Post by jon on May 14, 2018 18:24:33 GMT 1
Good choice on doing the calipers now IMO.
Sure as suggested you take take things off and clean them up perfect at a later date, but draining brake fluid and then having to re-bleed on re-assembly makes it worth doing now.
Have you used a torque wrench on the caliper bolt halves. I only ask as I’d strongly advise checking it periodically when using stainless cap heads. Were they A4 or A2 stainless? The ductility of stainless is less than steel. A4 is near normal 8.8 bolts, while A2 lower. I’m sure the originals are high strength 10.9. What that means in layman’s terms is they are more likely to stretch and make the caliper halves loosen. I’m sure you can guess the rest.
I’m quite interested myself as I’m using A4 in mine, but will be keeping a close eye as to whether to replace them with original or titanium.
Post by 17again on May 15, 2018 10:23:05 GMT 1
thanks guys, cant wait to get the tank and panels on soon.
dont know what spec there are.
they came from race bolt
S/Steel Flanged Hex Head Bolt M10 x 1.25mm pitch x 45mm long Flanged Hex Headed bolts are ideal for clamping softer materials such as aluminium or plastic as the larger diameter of the flange spreads the load causing less “imprinting” on the clamped component.
Part of Racebolt`s standard stainless range. Precision machined with rolled threads making them ideal for road or race. Durable, yet highly corrosion resistant making them ideal for exposed usage on chassis, engine or brake components etc.
Material: Stainless steel SKU: RB-SSHX1045F Brand:
Post by 17again on May 22, 2018 17:11:09 GMT 1
Post by donkeychomp on May 22, 2018 21:11:52 GMT 1
Kick ass. So want one.
Post by kosaprasa on Dec 28, 2020 23:51:26 GMT 1
just for info, now i am new owner of this bike
Post by russie on Dec 29, 2020 23:00:15 GMT 1
Looking good, really like the 3-spoke wheels. Was planning having a go at zinc plating. Did you eventually get success with it?
Post by 17again on Mar 24, 2024 9:52:04 GMT 1
Looking good, really like the 3-spoke wheels. Was planning having a go at zinc plating. Did you eventually get success with it? Sorry only just saw this no it’s not worth doing the plating the results are so much better by using a metal company. if it kept the bike I would have them all re plated
Post by 17again on Mar 24, 2024 9:53:23 GMT 1
just for info, now i am new owner of this bike What have you done with this bike so far? it would be nice to see what you have done with it. I know if I kept it I would do it again probably
Post by tippy on Mar 24, 2024 11:55:37 GMT 1
What wheels are they?
Post by tippy on Mar 24, 2024 12:53:19 GMT 1
Realised as soon as I asked!
