Post by tipfinchy on Jul 29, 2018 23:26:38 GMT 1
that is going to be so shot hit , cracking build
Post by Topman350 on Jul 30, 2018 20:14:19 GMT 1
that is going to be so shot hit , cracking build Thanks for the comment mate much appreciated π
Post by tipfinchy on Jul 30, 2018 21:47:12 GMT 1
love it , the tank and seat really look like they were meant to be , the fat as fook forks , swingarm etc etc
being a bit new on here im gradually reading all the build threads ( a bit like bingeing on box sets?) and admiring all the thought , dedication and hard work going in to the builds
Post by Topman350 on Jul 30, 2018 22:02:11 GMT 1
love it , the tank and seat really look like they were meant to be , the fat as fook forks , swingarm etc etc being a bit new on here im gradually reading all the build threads ( a bit like bingeing on box sets?) and admiring all the thought , dedication and hard work going in to the builds It's a great forum lots fantastic builders and you're always learning are you having a good yourself if not you should plenty of advice on how to get started...I myself should be done by very early October ππ
Post by Topman350 on Aug 1, 2018 12:25:39 GMT 1
Hooked up the fuel tap this morning, tell me guys will I need to fix a breather pipe as this tank will be sealed...you can see in the pick theres a larger circular entry point where the original fuel pump would go as this is now removed and will be resealed I'm sure the breather pipe will be needed to help fuel flow easier to ask than mess about.π www.dropbox.com/sc/k161roxl53zyb8v/AABbYIV786owje4hFF2G97--a
Post by dusty350 on Aug 1, 2018 16:15:44 GMT 1
Hi mate The tank will need to breathe for sure. An Lc tank breathes through the key slot in the cap. I fitted a new billet cap made by Wicked, and it's design meant the sealing washer restricted the groove that was meant to allow the cap to vent, so it couldn't. Every time I opened the cap there would be a loud hiss where pressure had built up in the tank. I had to drill a small hole all the way through the cap and then it was fine. Another member had the same cap, and same problem and his bike would die on a run due to fuel starvation where the cap wasn't venting.
Dusty
Post by Topman350 on Aug 2, 2018 21:10:00 GMT 1
Hi mate The tank will need to breathe for sure. An Lc tank breathes through the key slot in the cap. I fitted a new billet cap made by Wicked, and it's design meant the sealing washer restricted the groove that was meant to allow the cap to vent, so it couldn't. Every time I opened the cap there would be a loud hiss where pressure had built up in the tank. I had to drill a small hole all the way through the cap and then it was fine. Another member had the same cap, and same problem and his bike would die on a run due to fuel starvation where the cap wasn't venting. Dusty Cheers Dusty Thought so just needed it confirmed I'll see which is best to suit the tank many thanks ππ
Post by Topman350 on Aug 8, 2018 22:55:35 GMT 1
Post by Topman350 on Aug 13, 2018 14:57:30 GMT 1
Experimented with silver soldering must say very impressed so attached the hangers to my exhausts the strength is amazing for very little effort when i've finished rubbing down and polishing will post up some more pics will be doing so much more with this method ππ photos.app.goo.gl/kyCLzp5yk33GhVqx9
Post by rdboy63 on Aug 13, 2018 16:45:35 GMT 1
Great work Topman,coming on a treat,cheers Mick
Post by donkeychomp on Aug 13, 2018 22:42:14 GMT 1
Just seen the pics. What exactly is silver soldering. I can solder fine but my welding looks like bird droppings lol.
Post by Topman350 on Aug 13, 2018 23:33:25 GMT 1
Just seen the pics. What exactly is silver soldering. I can solder fine but my welding looks like bird droppings lol. Alex It's cool stuff seen it on YouTube it's referred to as ssf-6 muggy weld from the USA expensive but I trawled through eBay and found a similar product 5 rods 250mm flux coated so bought them had a practice it's pretty easy just take your time, it will weld just about any metal just use a hand held gas blow touch,look it up there is a video showing 2xSS washers it welds as strong as mig with and good finish too go for it ππ
Post by donkeychomp on Aug 14, 2018 0:34:13 GMT 1
Brilliant! I will try it thanks matey.
