Bolts.
Feb 7, 2018 11:42:11 GMT 1
Post by simon998 on Feb 7, 2018 11:42:11 GMT 1
I've successfully misplaced 50% of the bolts from my mk1/2 125lc.
Would anyone have a list of the bolt sizes included in those full bike kits? Inoxbolt.co.uk do the whole bike for £160 but I live beside a fastener supplier and reckon it would be 1/4 that price from them.
I've checked all the parts websites online but none of them give the actual thread pitch/bolt size.
Cheers!
Bolts.
Feb 7, 2018 11:58:06 GMT 1
Post by simon998 on Feb 7, 2018 11:58:06 GMT 1
Post by graeme6 on Feb 7, 2018 20:28:38 GMT 1
Not a full list but this is what I've replaced so far
Description Yamaha part no. Drawing no. generic part no. Size Note Cost Taper Head bearing 324800 or 48y 25ym 25mm x 48mm x 13mm Kit SSY125 £12.00 Taper Head bearing 324807 or 48Y130YM1 30mm x48mm x12mm Kit SSY125 Front wheel spacer 90387-127E0 14 see diagram £10.08 Front wheel oil seal TC or R23 93106-20002 5 20-37-8 TC or R23 Front wheel bearings x 2 93306-30101 4 6301 37mm od / 12mm id x12 wide Rear wheel bearings 93306-30203 6302 42mm od / 15mm id x 13 Rear wheel bearings 93306-20213 6202 35mm od / 15mm id x 11 Rear wheel dust seal 93102-22014 22x42x7 Rear wheel spindle 1W1-25181-01-00 26 220x15 (M14x1.5) Rear wheel spindle castle nut 90171-14020-00 27 M14x1.5 £14.50 Rear wheel inner spacer 90560-15218-00 2 22mm od x 15mm id x 78mm £13.00 Swing arm dust seals 93109-18020 3 18-24-4 Swing arm spacer (long) 90387-121G8 5 18mm od x 12mm id x76 Swing arm spacer (short) 90387-121G9 6 18mm od x 12mm id x 47mm Swing arm bushes 90386-18028 14 See diagram Swing arm shim 401-22127-00 7 28mm od x 18mm id x 0.3mm Swing arm shaft 4Vo-22141-00 8 215mmx12mm Top yoke £15 Centre stand £20 Side stand spring 9050729009 2 136mm yambits Stainless bolts £42.50
Seat cover from Norbo £10 +£5 del. Brake spares £15 + £8 del Lock set £60.00 Faring, belly pan & brackets £135.00 10W Carb £60.00 Air filter element 10W-14451-00 19 £7.00 Grab rail washers 1T4-24796-00-00 16 £7.00 Decals £10.00 Paint £200.00 Oil tank grommet 90480-01141-00 9 £2.50 Side panel grommet 90480-13197-00 5 2 off £5.00 Side panel grommet dampers 90480-12053-00 6 4 off £5.00 Rear tank locating damper 3Y62418300 7 £3.50 Rear tank locating washer 11H2418600 8 £3.50 Clutch flanged half nut 9017912244 11 M12x1x8.8mm Clutch basket half nut 90170-12337 . seal output shaft 93102-20143-00 24 20X38X5 seal kickstart 93102-20309-00 12 20x30x5 tc seal gearshift shaft 93101-12060-00 1 12x21x4 tc seal LH crankshaft 93306-30421-00 15 25X40X8 tc seal RH crankcase 93103-28097-00 16 28X40X8 tc seal clutch arm 93104-14004-00 26 14X25X5 tc Shaft seal 25x12x10 crankshaft bearing RH 93306-30301-00 23 6304 C3 17x47x14 crankshaft bearing LH 93306-20529-00 13 6205 C4 25x52x15 Balance shaft bearing left 93306-30201 22 6302 Balance shaft bearing right 93306-30305 23 6303 Needle bearing right 93317-31529 22 genuine only Needle bearing left 93311-41530 9 genuine only Primary gear shaft r/h bearing 93306-30303 8 6303Z Balance shaft nut 90170 12337 mk 2 