Post by panzermatt on Nov 17, 2018 19:36:04 GMT 1
I thought your other half told you to stop useing her mug for the tea.. brilliant isnt it!
Post by panzermatt on Nov 17, 2018 19:40:49 GMT 1
Before
Post by panzermatt on Nov 17, 2018 19:41:23 GMT 1
Post by andy748 on Nov 17, 2018 20:16:08 GMT 1
Lovely job nice progress. Andy.
Post by panzermatt on Nov 22, 2018 21:39:02 GMT 1
Post by panzermatt on Nov 22, 2018 21:39:43 GMT 1
Put engine in’t frame. Aye lad
Post by panzermatt on Nov 22, 2018 22:47:09 GMT 1
Does anyone have a solution for the clutch cable? So it doesn’t break the key surround on the lc2 ?
31k 1983.
Nov 22, 2018 23:41:17 GMT 1
via mobile
Post by ypvs400 on Nov 22, 2018 23:41:17 GMT 1
Does anyone have a solution for the clutch cable? So it doesn’t break the key surround on the lc2 ? I didn't realise the cable caused the damage, I will have a look at my original LC2 tomorrow.
Post by panzermatt on Nov 23, 2018 0:32:37 GMT 1
Thanks man
Post by doohanno1 on Nov 23, 2018 1:35:56 GMT 1
Does anyone have a solution for the clutch cable? So it doesn’t break the key surround on the lc2 ? A strategically placed cable tie perhaps.!
Post by midlifecrisisrd on Nov 23, 2018 9:16:06 GMT 1
Does anyone have a solution for the clutch cable? So it doesn’t break the key surround on the lc2 ? Its not the cable that breaks the surround. It's when it's crashed the clocks flex back on the rubber mounts and it hits the ignition switch The wear mark it leaves on the case below the Speedo is another thing though ☹ Steve
Post by panzermatt on Nov 23, 2018 10:40:11 GMT 1
Does anyone have a solution for the clutch cable? So it doesn’t break the key surround on the lc2 ? Its not the cable that breaks the surround. It's when it's crashed the clocks flex back on the rubber mounts and it hits the ignition switch The wear mark it leaves on the case below the Speedo is another thing though ☹ Steve So I’m cool to route the cable as normal
Post by midlifecrisisrd on Nov 23, 2018 11:19:07 GMT 1
Its not the cable that breaks the surround. It's when it's crashed the clocks flex back on the rubber mounts and it hits the ignition switch The wear mark it leaves on the case below the Speedo is another thing though ☹ Steve So I’m cool to route the cable as normal Yes From perch down through the cut out on left of ignition shroud then down right side of headstock Steve
Post by ypvs400 on Nov 23, 2018 12:44:43 GMT 1
So I’m cool to route the cable as normal Yes From perch down through the cut out on left of ignition shroud then down right side of headstock Steve I have just checked mine and yes it goes under the instrument section that normally breaks off and in front of the ignition barrel.
Post by panzermatt on Nov 25, 2018 16:19:36 GMT 1
so i fitted new power valve cables, and set the powervalve sby looking up the exhaust port, and not the roundy thing on the pulley, that seems off by a mill or so. anyway im happier lookimg up the exhaust, that way i know the valves open fully. ahhhhh that servo sound......
Post by panzermatt on Nov 25, 2018 18:44:54 GMT 1
Progress
Post by panzermatt on Nov 25, 2018 18:45:44 GMT 1
New air box seal
Post by panzermatt on Nov 25, 2018 18:46:41 GMT 1
Fit carbs with the help of my buddy Phil (doohan) on here
Post by panzermatt on Nov 25, 2018 18:47:45 GMT 1
All controls work fine, throttle cable returns nicely. Oiled it up loads
Post by panzermatt on Nov 25, 2018 18:48:19 GMT 1
Quality
Post by panzermatt on Nov 25, 2018 18:49:23 GMT 1
New power valve cables. At rest they are fully open. I hope this is right
Post by panzermatt on Nov 25, 2018 18:51:38 GMT 1
Rad on. And all pipes, put a tiny bit of that red rubber grease on pipes to help fit them.
Post by panzermatt on Nov 25, 2018 18:52:09 GMT 1
Polished it
Post by panzermatt on Nov 25, 2018 19:04:08 GMT 1
oh, when phil came around yesyerday, i was boasting about how i fit the engine without scratching the frame and even showed him the engine spacers that i hadnt fitted! DOH! engine back out spacers in, and then i thought i was off the hook, until luckily i dropped a washer into the engine somewhere, its gone, never found it. but while rooting around the top of the gearbox with a torch i discovered the water pipe clamp from clutch side to head was loose!!! so i spent an hour searching for other stuff i forgot to tighten. that was the only one.....i hope!
Post by andrel on Nov 25, 2018 19:27:19 GMT 1
You are motoring along with your build Matt. Wont be long now and you will be able to ride it. Just remember to check all the bolts - dont want wheels or brakes to come loose whilst hanging on the cable
Post by andrel on Nov 25, 2018 19:34:20 GMT 1
Fitting these tonight These looks pristine compared to mine. Just checked on Yambits now......89 pounds a valve with 21 pounds for the centre joint. I am in for the high jump that's for sure.
Post by panzermatt on Nov 25, 2018 19:34:58 GMT 1
You are motoring along with your build Matt. Wont be long now and you will be able to ride it. Just remember to check all the bolts - dont want wheels or brakes to come loose whilst hanging on the cable ARROW has rebuilt the oil pump, so if that arrives during t'week, i shall be starting her saturday! and! her good self has agreed to let me keep it in the kitchen over the winter.
Post by panzermatt on Nov 25, 2018 19:39:02 GMT 1
I honestly couldn't believe the condition of the engine when i pulled it apart, bar 1 siezed stud, evrything came apart easy, and the condition of parts was amazing! standard pistons and bore, still perfect, crank, perfect, powevalves perfect. god bless them Germans, old man Horst looked after her.
Post by andrel on Nov 25, 2018 19:54:06 GMT 1
I honestly couldn't believe the condition of the engine when i pulled it apart, bar 1 siezed stud, evrything came apart easy, and the condition of parts was amazing! standard pistons and bore, still perfect, crank, perfect, powevalves perfect. god bless them Germans, old man Horst looked after her. Yes, your bike looked rough from the outside, but was very good on the inside - mine seems to be the polar opposite. Shows you the value of a well-maintained bike.
Post by yamark on Nov 25, 2018 19:56:14 GMT 1
Really enjoying this build, great work
It sounds like you've had a right result with the engine
