Post by graeme6 on Mar 21, 2018 22:57:11 GMT 1
Considering changing the cylinder head studs out for stainless allen bolts, is this feasible or do they need to be high tensile. M8x50mm fit exactly if anyone interested.
Post by jollyr6 on Mar 21, 2018 23:29:54 GMT 1
Allen screws/bolts are usually 10.9 grade which is higher but a tw💩T to drill if anything goes wrong imo
Post by jon on Mar 24, 2018 12:03:32 GMT 1
Considering changing the cylinder head studs out for stainless allen bolts, is this feasible or do they need to be high tensile. M8x50mm fit exactly if anyone interested. I wouldn’t if I were you. Stainless has more ductility and so is more likely to stretch and make the head come loose. Also repeatedly screwing in and out of the aluminium case threads will more likely strip them than a fixed stud. Jon
Post by graeme6 on Mar 24, 2018 15:15:35 GMT 1
Studs in then me thinks, will domed stainless nuts be ok, do you think.
Post by jon on Mar 25, 2018 10:20:20 GMT 1
You’d be better with chromed steel nuts.
I’d be less worried about stainless nuts than studs though.
If you do use stainless keep an eye on the torque setting. If you keep having to nip them up you’ll have your answer.
Possibly less strain on a smaller motor, so should get away with it more.
