Post by donkeychomp on Apr 21, 2018 21:38:52 GMT 1
That wheel is lush.
Post by philmill on Apr 21, 2018 21:50:47 GMT 1
Thanks Alex.
Post by philmill on May 1, 2018 15:20:43 GMT 1
So I now have a disc fitted, can't find a 84mm centre but with a bit of modification I sorted it. So the first problem, you can see the hub! looks f-ugly! kh4URHgZSNyvwXhtxHBf9Q by Philip Millard, on Flickr Need to make a thin blank to hide it I think. Next problem seems to be alignment, Have I got something wrong? its miles out, no way to line up the calliper and pads, anybody got a pic of their set up they could show me please, I'm sure I must have something out of place. hhHlZzavT9eu1MlqcNndlA by Philip Millard, on Flickr 9K9diCpcTD6D%yU7e1SRnw by Philip Millard, on Flickr
Post by midlifecrisisrd on May 1, 2018 16:29:15 GMT 1
The problem with the disc spacing is the gsxr disc sits 5mm further out so you either need to mod the existing bracket (not sure if it can be) or custom made bracket which was the route I took
I bought a plate of 10mm alloy then used the rgv bracket to mark up the spindle and bolt hole centres and drew round it before getting it cut out and spacers made to centre it.
If I ever get round to it I keep meaning to take it off and get some made up
Post by philmill on May 1, 2018 17:17:38 GMT 1
That makes sense Steve, I wonder if I can just machine down the alloy RGV unit, I have two... I'll have a look at the options.
Phil
Post by philmill on May 1, 2018 17:34:44 GMT 1
I just had another look at this, I assume its 5mm I'm looking for? on that basis I can machine out the slot for the swinging arm so its open, then mill 5mm off the part where the spindle goes through and make a 5mm longer spacer, Any reason that won't work Steve?? I can just modify the mounting plate I got from you!
Phil
Post by midlifecrisisrd on May 2, 2018 11:43:25 GMT 1
I worried the carrier would be too weak if you milled the slot open
Don't know if a plate can be welded on to reinforce it
Post by philmill on May 2, 2018 14:14:08 GMT 1
Thanks Steve. I'll have a look at the options.
Post by philmill on Jan 26, 2019 16:24:03 GMT 1
Post by philmill on Jan 26, 2019 16:25:33 GMT 1
Can anybody confirm the thread pitch of the rear wheel not, is it 1.5?? its M20 according to my vernier.
Thanks. Phil
Post by Mr Kipling on Jan 26, 2019 17:55:23 GMT 1
Agree with Alex those wheels are Lush.....
Post by tipfinchy on Jan 27, 2019 14:38:58 GMT 1
looking very nice Phil , how did you get over the rear disc/caliper bothers in the end mart
Post by 1966baz on Jan 27, 2019 18:37:34 GMT 1
Very neat job there, looking good.
Post by philmill on Jan 27, 2019 18:51:10 GMT 1
looking very nice Phil , how did you get over the rear disc/caliper bothers in the end mart I'm using a GSXR400 rear wheel, hence the issue, luckily its been done before so was able to get the correct measurements, (thanks Steve) it needed 5mm to come off the calliper mount and a different spacer, came out perfect in the end.
Post by philmill on Jan 29, 2019 19:12:51 GMT 1
Post by dusty350 on Jan 29, 2019 19:47:38 GMT 1
Looking really good Phil Love those fasteners Dusty
Post by Mr Kipling on Jan 29, 2019 20:16:44 GMT 1
me too....
Post by philmill on Jan 29, 2019 20:22:10 GMT 1
Thanks guys, I like them too, just a bit different. I really must change the screws on the servo controller
Post by marrcel on Jan 29, 2019 20:43:13 GMT 1
Here is the point were i think it is over the top. These fasteners are under the tank. No body will ever notice these fasteners. I think this is the point were a poor mans jobs end. On the other hand i admire your drive to perfection. 😬
Post by philmill on Jan 29, 2019 22:21:26 GMT 1
Each to their own choice, I would never put old screws in somewhere just because they can't been seen! Personal pride in the job I guess.
Phil
Post by Tobyjugs on Jan 29, 2019 23:51:57 GMT 1
I think we all go over the top in our own ways.
Post by mouse on Jan 30, 2019 21:20:23 GMT 1
I quite agree Phil, on using old screws, even if they cannot be seen!
Bike is really coming along now and looking really great, love the rear caliper
Mouse
Post by gazsellars on Feb 12, 2019 16:11:07 GMT 1
Looks really nice Phil well done.
Gaz
Post by oldbritguy on Feb 13, 2019 0:48:37 GMT 1
Looking lovely mate.
Hope mine turns out even half as nice as this
Post by philmill on Feb 15, 2019 21:01:54 GMT 1
Well a bit more progress, I got the new valve bits from Norbo, decided to replace it all, forgot to order the valves connector though, so waiting on that now.
Is there a trick to getting the castle seal in on the L/H side, I'm worried about damaging the seal inner face when forcing it in.
Phil
Post by philmill on Feb 15, 2019 21:03:11 GMT 1
Post by panzermatt on Feb 15, 2019 21:32:32 GMT 1
That looks great, i hope you used copious amounts of the fancy molybendiumiuim grease. Mutts sent me some.
Post by philmill on Feb 15, 2019 21:39:25 GMT 1
Fancy grease...... No! just lots of two stroke oil as I built the valves, they are super smooth and free. So does the grease last?
Phil
Post by panzermatt on Feb 15, 2019 21:46:36 GMT 1
On advice from muttz (praise be upon him) he told me to lather them in't fancy grease, have you torqued the barrels down yet? if not whip em off and get some of t'fancy grease, muttz will tell you which stuff, its pretty important i think
Post by philmill on Feb 15, 2019 21:49:11 GMT 1
Thanks, I'll talk to Mutts, he arranged the porting work etc so he'll be the man to talk to. No heads not on yet and barrels only loosely bolted down.
