Post by mellow on Feb 19, 2018 17:19:31 GMT 1
Bit of a long shot........................anyone got a fork cap/adjuster assembly laying around unwanted for a '99 4xv R1. Managed to bollox mine up. Took it all apart but the rebound clicker just wont click. Have refitted the ball bearing and spring but it just wont play ball
Post by 1966baz on Feb 24, 2018 9:07:50 GMT 1
They are £240 new from Fowlers, ouch. If one fork turns up on ebay complete it would be a lot cheaper not ideal though.
Long Shot
Feb 25, 2018 15:08:54 GMT 1
via mobile
Post by mellow on Feb 25, 2018 15:08:54 GMT 1
Yeah I saw how much they are new. Hence the ask lol. Surprised still available as quite a lot of parts NLA 😐DON'T know why, can still get parts for a 30 yr old rd🤔 Bought a pair of bent forks for the adjuster caps. Apparently one leg was "slightly bent and could b straightened". Bit more than slightly...outer tube WOULDN'T even slide down it. Plus both outer tubes had creases where bottom yoke would be. Luckily only wanted the caps really, they did work but had "use full preload" ENGRAVED" Into them😑 took mine apart after seeing how they work from the working ones & fixed mine. Will polish the engraving out & keep as spares. There is some shit about with poor descriptions🤔
Post by 1966baz on Feb 27, 2018 8:57:38 GMT 1
Yeah I saw how much they are new. Hence the ask lol. Surprised still available as quite a lot of parts NLA 😐DON'T know why, can still get parts for a 30 yr old rd🤔 Bought a pair of bent forks for the adjuster caps. Apparently one leg was "slightly bent and could b straightened". Bit more than slightly...outer tube WOULDN'T even slide down it. Plus both outer tubes had creases where bottom yoke would be. Luckily only wanted the caps really, they did work but had "use full preload" ENGRAVED" Into them😑 took mine apart after seeing how they work from the working ones & fixed mine. Will polish the engraving out & keep as spares. There is some shit about with poor descriptions🤔 Yeah there certainly is.Good you're sorted now.
