Post by mellow on Nov 8, 2005 21:46:38 GMT 1
Post by chrismac on Nov 11, 2005 19:47:58 GMT 1
how do you get the hangers show shinney?
Post by mellow on Nov 11, 2005 20:50:50 GMT 1
how do you get the hangers show shinney? Probaly with a polishing wheel. I have just finished polishing up boost bottles and you can get a realy nice shine with the right kit. You can see them on the wanted and forsale page. Bling bling 10 points to norbo ;)polishing kit.......if theres deep pits i use 320 grade wet n dry then work down with the 3 types of mop and cutting compound.then BLING BLING shiny ;D NORBO..........u didnt say wot u use for the de-carboning of valves and head m8 ???or is it a trade secret?
Post by Norbo on Nov 12, 2005 17:19:57 GMT 1
Its no secret . Scrape the hard carbon of with a smooth knife not one with small serations on. Wire wheel them down then wet and dry anything left . Simple.
Post by mellow on Dec 9, 2005 21:06:06 GMT 1
ok..........couple more pics of me latest bit B4 Paint - Shotblasted
After - Sprayed
Post by mellow on Dec 9, 2005 22:04:45 GMT 1
cheers the swingarm was shotblasted then couple of coats of etch primer then 2 pack primer then sprayed with Fine Alluminium colour paint (at least i think thats wot me m8 said it was ) not sure if he laquered it after but its quite shiny.........i must ask him the frame is a bit awkward to price.........i had the frame,swingarm,bottom yoke,headlamp cradle,rear brake pipe clip and relay arm shotblasted and then all them bits powder coated apart from the swingarm n it cost £120. hope that helps
Post by mellow on Dec 13, 2005 22:29:39 GMT 1
yup b nice to b on a stroker again ;D just hope its reliable well......as reliable as a 2 stroke gets nearly got al me bits so should start re assembly soon
Post by mellow on Jan 8, 2006 17:15:52 GMT 1
Post by chrismac on Jan 8, 2006 22:35:27 GMT 1
Tell me Tell me plz
How do you get the bits so shiny?
Post by mellow on Jan 8, 2006 22:43:19 GMT 1
with a polishin kit from M and P made by Mr Fastner.i sand most of the deep pits out with 320 grade wet n dry paper then just use the 3 different grades of polishin soaps n mops n there u have it
Post by chrismac on Jan 8, 2006 22:49:17 GMT 1
sounds to easy
how long does each bit take?
Post by mellow on Jan 9, 2006 16:29:28 GMT 1
if i did it solidly it would b about 7hrs i spose but i normally sand down one day then polish the next. cant do it all in one day due to sore fingers from sandin DIRTBAG............honest they aint chrome.they aint even perfect.if u got real close u would see tiny pits still but they look good enough n they had enough time spent on them now
Post by Norbo on Jan 9, 2006 21:29:20 GMT 1
I know what you meen . I used to do polishing for other people and you just cant charge for the time it takes to do a real good job. Allthough i do have better kit then the m&P stuff it still takes me a long time to do stuff 1 boost botle takes about 2 hours to take the welds of linish down and polish . I only wish they stayed so shiney .
Post by mellow on Jan 10, 2006 17:48:03 GMT 1
do u use the coarse compound n the mop that looks like a string doormat to do the welds norbo shouldnt take long with that? as for keepin shiny i only give mine a rub over once every couple of months with MAAS cream. wot kit u got then? the Mr.Fastner kit i got from M&P is top notch gear mate u can even phone them n they give advice if u need it
Post by Norbo on Jan 11, 2006 10:27:35 GMT 1
I dont use a kit i get mops ans compounds from polishibng suppliers as i need them. It takes so long becourse of the welds and linishing out all marks befor i polish . The more time you spend linishing down the better job you get with the polishing .