Post by Yogi on Aug 14, 2018 6:31:00 GMT 1
Just seen the pics. What exactly is silver soldering. I can solder fine but my welding looks like bird droppings lol. Alex It's cool stuff seen it on YouTube it's referred to as ssf-6 muggy weld from the USA expensive but I trawled through eBay and found a similar product 5 rods 250mm flux coated so bought them had a practice it's pretty easy just take your time, it will weld just about any metal just use a hand held gas blow touch,look it up there is a video showing 2xSS washers it welds as strong as mig with and good finish too go for it ππ I silver solder tanks when they've got problems,as said it ain't cheap stuff Luckily I get mine free from work being a fridge man we use them to braze up compressors Our rods are called silver-flo
Post by Topman350 on Aug 14, 2018 17:09:15 GMT 1
It's cool stuff seen it on YouTube it's referred to as ssf-6 muggy weld from the USA expensive but I trawled through eBay and found a similar product 5 rods 250mm flux coated so bought them had a practice it's pretty easy just take your time, it will weld just about any metal just use a hand held gas blow touch,look it up there is a video showing 2xSS washers it welds as strong as mig with and good finish too go for it ππ I silver solder tanks when they've got problems,as said it ain't cheap stuff Luckily I get mine free from work being a fridge man we use them to braze up compressors Our rods are called silver-flo You see all the top guys use it lol ππ
Post by donkeychomp on Aug 14, 2018 22:38:17 GMT 1
I will google it! Cheers!
Post by Topman350 on Aug 15, 2018 22:36:45 GMT 1
Post by donkeychomp on Aug 15, 2018 22:49:47 GMT 1
Brilliant results but like you say it ain't cheap lol.
Post by Topman350 on Aug 15, 2018 23:17:42 GMT 1
Brilliant results but like you say it ain't cheap lol. Alex The rods I bought were Β£16:95 for 5 didn't think that was too bad as many others are pricey but yeh happy with the results...welding in my opinion isn't cheap unless you do loads of it this option is really good value ππ
Post by dusty350 on Aug 16, 2018 6:27:28 GMT 1
It looks really good Topman Does it help to have experience of welding to use it ? Dusty
Post by bazzer5115 on Aug 16, 2018 7:50:46 GMT 1
Welding and silver soldering completely different methods of joining metal. Did both pretty much every day working for 20 years in a naval dockyard. As the two surfaces being joined are not being fused together as in welding,the larger the contact area the better.(as topman has done) You can weld edge to edge and still achieve good strength,but that would be weak if silver soldered,you would have to overlap the edges. Better strengths are obtained on copper/brass/copper nickel materials than steel and stainless steel as the βbondβ is not so good. Silver soldering also known as brazing or easi-flo. Expensive because the rods are between 40%/55% silver!!
Post by Topman350 on Aug 16, 2018 8:30:38 GMT 1
It looks really good Topman Does it help to have experience of welding to use it ? Dusty Not at all Dusty but it still needs care especially when heating the metal this needs to be a dull red then add the flux from the rod you'll see it do its job and then add the rod working it into the edge area it will then melt and puddle and the flux will suck in the solder same as capillary action then leave to cool down before attempting any cleaning...I would do a couple of practice runs first you'll soon grasp it. ππ
Post by Topman350 on Aug 16, 2018 8:32:54 GMT 1
As Bazza says a fused weld is always better as this has the penitration but for this kind of work and brackets etc just the job π
Post by bazzer5115 on Aug 16, 2018 8:54:27 GMT 1
When the flux cools it can be difficult to remove as it feels hard as glass. Best way to remove the excess flux is to soak the brazed part in warm water as this dissolves the flux. Difficult with exhausts but put a wet rag around area and change a couple of times and in 15 mins the flux will be goneπ
Post by Topman350 on Aug 26, 2018 20:02:30 GMT 1
Decided to change the rear sets due to when I lowered the black ones they didn't sit right down to the angle so bought these titainium ones and made some new brackess in Ally I will silver solder theses on but will polish them first and leave an end line by the frame so when the frame gets powder coated it won't interfere with the bracket... I'll post a pic when completed π www.dropbox.com/s/7fg797fbu8wy1i8/IMG_20180831_180405.jpg?dl=0
Post by bazzer5115 on Aug 26, 2018 21:33:51 GMT 1
You canβt silver solder alloy!!!!! Baz
Post by Topman350 on Aug 26, 2018 22:59:11 GMT 1
You canβt silver solder alloy!!!!! Baz I did a test on it with mild steel and it's solid Baz?
Post by yazza54 on Aug 27, 2018 6:14:54 GMT 1
Aren't you effectively going to stick two pieces of ally together, no penetration. Needs welding surely given it'll be load bearing
Post by bazzer5115 on Aug 27, 2018 8:21:12 GMT 1
Mild steel,no problem. But not aluminium,no Try and get it adhere,it just wonβt & the melting points are very close to each other Baz
Post by Topman350 on Aug 27, 2018 9:39:50 GMT 1
Hi Baz if I get issues will use stainless I just want those bracket polished! its good fun experimenting it's how we learn also with all the great other advise that's available on here it's what make this forum cool cheers bro.
ππ
