Post by Tobyjugs on Mar 28, 2018 21:37:04 GMT 1
Without
Post by dusty350 on Mar 29, 2018 7:49:00 GMT 1
Without Dusty
Post by mouse on Mar 29, 2018 7:55:41 GMT 1
Definitely without, you could use bar end mirrors?
Mouse
Post by donkeychomp on Apr 3, 2018 21:59:06 GMT 1
Post by dusty350 on Apr 4, 2018 7:40:15 GMT 1
Post by donkeychomp on Apr 4, 2018 9:42:35 GMT 1
I have Dusty. On my watch list! Can't understand how it works though, looks like it would just move about. Wracking my brain as to how we did it back in the day...I do recall lots of washers... Alex
Post by veg on Apr 4, 2018 11:33:30 GMT 1
Alex have you got a set of carbs yet? I have a spare set of 250 gamma ones, the clock cover is looking remarkably better than it did.
Post by donkeychomp on Apr 4, 2018 13:14:00 GMT 1
No carbs! Will send you a PM.
Post by 4l04ever on Apr 4, 2018 20:13:18 GMT 1
That jack up kit does not look like it would work, as you say... Look at the ones on the NKRACING website to see what they should look like.
You can use a 10W rear shock to get the back end up a bit. (Fitted to RD125LC and RD80LC).
Post by donkeychomp on Apr 4, 2018 21:00:48 GMT 1
Thanks for that...yep the NK one looks a lot different!
Post by dusty350 on Apr 4, 2018 21:14:16 GMT 1
A length adjustable shock can jack the back up a bit too. Dusty
Post by veg on Apr 4, 2018 21:14:36 GMT 1
Alex if they work they are flat side 28mm? you can have them for the postage
Post by donkeychomp on Apr 4, 2018 22:16:44 GMT 1
PM sent
Post by donkeychomp on Apr 4, 2018 22:23:43 GMT 1
Did some adding up today. I have all the receipts for every part I have bought...and then there are things I didn't include, like tyre fitting, paint, nuts and bolts etc. First receipt dated 5th April 2017. So far I have spent (gulp) £996.22
How on earth I managed to afford that is beyond me but I know there is a LOT more money to be spent. Engine...exhausts.
Post by donkeychomp on Apr 5, 2018 21:17:08 GMT 1
Post by midlifecrisisrd on Apr 5, 2018 22:03:37 GMT 1
Good build on not a lot of money
Clutch switch is usually got to do with Side stand cut out
If you try and let the clutch out in gear with the stand down it kills the engine
Post by donkeychomp on Apr 5, 2018 22:14:38 GMT 1
Ahh right, thanks Steve. I'll probably remove it Alex
Post by donkeychomp on Apr 7, 2018 21:21:29 GMT 1
Post by donkeychomp on Apr 9, 2018 21:07:59 GMT 1
Post by dusty350 on Apr 9, 2018 21:24:00 GMT 1
Hi mate Why not mount the reg/rectifier in it's normal spot - mounts on the back of the battery box plate and not the front - fuse box goes on the front. Dusty
Post by donkeychomp on Apr 9, 2018 21:28:25 GMT 1
That just dawned on me Dusty. My LC now has 2 rectifiers on. I blame a lack of sleep and Donald Trump Alex
Post by mouse on Apr 9, 2018 22:18:33 GMT 1
Bike is looking great Alex, amazing considering such a relatively small outlay. What about using ally sheet to fill the space under the seat if you are worried about heat?
Mouse
Post by donkeychomp on Apr 9, 2018 23:57:46 GMT 1
That might be a good idea mate. I shall continue with my previous measurings. Not going to use any mudguards though so might not be an issue...if I finally get a decent nights sleep I might figure something out lol.
Post by donkeychomp on Apr 13, 2018 21:04:25 GMT 1
Post by dusty350 on Apr 13, 2018 22:16:40 GMT 1
Probably got some coloured wire down the shed mate😉
Dusty
Post by reedpete on Apr 13, 2018 22:33:51 GMT 1
How does the cable contact inside the coil? Are there screw points like on the early Aircooled coils or just prongs?
Post by donkeychomp on Apr 13, 2018 23:14:21 GMT 1
Pete, I tried screwing it in but it is a prong after careful examination!
Dusty, a few bits of orange and black wire would be very handy!
Post by dusty350 on Apr 14, 2018 6:01:21 GMT 1
I will sort some wire out for you 😉
Dusty
Post by donkeychomp on Apr 14, 2018 10:37:11 GMT 1
Thanks mate. Might have to farm this soldering job out, there is hardly any wire left!
Post by donkeychomp on Apr 15, 2018 21:11:14 GMT 1
