Post by chaos824 on Nov 5, 2017 11:24:29 GMT 1
Hello beautiful people! I've just bought, not only my first big bike, but my first RD350. It looked amazing and I haggle down to a decent enough price for me. It was between this bike, or 250 smoker super sports and after much deliberation I finally caved and bought the "dream" Looks far from original (No clocks[digital one], headlight cowl and belly pan, indicators) Paint is also far from standard. I'm not really sure what the frame is, still looks like an RD350LC but its advertised as just an RD350 frame. Here it is anyhow, any info would be greatly appreciated!
Post by loudpipes on Nov 5, 2017 12:23:42 GMT 1
Is this the one from scarborough, think you will find frame is a 31k like in your title of thread mate.
Post by Yogi on Nov 5, 2017 13:01:11 GMT 1
Welcome aboard mate
The frame and bodywork are definitely 31k powervalve Powervalve motor with what looks like manually adjustable valves Looks like a cagiva mito rear swinger front end maybe szr660 Wheels could be mito or szr or even a mixture of both
Some others may know better
Matt
Post by dusty350 on Nov 5, 2017 20:08:21 GMT 1
Hi Welcome to the forum Nice looking bike - you'll enjoy that ! Front end and wheels are either Szr or look exactly the same as Tzr125r Belgarda. Enjoy Dusty
Post by loudpipes on Nov 5, 2017 21:30:54 GMT 1
If it's the bike I'm thinking of its tzr forks and wheels my mate who deals in bikes sold it to a local bike shop for not much money a year or so ago.
Post by chaos824 on Nov 7, 2017 10:43:51 GMT 1
If it's the bike I'm thinking of its tzr forks and wheels my mate who deals in bikes sold it to a local bike shop for not much money a year or so ago. Thats probably right! Yeah it was purchased by a garage in Scarborough as a build to finish apparently. The previous owner had built it to this standard and gave up at the wiring stage according to the garage. Here is what it was advertised as: bike has now been fully set up on dyno by dave wattham 2 stroke specialist and is kicking out a healthy 56.5 hp, new build rd350 engine fully stripped vapor blasted and re-built with measured crank, new head, gearbox stripped and checked, new pistons etc, brand new 34mm roundslide carbs, adjustable power valve, billet waterpump and cases, new jollymoto gp pipes, brembo wheels and brakes, new ap radial master on front and brembo master on back with brand new ebc discs, paioli forks and ohlins shock at the rear, ebc clutch, new work of art rad and silicone hoses, new expansion tank, dyna coil with taylor leads, 20mm reed block spacers, new battery new tyres, candy blue paint with the yamaha tuning forks airbrushed on then laquered over, this is essentially a new bike it will need running in correctly.
Post by Yogi on Nov 7, 2017 13:01:37 GMT 1
If the engine was set up by Muttsnutts (Dave Whattam) it should be good
Post by muttsnuts on Nov 7, 2017 20:56:57 GMT 1
If the engine was set up by Muttsnutts (Dave Whattam) it should be good um, normally I wouldn't argue with you Matt, but tne bike was brought to me as not running very well at all, its was terrible TBH, it needs more time on the dyno TBH, but the dealer just wanted it running, but didn't want to spend anymore than nec essary to get it running, so I got it going and running something like, I'll need to check my notes etc (will need bike reg number) as I am sure the clucth was either slipping and I replaced it, or it slipped a few times and needs sorting at some point - can't remember which The PV are indeed manual, so I set it for top end power, so its a little flat (well ok, quiet a lot) at the bottom end, it does have some trick parts etc on it, but really needs to PV servo etc putting back on and sorting out for it to have better bottom end Think it's running 34mm carbs as well
Post by TZ750D on Nov 7, 2017 21:08:59 GMT 1
Pipes are definitely Jollys
