Post by Mr Kipling on Dec 21, 2018 15:22:05 GMT 1
Been tweaking the lower fairing too enable the fairing n exhausts to behave with each other , need to fabricate a few mounts but getting there slowly...
Post by Dangerous on Dec 21, 2018 15:42:52 GMT 1
Looking fantastic MR K.
Post by Tobyjugs on Dec 21, 2018 17:21:53 GMT 1
I have to agree with Dangerous but i still like the back end in your avatar much more
Post by Mr Kipling on Dec 21, 2018 18:15:07 GMT 1
I have to agree with Dangerous but i still like the back end in your avatar much more I totally agree she,s a bit peachy !!!! ;)
Post by jimmypx on Dec 22, 2018 19:46:37 GMT 1
Nice project 👍. I'm tempted to put my ypvs engine in my rs250. What engine cradle do you have?
Post by mikee on Dec 22, 2018 19:52:20 GMT 1
Mr K asymmetric pipes are the future
Looking a sticking a 31k , +4 etc etc ..., in a Mille frame I have knocking about , same as but a lot different to the rs set up If I can make some space in the workshop it might start , soon
Mike
Post by Mr Kipling on Dec 23, 2018 13:49:34 GMT 1
Nice project 👍. I'm tempted to put my ypvs engine in my rs250. What engine cradle do you have? In this one a terry mead kit , in the other build a complete FFTP KIT...Hth...
Post by jimmypx on Dec 23, 2018 14:59:49 GMT 1
Nice project 👍. I'm tempted to put my ypvs engine in my rs250. What engine cradle do you have? In this one a terry mead kit , in the other build a complete FFTP KIT...Hth... Thanks where could I find the terry mead kit ?
Post by Mr Kipling on Dec 23, 2018 15:06:41 GMT 1
In this one a terry mead kit , in the other build a complete FFTP KIT...Hth... Thanks where could I find the terry mead kit ? Talk too terry or Alyson direct , 01233 840323... Hth
Post by Mr Kipling on Dec 23, 2018 15:10:32 GMT 1
Thanks where could I find the terry mead kit ? Talk too terry or Alyson direct , 01233 840323... Hth Mark dent also makes a fitting kit btw... Performance fabrications ltd , 07831 711079..
Post by jimmypx on Dec 23, 2018 15:11:48 GMT 1
Talk too terry or Alyson direct , 01233 840323... Hth Mark dent also makes a fitting kit btw... Thank you 👍
Post by jimmypx on Dec 23, 2018 15:17:28 GMT 1
Thanks where could I find the terry mead kit ? Talk too terry or Alyson direct , 01233 840323... Hth Just had a search and they are only 20 minits away from me.. Thanks
Post by Mr Kipling on Dec 23, 2018 15:22:37 GMT 1
Talk too terry or Alyson direct , 01233 840323... Hth Just had a search and they are only 20 minits away from me.. Thanks Terry n Alyson are nice people easy to deal with...Atb...
Post by 4l04ever on Dec 23, 2018 16:05:40 GMT 1
How much is the Terry Mead fitting kit? The Mark Dent one is £850.
Post by Mr Kipling on Dec 23, 2018 21:21:31 GMT 1
How much is the Terry Mead fitting kit? The Mark Dent one is £850. Sorry no idea of current price...
Post by Mr Kipling on Dec 24, 2018 11:35:07 GMT 1
So I recently ordered a +4 hotrods stroker bottom end kit and santa obliged by dropping it off today for me ( most people get to open a prezzie on Xmas eve ) It comes with a gasket set designed to be used with Vertex pistons ..the base gaskets are the correct size too make the pistons n barrels sit flush with each other ... This I,m using to build a 385 cc motor , I,ll use it with my vertex stroker pistons that I have here along with brand new barrels etc...
Post by Mr Kipling on Dec 24, 2018 14:55:53 GMT 1
So these are the barrels n pistons etc I,ll be using .. Once ive popped the crank in the cases I,ll pop on the pistons n barrels and measure up before sending barrels up to uncle Mick for tuning...This,ll be the engine I,m going to use in this build the other Mootah I,ll keep as a large paperweight...
Post by Mr Kipling on Dec 26, 2018 16:23:22 GMT 1
So I,m sitting here after havin a few bevvies and start too think maybe I should turn this into a 421 and use the engine I just have sitting here after all I,d only need a new set of exhausts which I could nab from the other build...Mmm....
Post by jon on Dec 26, 2018 17:02:53 GMT 1
Personally I think it’s a shame to tune a NOS set of PV cylinders. They are not priceless, but definately worth big money to someone building a top notch bike.
Sell them to someone who wants this type of build, and it would probably pay for your proposed cylinders at least.
Post by Mr Kipling on Dec 26, 2018 17:12:16 GMT 1
Don,t need to buy cylinders Jon , I got a ready made 421 mootah sitting in the spare room alongside my TZ equipped mootah...
Post by Mr Kipling on Dec 27, 2018 13:28:16 GMT 1
Nice to see the post is working today received one set of exhaust studs.
Post by Mr Kipling on Dec 27, 2018 14:56:41 GMT 1
Started too sort the bits for the motor awaiting on another box from fowlers but have a few parts already...
Post by jon on Dec 28, 2018 10:13:52 GMT 1
Started too sort the bits for the motor awaiting on another box from fowlers but have a few parts already... Is that a dowel pin 99530-10114 for the cylinders at the bottom of the picture? If so I’d be keen to hear your opinion of the fit. Mine was dire so I had to machine one with an internal thread. Jon
Post by dusty350 on Dec 28, 2018 10:30:16 GMT 1
That looks like a selector fork pin to me ? Dusty
Post by Mr Kipling on Dec 28, 2018 12:30:07 GMT 1
Is that a dowel pin 99530-10114 for the cylinders at the bottom of the picture? If so I’d be keen to hear your opinion of the fit. Mine was dire so I had to machine one with an internal thread. Jon Hi Jon , the pins are a nice snug press fit , easy to do on bare cases without the studs in place....Hth
Post by Mr Kipling on Dec 28, 2018 14:00:40 GMT 1
Few more parts turned up for the puzzle...Slowly getting there
Post by jon on Dec 28, 2018 14:09:39 GMT 1
If so I’d be keen to hear your opinion of the fit. Mine was dire so I had to machine one with an internal thread. Jon Hi Jon , the pins are a nice snug press fit , easy to do on bare cases without the studs in place....Hth Mine wee terrible. Inside diameter too big, and outside too small. Jon
Post by Mr Kipling on Dec 28, 2018 16:59:27 GMT 1
The Vertex pistons are a cast item and come equipped with there own fishnet stockings..
Post by Mr Kipling on Jan 1, 2019 16:51:12 GMT 1
So today I kick started the new year off by removing all parts from the subframes along with a few other parts in preparation for powder coating,,, Fingers crossed I wont need to wait too long to get them back enabling me too get stuck into the good stuff....
Post by mikee on Jan 1, 2019 20:58:26 GMT 1
Spent the day doing nowt , though I did cook for 6 , workshop tomorrow is the plan
Mike
