Post by vin on Jan 9, 2007 19:32:53 GMT 1
That would make nuttytart feel a whole lot better in herself wouldn't it ..................................and me I don't suppose you have the clock wiring harness,cherry speed sensor ( no pun about cherry's ) temp sensor and ohm resistor by any chance as well ;D So what price to a fellow buddy,mate ,comrade,friend then
Post by vin on Jan 17, 2007 15:27:23 GMT 1
Carbon fiber parts have been delivered direct from Tokyo ;D it only took a week
Post by vin on Jan 17, 2007 15:46:43 GMT 1
I decided to go for the acewell clock's in the end as they came my way at a very nice price and they don't take as much fitting as the R1 clock's The only thing is they don't have temp readings so on the look out for a diddy digital one if anyone finds one
Post by vin on Jan 17, 2007 21:41:31 GMT 1
Thanks mate Just waiting for the wavy's,rearsets and powder coated wheels, a bit more fabricating and then spray job I'm hoping by March it should be finished ;D
Post by pablo on Jan 18, 2007 15:32:32 GMT 1
how much that vin? n wassit do?
Post by vin on Jan 18, 2007 17:58:02 GMT 1
Post by pablo on Jan 18, 2007 19:10:32 GMT 1
i had summit very similar on one of my karts made by alfono
Post by vin on Jan 20, 2007 18:18:45 GMT 1
Post by vin on Jan 20, 2007 23:20:45 GMT 1
Yep mellow mate I can't wire the speedo up until I get the ignition sorted Because I have put the RGV ignition on I need to splice it onto a RD loom electrical block,so it's a bit of a nightmare trying to work it out .........as I said electrics not my forte
Post by vin on Jan 21, 2007 23:23:49 GMT 1
I like it because they keep the front end nice and neat and compact .
Post by vin on Jan 24, 2007 19:20:54 GMT 1
Thanks donk The rear sets came today ;D probably not the quality of raask,le-moto etc but certainly worth the money They will need obviously either frame mod or bracket making but I knew that. and here they are just to see how they will look ;D
Post by vin on Feb 4, 2007 20:27:37 GMT 1
Wheels back from the powder coaters (thanks Kc) carbon fitted and rear sets mounting bracket mocked and ready for me to cut out of some very nice 10mm ally plate ;D Oh and not the one shown in picture! this is number 3 of 5 designs I played with Hopefully disc's will be here next week,and I've been in touch with Richy Herbert about the paint job ;D So coming along.
Post by Dirtbag on Feb 5, 2007 6:44:05 GMT 1
Christ on a bike !.............Vin mate....are you a lottery winner ? All that Carbon fibre and trick bits must have cost you a kidney. It does look very very good. Love the black stuff......wheels etc Looks like something the Ghostrider would mount You're not gonna put a canoe on the back of it are you ?...........that seems to be the trend these days
Post by vin on Feb 6, 2007 22:37:09 GMT 1
Thanks guys for all your great comments donk, No not a lottery winner just had to sacrifice me other bike .........besides if I was a lottery winner I'd have allot better workshop than my pokey shed
Post by vin on Feb 9, 2007 22:18:55 GMT 1
I know what you mean mate......I use my workshop as a spraybooth...its that small ;D ;D ;D Finished the rear sets tonight ;D I might do a little bit more milling in the centers What do you think guys polished or powder coated?
Post by nuttytart350 on Feb 9, 2007 22:39:22 GMT 1
just a thought vin ... do u have enough clearance to yur spannies with the rear sets there ... mine needed bigger spacers ... they do look the biz tho' .. well done ...
Post by vin on Feb 10, 2007 15:12:35 GMT 1
just a thought vin ... do u have enough clearance to yur spannies with the rear sets there ... mine needed bigger spacers ... Well spotted Nutty the ally plate is 10mm thick (a little over kill I know) but will probably need to space out a little more and I have already done some different thickness spacers to experiment on And thanks for all the great feedback guys n gal ;D Oh and just picked up from that very nice man Kc104 some more powder coated bits So watch this space for more piccies
Post by vin on Feb 10, 2007 20:24:33 GMT 1
Some more bling ;D looks better than the pictures portray
Post by nuttytart350 on Feb 11, 2007 10:42:02 GMT 1
ere vin .... where did ya get the plastic brake pipe on that rear brake up to the reservoir .... i need sum o that miself ....
Post by vin on Feb 11, 2007 12:53:22 GMT 1
ere vin .... where did ya get the plastic brake pipe on that rear brake up to the reservoir .... i need sum o that miself .... Hi nutty, Sorry I don't know as it was already on them when I bought them?
Post by vin on Feb 11, 2007 22:04:00 GMT 1
For coating they blast it and mask it They use a foil type tape,takes a bit of getting off though and always best to clean threads out after with a tap
Post by scott on Feb 11, 2007 22:11:42 GMT 1
cheers m8,the place where i've had a couple of frames done charges £40 per frame plus some bits but i av to clean everythin down and would av to mask it all off if needed but don't know if this is a good price or not
Post by vin on Feb 11, 2007 22:32:19 GMT 1
I would say that is a good price A fair bit of work to blast and mask a frame but if it saves money then thats got to be good
Post by vin on Feb 17, 2007 18:12:34 GMT 1
Post by nuttytart350 on Feb 17, 2007 23:43:45 GMT 1
not at the moment he wouldn't .... ;D did sum1 mench bird flu ... nice one vin the bling ....
Post by vin on Mar 3, 2007 20:36:43 GMT 1
Post by vin on Mar 4, 2007 9:49:53 GMT 1
just file the gap out where the chain rubs or leave the chain n it will wear wot it needs ;D I've filed down the ribs on the inside of the casing but it's not enough! so I think I may have a go at making a couple of my own gaskets and see if that will work Cheers guys for your great comments
Post by vin on Mar 4, 2007 21:41:11 GMT 1
thanks mate Yep I've been busy the last few day's (even with man flu : and have got allot done! How about you mate? was hoping for some updated piccies of yours? Oh and I ended up fitting the RD ignition in the end and modifying the top yoke still it's done now other than powder coating a few bits!
Post by vin on Mar 4, 2007 21:46:49 GMT 1
Dave, this is how the ignition ended up like! just need the bracket powder coated so that it blends in and then fit my Koso temp gauge in the space left.
Post by vin on Mar 5, 2007 18:07:00 GMT 1
