Post by philmill on Mar 17, 2018 20:26:14 GMT 1
So due to the rarity and price of the RGV (VJ22) Rear calliper what are you guys using, I've seen a few Brembos but is there anything else that fits? I did think about VJ21 but don't fancy the Torque arm ruining the line. For the Brembo option, is thereon that fits the VJ22 caliper fitting?
Cheers, Phil
Post by LC_BOTT on Mar 17, 2018 21:11:47 GMT 1
KR1 is also the same I believe, A few have also used a Brembo caliper and a Tyga carrier.
Post by dusty350 on Mar 17, 2018 21:30:07 GMT 1
I fitted the Brembo caliper and Tyga carrier; 20170810_144200 by David Miller, on Flickr It's a trick little set up but caliper and carrier costs about Ā£200 !! Are Vj22 calipers expensive ? Got one sat in my shed doing nothing. Dusty
Post by midlifecrisisrd on Mar 17, 2018 21:48:42 GMT 1
I fitted the Brembo caliper and Tyga carrier; 20170810_144200 by David Miller, on Flickr It's a trick little set up but caliper and carrier costs about Ā£200 !! Are Vj22 calipers expensive ? Got one sat in my shed doing nothing. Dusty Vj22 calipers and brackets are a small fortune now I had to pay Ā£150 for a rebuilt set up Steve
Post by dusty350 on Mar 17, 2018 21:57:57 GMT 1
Bloody hell, didn't realise I removed mine to fit the Brembo set up. Dusty
Post by midlifecrisisrd on Mar 17, 2018 23:10:47 GMT 1
Bloody hell, didn't realise I removed mine to fit the Brembo set up. Dusty I know š I'm thinking about removing mine and making a bracket to fit an r1 blue spot I'll be getting my bracket copied a few times though š (gsxr400 wheel in the arm) Steve
Post by JonW on Mar 18, 2018 1:08:03 GMT 1
Wow, I must go thru my RGV stash if they now sell for that money, eeek. I will say that the OEM RGV side by side twin piston unit is a nice unit, but wow...
Post by philmill on Mar 18, 2018 8:32:02 GMT 1
Thanks for the replies, there is an NOS caliper on eBay at the moment but I can see the prices just going crazy! So Iām looking for a sensible priced one if anybody wants to sell š
Post by philmill on Mar 18, 2018 8:49:36 GMT 1
I'm happy to take a calliper that needs rebuilding, I'll want to paint it anyway. I will check out the KR1 options.
Phli
Post by LC_BOTT on Mar 18, 2018 9:06:40 GMT 1
Post by dusty350 on Mar 18, 2018 10:59:23 GMT 1
I'll dig my caliper out of the shed if you like. I don't need it now as I fitted the Brembo. I've got the carrier as well - it was modded to fit the Met swingarm but still fits an Rgv arm as standard, if you are interested. Dusty
Post by dusty350 on Mar 18, 2018 12:30:29 GMT 1
Just measured my Tyga carrier and the mounting hole centres are approx. 85mm, so the GB Moto caliper wont fit unfortunately.
Dusty
Post by dllc on Mar 18, 2018 12:32:23 GMT 1
Kr1 Kr1s, Gpx 250 all the same caliper as rgv
Post by philmill on Mar 18, 2018 12:33:20 GMT 1
Cheers, Dusty, I have carrier or at least the bit that that wheel spindle goes through! mind you, I'm using a GSXR 400 wheel so that won't work! Yes, let me know.
Phil
Post by JonW on Mar 19, 2018 0:17:32 GMT 1
Kr1 Kr1s, Gpx 250 all the same caliper as rgv Yes and some of the fronts used by those bikes work ok too, its all about nipple orientation... but then, when wasn't it? lol FWIW Kawa seals are much cheaper than Suzy...
Post by philmill on Mar 20, 2018 8:03:20 GMT 1
Thanks Jon, good info on the parts prices.
phil
