Power
Nov 29, 2017 19:45:58 GMT 1
Post by 125lc1dt on Nov 29, 2017 19:45:58 GMT 1
Due to a lack of top end power on my DT 125 I’m going through the list of possible faults. Would a weak spark due to igntion system faults cause a power loss in top gear. The engine has been rebuilt and I’ve checked the fuelling side of things to. I’ve been told that the igntion exciter coil can degrade over time ?
Power
Nov 29, 2017 20:19:14 GMT 1
Post by mellow on Nov 29, 2017 20:19:14 GMT 1
Work colleague of mine has the ypvs full power same as a mate and i. His ran like a sack at times,even backwards and missing. Bought a new cdi from america for £150ish which is apparently improved and the bike now starts first kick and apparently wheelies in the gears
Power
Nov 30, 2017 18:53:27 GMT 1
Post by 125lc1dt on Nov 30, 2017 18:53:27 GMT 1
Would a fault in the igntion circuit cause a drop in power but still let the engine start and run okay ?
Power
Nov 30, 2017 19:00:59 GMT 1
Post by Mr Kipling on Nov 30, 2017 19:00:59 GMT 1
What type of DT are u referring too ??? Early dt125lc,s are hardly powerful too begin with , restricted only good for 65 top end 70 top de restricted...
Power
Dec 1, 2017 10:17:56 GMT 1
Post by 125lc1dt on Dec 1, 2017 10:17:56 GMT 1
DT125 LC1. At the moment top speed is 50/55mph as it will not accelerate in top gear. When the bike was last on the road 20 yrs ago 65/70 mph was easily achievable so I was looking at the igntion side of things as these can degrade with time. Actually I’m minded to take the whole sytem to Rex’s speed shop to test all of components for this ?
Power
Dec 1, 2017 16:44:29 GMT 1
Post by Mr Kipling on Dec 1, 2017 16:44:29 GMT 1
does it revs out in the lower gears ok ???
Power
Dec 1, 2017 18:53:49 GMT 1
Post by 125lc1dt on Dec 1, 2017 18:53:49 GMT 1
Up to 6k yes but the one time I missed a gear it miss fired at 7 k.
Power
Dec 1, 2017 19:58:21 GMT 1
Post by Mr Kipling on Dec 1, 2017 19:58:21 GMT 1
I,d deffo be looking an testing the windings an coil... have u a manual so u can check for yourself ??? easy to do..
Power
Dec 1, 2017 23:11:53 GMT 1
Post by 125lc1dt on Dec 1, 2017 23:11:53 GMT 1
Yes. Secondary windings on HT coil should be 9k ohms but getting open cuircuit. Also exciter coil plus pick up showing 158 ohms instead of 182 ohms. I’m going take all the igntion components to Rex’s Speed shop company to test them Rather than try replace bits as cdi unit very expensive
Power
Dec 2, 2017 15:57:24 GMT 1
Post by Mr Kipling on Dec 2, 2017 15:57:24 GMT 1
Might sound a silly Q , but have u tried changing the plug cap or testing the coil without it..
Power
Dec 2, 2017 19:52:55 GMT 1
Post by 125lc1dt on Dec 2, 2017 19:52:55 GMT 1
I took the secondary winding measurement with the cap off. Looks like a open circuit maybe the voltage is enough to jump the broken wire inside. Not sure if primary winding in range either. The engine uses NGK BR8 ES plug so cap non resistor type. Getting 5 K Ohms so looks okay.
Power
Jan 24, 2018 12:05:06 GMT 1
Post by 125lc1dt on Jan 24, 2018 12:05:06 GMT 1
Sorted. Had all igntion components checked out by Rex’s Racing shop. HT coil was u/s also had igntion source Coil rewound. Bike starting/ running excellent now.
