Post by headcoats on Jun 27, 2018 10:33:06 GMT 1
Put this pic on top of page 4 for a sneaky peak at what the pile of bits are morphing into !
Tried the paint out today !
Don't half make you nervous handling new paint LOL
Post by headcoats on Jun 27, 2018 17:41:04 GMT 1
Probably a slightly different route on the steering locks, I had a section of metal tube welded to the underside of the headstock So the bump stops are at the back and the lock stops were drilled and tapped so it can be adjusted on an M6 bolt Need to grind it down a bit and refine it too
Post by headcoats on Jun 27, 2018 17:42:04 GMT 1
From the front and in fairness you will hardly see it when it's all painted/powder coated
Post by headcoats on Jun 27, 2018 17:43:28 GMT 1
Looks like the radiator cap stops play on the right side turn
Post by donkeychomp on Jun 27, 2018 20:51:03 GMT 1
Is there such a thing as a rad cap with only one lug?
Post by headcoats on Jun 27, 2018 21:13:30 GMT 1
The one I will be using is the round type , genuine part but the later round design
Welder is coming sunday to hopefully whip this UK frame into shape or it will be surrender to the Germans LOL
Post by donkeychomp on Jun 27, 2018 21:56:19 GMT 1
haha!
Post by headcoats on Jun 28, 2018 13:09:26 GMT 1
Inner muddy looking a bit shite ! What's the best way to make it look reasonable again ?
Post by donkeychomp on Jun 28, 2018 21:40:40 GMT 1
Lots of ways. Dishwasher first, Back to Black if it's not scratched too much, if it is very fine wet and dry then maybe shoe polish and a buff...loads of other ways too!
Post by headcoats on Jun 29, 2018 15:59:49 GMT 1
looking through my bag of new bits I have a YPVS gear change which apart from it being black and not chrome, thought it was the same as an LC one
WRONG !
The shaft that slides onto the pin on the footrest is not as wide DOH !
So either space it out or ask Nick Chambers who makes stainless shafts for the footrest to make a shorter version or sell or swop with someone for an LC one
It was new in the bag till today :-)
This pic shows the reduced width compared to the LC
What's a 1UA part worth , are they still available , am I sitting on a goldmine LOL
Post by headcoats on Jul 1, 2018 15:30:44 GMT 1
Welder came today to check the frame out and he will come next sunday to do the work
So getting the frame and bits powder coated is looking a step closer
Post by midlifecrisisrd on Jul 2, 2018 7:42:16 GMT 1
1ua pedal nla, last sold at £30. Still a few floating around though
LC replica complete pedal, rod and arm available at £30 from legend or Yambits for under £30 posted
I'll give you £30 plus post for it
Post by headcoats on Jul 2, 2018 16:56:10 GMT 1
How much is a genuine chrome LC gear change, just the lever bit :-)
Post by midlifecrisisrd on Jul 2, 2018 18:13:40 GMT 1
How much is a genuine chrome LC gear change, just the lever bit :-) I could answer that if I could find one lol Steve
Post by headcoats on Jul 2, 2018 18:39:37 GMT 1
Oh so no longer available either then !
Post by midlifecrisisrd on Jul 2, 2018 18:53:53 GMT 1
Post by headcoats on Jul 3, 2018 13:02:47 GMT 1
Nissin radial master cylinder 19mm bore
Does anyone know what angle I need the Banjo for as it is quite different to a non radial brake ?
Post by donkeychomp on Jul 3, 2018 21:36:23 GMT 1
I'd say get it as straight as you can to avoid any kinks.
Post by headcoats on Jul 4, 2018 9:38:45 GMT 1
Think I'm going to assemble the bike and put all the wiring ,switchgear and cables etc then see where I can route the brake hose for the cleanest look
Post by headcoats on Jul 4, 2018 9:45:40 GMT 1
As you all know I love my KR1S wheels LOL but as the rear wheel is an 18 inch wheel and takes a freaky 140 60 18 tyre (150 can be fitted) All the big tyre companies apart from Bridgestone had stopped making that size Bridgestone were doing BT90 and BT92's but now only offer a BT90 and in a 150 60 18 All the others are old stock, so I think I will have to hang onto the 17 inch RS 250 Aprilia rear wheels in case the worst happens !
Post by wwwRD350LCnet on Jul 4, 2018 10:20:17 GMT 1
Your shift lever is from YAMAHA new manufacturing I think because really different compare to the genuine version (black painted, different ball metallic coating) !!!:
When did you buy it ?
Xavier
Post by midlifecrisisrd on Jul 4, 2018 12:12:59 GMT 1
Xavier I did wonder as I have a used one that is olive drab Steve
Post by headcoats on Jul 4, 2018 14:06:39 GMT 1
Bought it about 7 years a go
I will probably use it then with a few spacers
Post by headcoats on Jul 7, 2018 11:32:05 GMT 1
Hurrah Got a replacement sprocket after the fake one and guess what it fits LOL If you get a JT sprocket , it should come in the branded bag and a little piece of paper inside showing the batch number etc
Post by headcoats on Jul 7, 2018 13:08:57 GMT 1
rdlccrazy.proboards.com/thread/44679/ypvs-tacho?page=1&scrollTo=409509Check out the above thread I'm looking at putting an electronic YPVS tacho in the LC clock cases as my engine cases have no machining for the earlier type mechanical gears What would be nice as mentioned would be the YPVS tacho with a different clock face decal (and needle) and a cut out for a tiny temperature gauge :-) Any opinions welcomed !
Post by midlifecrisisrd on Jul 8, 2018 10:16:34 GMT 1
Jap rz250 ypvs used a tacho with a black face and white writing with a white thin needle
Post by headcoats on Jul 8, 2018 18:25:52 GMT 1
Is this what you mean ?
The 1-12 look in the same position , as in zero at 9 0clock
Wonder if there are replica decal faces for these ?
Post by headcoats on Jul 8, 2018 19:11:06 GMT 1
Liking how these end cans are tucked in Trouble is I'm keeping the standard hangers as it's the law (plus if you chop the passenger peg holes off is a no no too ) so will have to see how the Lomas GP pipes look once bolted on
Prefer the staggered look compared to the parallel look as standard
Post by midlifecrisisrd on Jul 8, 2018 19:36:11 GMT 1
Wonder if there are replica decal faces for these ? No like this Steve
Post by donkeychomp on Jul 8, 2018 21:07:23 GMT 1
I know someone with a set of those clocks if that helps at all! He might be persuaded to part with them.
