Post by bryan on Jun 3, 2018 19:16:24 GMT 1
Decided to get the engine in today too, just to get my bench clear. Filled down the YPVS plastic stator cover round the rear LC frame tube too. Untitled by Bryan Haynes, on Flickr
Post by bryan on Jun 3, 2018 19:18:44 GMT 1
Fitted ignition, NK Vapor bracket and clocks, will get battery next week and start on the wiring for it. Untitled by Bryan Haynes, on Flickr
Post by bryan on Jun 16, 2018 14:06:13 GMT 1
Owner dropped off the EBC VEE Rotors discs and bolts and front caliper bolts today, think they look great. Untitled by Bryan Haynes, on Flickr Be off to Mark Dent soon for pipes and custom rear sets.
Post by spacejunkie on Jun 17, 2018 8:18:36 GMT 1
Where did you get the ceramic coating done it looks good
Post by ingo on Jun 24, 2018 22:18:58 GMT 1
Flying tiger at bury st Edmunds 01284 599003 it’s cerakote very hard wearing but not as thick as powder coating
Post by lb on Jul 12, 2018 23:30:50 GMT 1
Awsome build so far,looks great.
Post by bid on Jul 13, 2018 20:49:36 GMT 1
you guys honestly, why cant i do this stuff, chuffing awesome, cant wait to see this finnished, well done chap,👏
dave😉👍
Post by bryan on Sept 8, 2018 14:37:11 GMT 1
firebird67
2 strokes forever 😍😍😍
Post by firebird67 on Oct 15, 2018 23:22:37 GMT 1
Looking good rearset look cool 👍
Post by bryan on May 21, 2021 20:55:14 GMT 1
Time to get this thing restarted and built, can’t believe it’s been so long since I’ve done anything on it. Going to catch up on work I've managed to get done over the last week. 28mm Mikuni flat slides (£295 from Norbo) on new Genuine Yamaha cable with 40deg adapters, all just goes together no issues. Steve’s Build by Bryan Haynes, on Flickr Easy fit straight onto inlet rubbers. Steve’s Build by Bryan Haynes, on Flickr Ordering to Ramair filters once batch has been made. Untitled by Bryan Haynes, on Flickr
Post by bryan on May 22, 2021 1:38:17 GMT 1
Trail Tech Vapour dash wired up with coolant temp now showing, all warning lights working. Untitled by Bryan Haynes, on Flickr Had to have temp sender hole tapped to match new 2 wire sender unit. Steve’s Build by Bryan Haynes, on Flickr
Post by Robbieben on May 22, 2021 7:23:45 GMT 1
I'd be interested to see the dash when its up and running, this is one of the options I've looked at for my hybrid build.
Post by bryan on May 22, 2021 10:09:18 GMT 1
Post by bryan on May 22, 2021 10:38:31 GMT 1
Steve dropped the tank round so I can get it started soon, so stuck the RGV carbon mudguard and left pipe to see what it looks like. Steve’s Build by Bryan Haynes, on Flickr
Post by bryan on May 22, 2021 10:41:58 GMT 1
Post by bryan on May 22, 2021 10:52:08 GMT 1
Post by bryan on May 22, 2021 11:21:26 GMT 1
Post by bryan on May 22, 2021 11:56:06 GMT 1
Post by bryan on May 22, 2021 15:24:30 GMT 1
Tank clean b4 I try to start it as waiting on petrol and oil pipes, 2 keys of Aquarium grave and Por15 Marine Clean first followed up with some Zinc Phosphate Metal Ready. Untitled by Bryan Haynes, on Flickr Bit better. Untitled by Bryan Haynes, on Flickr
Post by bryan on May 22, 2021 17:11:30 GMT 1
Dyna Miniature Series DC11-2 high output coil fitted, make the engine so easy to start when you fit one compared to an old original coil, simple to fit just make a twin wire loom from coil plug and bolt it on.. Untitled by Bryan Haynes, on Flickr
Post by bryan on May 23, 2021 18:22:30 GMT 1
As I'm not running a hose into the LC rad for the thermostat bypass, I'm drilling the same size hole in the body. Untitled by Bryan Haynes, on Flickr
Post by bryan on May 24, 2021 0:18:30 GMT 1
Post by Dangerous on May 24, 2021 6:25:18 GMT 1
AMAZING BRY AS USUAL 👍👍
Post by bryan on May 24, 2021 14:03:02 GMT 1