different to mk1 seal front forks 93110-33018-00 8 & 28 33 45 11 or 33 45 10 Bolts Rear mudguard mounting bolts 90119-06056-00 5 & 14 M6x20 (6 0ff) Handlebar location bolts 91311-06020-00 4 M6x20 (2 0ff) Handlebar clamp bolts 91311-08025-00 3 M8x25 (2 off) Air box lid front 92501-06025-00 22 M6x25 Air box lid rear 92501-06014-00 24 M6x15 (2 off) Air box front to back coupling nut 90179-06009-00 M5 nut Air intake rear mounting bolts 90119-06056-00 30 M6x15 (2 off) Battery box mounting bolt 90159-06059-00 8 M6x10 Battery box clamp bolt 4L0-21543-01-00 10 M5x15 Top shocker mount bolt 90109-10554-00 16 M12x70 12mm shaft 55mm & M10 15mm long Bottom shocker pin 90240-12091-00 19 12mmx61mm 2.8mm split pin Top yoke clamp bolt 91311-08040-00 8 M8x40 (2 off) Bottom yoke clamp bolts 95821-10035-00 17 M10x35 (2 off)* 1mm pitch Front spindle clamp bolt fork btm 97321-08060-00 41 M8x60 Headlight bracket pinch bolt 95023-06020-00 11 M6x20 Headlight bracket bolt 95023-06010-00 13 M6x10 Front caliper bolts 90105-10308-00 12 M10x45mm 1.25 pitch with collar Brake plate to torsion bar bolt 90109-08063-00 35 M8x25 hex head hole for split pin Chain puller bolts 90101-08775-00 32 M8x45 Rear brake arm bolt 90101-06291-00 19 M6x25 Rear subframe to frame 97316-08020-00 7 M8x20 (4off) Rear mudguard to subframe bolts 90119-06056-00 5 M6x16 (4off) Tool tray / rear light mounting bolts 97316-06020-00 16 M6x16 (4off) 90119-06056-00 as well Stator plate mounting bolts 92501-06075-00 10 M6x75 (2 off) Oil pump mounting bolt 90201-08624-00 16 M5x15 (2 off) Front mudguard bolts 95023-06012-00 3 M6x10 (4 off) Grab rail bolts 92013-08050-00 15 M8x55 (4 off) Dome head Reed block bolts 97306-06025-00 9 M6x25 (4 off) Engine side casing (right) 92516-06030-00 9 M6x30 (7 off) engine side casing (right) 92506-06035-00 10 M6x35 (1 off) Tacho drive housing bolt 97006-06010-00 8 M6x10 Ignition coil mount bolts 92501-06025-00 2 M6x25/30 (2 off) Brake hose clamp bolt 95023-06025-00 14 M6x20/25 water pump housing bolts M6x20 (3 off) Seat lock mount bolts 92502-06016-00 11 M6x16 (4off) Indicator nut 95706-12100 13 M12x1.25 (4 off) flange nut Tail light lens screw 1M1-84524-60 4 M4x42 (2 off) Tail light mounting bolt 97321-06030 10 M6x30 (2 off) Cylinder head bolts/studs 90116-08391 2 M8x1.25x65 (4 off) Exhaust stud 90116-08042 3 M8x1.25x32 (2 off) Barrel front bolts/studs 90116-08318 12 2 off Barrel rear bolts / studs 90116-08388 13 2 off
Bolts.
Feb 8, 2018 9:42:03 GMT 1
Post by simon998 on Feb 8, 2018 9:42:03 GMT 1
I knew someone would be like me and keep a list of everything! That's fantastic man, I appreciate it. I'll print that off and nip over to the fastener place and see what they can do.
Bolts.
Feb 8, 2018 9:42:46 GMT 1
Post by simon998 on Feb 8, 2018 9:42:46 GMT 1
Do you have that saved as an xls file? I was about to import it to excel and sort it into columns but if you have it handy it would save me a half hours work, lol.
EDIT - Nevermind, I've sorted it all into excel myself. If anyone wants the spreadsheet, let me know and i'll upload it.
