Post by Mr Kipling on Jan 3, 2019 14:11:10 GMT 1
Spent the day doing nowt , though I did cook for 6 , workshop tomorrow is the plan Mike Looks like u got yourself a nice project on the go , I,ll be watching for updates...
Post by Mr Kipling on Jan 3, 2019 17:23:26 GMT 1
Here,s a throwback picture of how it looked with the side by side exhausts... These exhausts are probably what I,ll re=use this time around....
Post by jimmypx on Jan 3, 2019 17:30:58 GMT 1
I do like side by side exhausts. I'm not sure to change my to side by side or not
Post by Mr Kipling on Jan 4, 2019 14:11:54 GMT 1
Today I dropped of my subframes and a few odds n sods to be powder coated , I,m using a firm recommended by a fellow forum user , they've quoted me a weeks turnaround which,ll be great if they do... I got a little job to be done on the frame then I can reassemble back into a rolling chassis..Appy days ahead...
Post by Mr Kipling on Jan 10, 2019 16:02:20 GMT 1
So I finally have a rolling chassis back on its feet....As can be seen I,m using Yamaha R6 forks that have been revalved and resprung by Maxton too suit the lighter Aprilia frame..Once I get back the coated parts I,ll be able to move on to the next phase of the build...
Post by Tobyjugs on Jan 10, 2019 17:39:21 GMT 1
Looking forward to seeing the mootah fitted.
Post by Mr Kipling on Jan 10, 2019 21:35:31 GMT 1
Not as much as me buddy … Gonna pop the TZ dry clutched Mootah back in as its here built and ready to go …. Quick spec Tuned barrels , Nova close ratio box , Billet intakes TZ Primaries n Clutch , Billet sidecasing , Shift Pro...
Post by Mr Kipling on Jan 10, 2019 21:49:07 GMT 1
Other side don,t look too shabby either...
Post by Tobyjugs on Jan 10, 2019 23:23:29 GMT 1
I'm just in the middle of trying to get a dry clutch together. It will be using a later TZ250 clutch which is 20mm lower than the older 350 type and uses an extra pair of plates. What type of dry clutch are you using?
Post by mouse on Jan 11, 2019 9:43:57 GMT 1
That's a beauty Mr K, though if you are going to run it i would think twice about that head, (only going on my own experience!!)
Mouse
Post by Mr Kipling on Jan 11, 2019 14:32:41 GMT 1
That's a beauty Mr K, though if you are going to run it i would think twice about that head, (only going on my own experience!!) Mouse Hi Mouse , I,ve had no issues with these heads been using them for quite some time now... but thxs though....
Post by Mr Kipling on Jan 11, 2019 16:18:16 GMT 1
So last week saw me drop off some parts to be powdercoated , I got quoted a weeks turnaround and the boys never let me down as I picked it up today , so thxs Alex for the recommendation...….
Post by Mr Kipling on Jan 11, 2019 18:56:41 GMT 1
I'm just in the middle of trying to get a dry clutch together. It will be using a later TZ250 clutch which is 20mm lower than the older 350 type and uses an extra pair of plates. What type of dry clutch are you using? hi bud I,m using a TZ350E / hybrid clutch.....
Post by dusty350 on Jan 11, 2019 22:01:31 GMT 1
That's engine porn right there Mr K Verrry nice Did you use De Corrosion for the powdercoating ? Dusty
Post by Mr Kipling on Jan 12, 2019 14:01:59 GMT 1
That's engine porn right there Mr K 8-) Verrry nice :) Did you use De Corrosion for the powdercoating ? Dusty :) Yes Dusty I did , Very good service....Ask for Luke....
Post by dusty350 on Jan 12, 2019 14:49:31 GMT 1
They are good. Luke did my Rgv wheels and a few other parts last summer - excellent job. I first used them back in the 80's when they were in Feltham - did a 400 frame for me. I thought they had disappeared until Alex found them. Dusty
Post by Mr Kipling on Jan 12, 2019 22:04:08 GMT 1
yeah I,m glad Alex told me where they were , I,m all for keeping things closer too home , helps out a bundle....
Post by Mr Kipling on Jan 17, 2019 21:17:24 GMT 1
Changed the steering bearings n races today used this little gem too make quick work of removing the races
Post by jimmypx on Jan 17, 2019 23:00:26 GMT 1
They make it so much easier.. You can get longer ones aswell
Post by Mr Kipling on Jan 18, 2019 20:29:11 GMT 1
Yeah it does ,,,I tried drifting the races out to no joy and then remembered I,d bought this 30 secs later they where out...Result....
Post by Mr Kipling on Jan 19, 2019 15:37:10 GMT 1
So today I refitted the front end after replacing the bearings n races also ordered a new R6 ignition switch so I can sort out the steering lock once it arrives it,s slow progress but it is progress…..
Post by Mr Kipling on Jan 20, 2019 14:05:58 GMT 1
Rebuilt a rear shock today just incase I need it as a spare....
Post by Mr Kipling on Jan 20, 2019 16:27:27 GMT 1
Post by jimmypx on Jan 20, 2019 16:34:04 GMT 1
How do you rate the rear sets? they are alot cheaper than gilles. I'm looking at buying them ones or gilles.
Post by Mr Kipling on Jan 20, 2019 16:38:27 GMT 1
The rearsets are good multi adjustable just like my gilles I have on my other build not quite the same quality but bloody good though....
Post by dusty350 on Jan 20, 2019 18:01:07 GMT 1
Looking very nice Mr K What make are your rearsets ? Dusty
Post by jimmypx on Jan 20, 2019 18:17:35 GMT 1
The rearsets are good multi adjustable just like my gilles I have on my other build not quite the same quality but bloody good though.... Cheers they do them in All different colours as well.
Post by Mr Kipling on Jan 20, 2019 19:14:22 GMT 1
Looking very nice Mr K What make are your rearsets ? Dusty Hi Dusty , there made in Italy not too sure of the makers name without finding me invoice,,, ::)
Post by jimmypx on Jan 20, 2019 20:06:42 GMT 1
Post by Mr Kipling on Jan 20, 2019 20:22:49 GMT 1
yeah , there the ones I had mine clear anodised and replaced all the bolts for stainless and replaced the rose joint for a stronger one....
