT 1
nice polishing result, actually those parts look fantastic.
well worth the mess
