Post by panzermatt on Nov 25, 2018 20:07:35 GMT 1
so far so good lads. next saturday i hope to start it. so then we shall know.............
Post by panzermatt on Nov 27, 2018 19:55:02 GMT 1
Fit the chain and front sprocket
Post by panzermatt on Nov 27, 2018 19:56:09 GMT 1
Spanky, fancy new bolts on’t chain guard
Post by panzermatt on Nov 27, 2018 19:58:08 GMT 1
Running out of things to do now!
Post by dllc on Nov 27, 2018 20:02:21 GMT 1
You could polish that gear selector😂😂
Post by panzermatt on Nov 27, 2018 20:14:44 GMT 1
You could polish that gear selector😂😂 keeping it real!
Post by ypvs400 on Nov 27, 2018 20:31:33 GMT 1
You could polish that gear selector😂😂 Better not post pics of my LC2 rustoration 😀
Post by panzermatt on Dec 1, 2018 15:16:37 GMT 1
Lads, is it my imagination, or are these things shit? The exhaust wobbles around like mad when fitted. What is one to do? I was thinking about fitting one of the felt gaskets too. On top of that
Post by midlifecrisisrd on Dec 1, 2018 15:22:57 GMT 1
If it's standard pipes and they wobble when tightened then chances are the rings that go between the flanges and the back of the header pipe
You can use a wire coat hanger to make a ring to fill the groove in the flange
Post by panzermatt on Dec 1, 2018 15:35:21 GMT 1
So put a ring of coat hanger in this groove?
Post by midlifecrisisrd on Dec 1, 2018 15:49:38 GMT 1
So put a ring of coat hanger in this groove? Yep, you got it Steve
Post by panzermatt on Dec 1, 2018 15:56:13 GMT 1
thanks man. doohan on here rang me and said the same thing
Post by panzermatt on Dec 1, 2018 16:39:03 GMT 1
Left hand side tight as can be lovely, but right won’t play ball, have to get a thicker hanger. But this trick works a treat
Post by doohanno1 on Dec 1, 2018 16:42:49 GMT 1
Use two pieces of wire.!!
Post by panzermatt on Dec 1, 2018 16:55:33 GMT 1
i'm doing that as we speak!
Post by panzermatt on Dec 1, 2018 17:12:11 GMT 1
Engine fluids in.
Post by panzermatt on Dec 1, 2018 17:13:02 GMT 1
Only the best oil, coolant and 2 stroke
Post by panzermatt on Dec 1, 2018 17:15:06 GMT 1
Slight weep from this, heated washer up red hot, quenched, put back on, perfect. No coolant or oil leaks anywhere. Spent an hour with a torch and feeling everything to be sure
Post by panzermatt on Dec 1, 2018 17:15:24 GMT 1
Post by panzermatt on Dec 1, 2018 17:15:58 GMT 1
Spotless. And lovely and tight.
Post by panzermatt on Dec 1, 2018 17:17:36 GMT 1
Final piece of the ypvs puzzle. When this returns from arrow, I’m in business. Now we’re sucking diesel boys!
Post by oldbritguy on Dec 1, 2018 17:28:30 GMT 1
Suspense is killin' me here!!! Brilliant stuff.
Post by panzermatt on Dec 2, 2018 14:09:56 GMT 1
Put all the body work on it, I didn’t get her resprayed for 2 reasons 1 money and 2 it was grand 😊
Post by panzermatt on Dec 2, 2018 14:10:18 GMT 1
Post by panzermatt on Dec 2, 2018 14:10:41 GMT 1
Post by panzermatt on Dec 2, 2018 14:10:58 GMT 1
Post by panzermatt on Dec 2, 2018 14:11:20 GMT 1
Post by panzermatt on Dec 2, 2018 14:11:48 GMT 1
Post by panzermatt on Dec 2, 2018 14:14:52 GMT 1
Has anyone spare decals for the belly pan? I don’t want to buy a whole set for just those
31k 1983.
Dec 2, 2018 14:23:44 GMT 1
via mobile
Post by midlifecrisisrd on Dec 2, 2018 14:23:44 GMT 1
Has anyone spare decals for the belly pan? I don’t want to buy a whole set for just those The image works will do individual decals Steve
