Post by mak595 on Jul 5, 2020 17:44:49 GMT 1
quick question lads, my bike is spitting oil from somewhere, i thought it was powervalve seals, but i have recently replaced these, i have on close inspection found the left exhaust to be loose. would this explain my oil splatters? Yep, you might have to use the old coat hanger trick to get a good seal
Post by panzermatt on Feb 5, 2022 13:29:22 GMT 1
Help! Lads in simple terms what do I have to do here?
Post by panzermatt on Feb 5, 2022 13:30:27 GMT 1
Just connect old connectors? And bobs your uncle?
Post by panzermatt on Feb 5, 2022 13:30:52 GMT 1
Post by panzermatt on Feb 5, 2022 13:31:13 GMT 1
Post by oldbritguy on Feb 5, 2022 18:09:41 GMT 1
I dont think the plugs are the same
I have a similar situation with the bike I am building just now and have a zeel for the big motor
Wiring diagrams are available from Zeel if you are up for a bit of wiring. Just get some compatible plugs to keep it tidy
Post by jessy03 on Feb 5, 2022 19:55:34 GMT 1
If your old one is buggered then just cut the plugs off and use them, dead easy to wire up. If your stuck let me know done loads of them👍
Post by jessy03 on Feb 5, 2022 19:57:18 GMT 1
Right wiring diagram
Post by panzermatt on Feb 6, 2022 10:49:01 GMT 1
so, i use all three plugs, and just put the wires back in the same order. that doesnt sound too hard. any trick to putting the wires into the connectors?
Post by jessy03 on Feb 6, 2022 11:29:46 GMT 1
You will need to cut the connectors off the old cdi and solder them to the new one, fix the Zeeltronic in place and cut the wires to the correct length - they look a little long.
Post by 4l04ever on Feb 6, 2022 11:31:08 GMT 1
Is the old CDI scrap? If so, you can cut the cable off and join the wires to the wires from the Zeel, so you don't have to take the connectors apart.
Post by panzermatt on Feb 6, 2022 12:11:00 GMT 1
i could do that, that would be easier. the old cdi is banjaxed.
Post by panzermatt on Feb 6, 2022 14:08:08 GMT 1
what are resistor spark plugs? and i presume the spare wires are for stuff i dont need.
Post by midlifecrisisrd on Feb 6, 2022 14:21:05 GMT 1
Br8es are resister
B8es are not resister
Just means there is an inline resister. Power valves need them
Post by midlifecrisisrd on Feb 6, 2022 14:23:16 GMT 1
Yes there will be spare wires
Quick shifter input, shift light, 1 pulse per rpm tacho feed are the usual suspects
Take the 12v feed from the pv controller brown wire
Post by panzermatt on Feb 6, 2022 18:00:36 GMT 1
I did something right, she started! thanks lads.
Post by shaunthe2nd on Feb 8, 2022 22:27:18 GMT 1
Fantastic. Happy days.
Post by panzermatt on Mar 18, 2022 21:42:39 GMT 1
took bike out today for a proper spin, and by jaysus them zeel things are brilliant! bike runs beautiful now. defo an increase in power too. thanks Buck 1963!