Post by mellow on Jan 11, 2006 16:53:10 GMT 1
yep i agree with that i sand the worst pitting out coz its quicker than polishin with the course mop but the coarse mop and soap i have will smooth welds right down as long as its shiny at the end thats cool
Post by mellow on Jan 22, 2006 0:38:20 GMT 1
yes m8 its called Vienna Lime.u r sposed to dust it onto the bit u have polished n its supposed to remove the grease film left by the polishing soap. i dont use it coz it dont seem to do much.i use MAAS cream to clean the grease off.its like autosol but finer.i think its the same as autoglym metal polish m8. hope this helps.n e more questions feel free 2 ask
Post by chrismac on Jan 22, 2006 1:00:39 GMT 1
Cheers
Post by mellow on Jan 23, 2006 15:26:00 GMT 1
OH BALLS!!!! been waitin since b4 xmas for ONE part so i can get me swingarm on.shop fones 2 day n says ur bits on.............YIPPEE i think..............rush down there................WRONG PIVOT SLEEVE!!!! so after about 4 weeks wait..............he ordered the correct one 2 day n it will b in 2morrow.bit of a time difference there oh well.........praps il have a rollin chassis by the weekend
pete
Post by pete on Jan 23, 2006 16:07:41 GMT 1
superb job with the polishing I know how long it takes cos I did the same to my LC2 brackets. Impressed you had a go at the F2 footpeg brackets I was going to do mine but thought it impossible cos of the dimpled finish but you have done it Pete
Post by mellow on Jan 23, 2006 16:45:11 GMT 1
thanks :)they took a few hrs sandin down first though
Post by mellow on Jan 28, 2006 18:11:50 GMT 1
Post by chrismac on Jan 28, 2006 23:57:13 GMT 1
Total respect to mellow regarding the polishing, just had a go at my hangers now where near as good as mellows.
The work on the frame etc loos spot on as well
Post by nuttytart350 on Jan 29, 2006 0:26:11 GMT 1
Looking good there.....is that a new shock?
Post by mellow on Jan 29, 2006 14:32:34 GMT 1
CHRISMAC.......................... m8 it takes ages,u cant do it in 5 mins my m8 thought it could b done in an hr or so but the end result shows all main thing to do is get all pits/scratches etc out with the straw lookin mop and brown soap.dont b afraid to add a bit more pressure if the pits etc are deep. once they are nearly all gone switch to the stitched mop and the white soap. use that until all marks are gone.may take a while dependin how much u left to polish out. once u done that u clean ALL residue of cutting compounds off,i use autosol or MAAS creme. then use the other mop with the blue soap till its shiny NUTTYBIRD yup it most certainly is a brand spankin new shock from my local bike dealer.and it was in stock which was even better ;D
Post by mellow on Mar 4, 2006 21:57:10 GMT 1
UPDATE....................i am totally fed up with doin my wheels paint stripped............sanded.........polished spokes on one side of one wheel..............still not finished...........been workin on em after work all week n all 2 day END OF UPDATE
Post by mellow on Mar 8, 2006 18:26:04 GMT 1
i have sum of that sealant and sum rust killer to go in first but if its like a t bag its not worth tryin it foned a breaker yesterday..........said "im lookin for an F2 tank that dont leak m8"............"so am i " he said bought one off ebay that apparently has no rust on seams and doesnt leak but has a dent.we will see
Post by mellow on Mar 11, 2006 17:15:02 GMT 1
one side of a wheel
Post by mellow on Mar 12, 2006 22:53:52 GMT 1
thats the first side..............did the spoke faces today on the other side n boy r they blingin ;D still got the rim to do n the rear wheel
Post by mellow on Mar 18, 2006 16:47:23 GMT 1
well wot another fun day i feel i must warn u all that Yamaha F2 tanks ARE made of tissue paper pulled a huge dent out.......welded hole.......welded next hole it made.....then the next.then the next.....may as well seam weld the whole thing and this is on a tank that "doesnt" leak
