Post by Topman350 on Apr 20, 2017 11:08:03 GMT 1
Trying to work out the position of the sub frame and seat looks to be not too difficult and suits the cradle fine 😀
Post by yazza54 on Apr 20, 2017 14:48:01 GMT 1
Today had the angle grinder and reciprocating saw out, taken off the subframe and top lugs from the swinger these I will relocate further back when I know how much length I have to play with regards the shock...Ive also measured how much I need to reduce the width of the swingarm its around 60mm its going to be a snug fit for sure 😉 Frame looks like spaghetti in comparison to that swing arm.
Post by Topman350 on Apr 20, 2017 15:04:42 GMT 1
Today had the angle grinder and reciprocating saw out, taken off the subframe and top lugs from the swinger these I will relocate further back when I know how much length I have to play with regards the shock...Ive also measured how much I need to reduce the width of the swingarm its around 60mm its going to be a snug fit for sure 😉 Frame looks like spaghetti in comparison to that swing arm. Not far wrong there chap 👍
Post by jon on Apr 22, 2017 9:29:22 GMT 1
Topman350,
Have you measured the wheelbase? It looks like it's going to be very long. With such a wide rear tyre (how wide is it?) it may feel very slow turning into corners.
Also had yon considered spreading the frame? It might be a better idea than narrowing the swingarm in order to have chain clearance between tyre and frame.
Post by Topman350 on Apr 23, 2017 17:52:23 GMT 1
Topman350, Have you measured the wheelbase? It looks like it's going to be very long. With such a wide rear tyre (how wide is it?) it may feel very slow turning into corners. Also had yon considered spreading the frame? It might be a better idea than narrowing the swingarm in order to have chain clearance between tyre and frame. Jon Hi Jon no mate not measured the wheel base im not too bothered about it...it should handle and turn ok with the right profile tyres, with the frame I didnt want the headache of more fabrication unless I have too I take on board not reducing the swinger but would rather do that than widen the frame...will see how things pan out....the rear tyre will be 160/60-17 I should only need the front sprocket to be offset by 9/10mm well hope so anyway lol 😉👍
Post by 4l04ever on Apr 23, 2017 22:19:37 GMT 1
Are you going to have to cut a step out of each side of the front of the swing arm, as just the round section machined back would still not be enough to get it into the frame?
Post by Topman350 on Apr 23, 2017 23:49:07 GMT 1
This is the original tank whats your thoughts? im thinking of narrowing the rear so it matches the seat or use a different one I have bought from a yzfr125 which is all plastic and does have a nice shape if I use that one i will sell the original....what to do???
Post by Topman350 on Apr 24, 2017 0:00:39 GMT 1
Are you going to have to cut a step out of each side of the front of the swing arm, as just the round section machined back would still not be enough to get it into the frame? I will need to take about 60mm straight out the middle 70mm in total you can notice a black line in the center of the masking tape so 25mm to the left and 35mm to the right and shave 10mm off the right side....I have to be carefull in the accuracy due to the width I need for the rear wheel and spacers etc some of the rear wheel hub will also need tweeking wish me luck lol 👍
Post by Topman350 on Apr 25, 2017 21:58:01 GMT 1
All the plastics for the rear now arrived waiting on the rear light....I've decided to use the plastic YZFR 125 tank its more suited to rhe rear. 😀👍
Post by Yogi on Apr 25, 2017 22:08:59 GMT 1
Hi mate How do you find all the trick parts so quickly Shaping up to be another stunner already
Are you up for selling the 31k tank?
Atb Matt
Post by Topman350 on Apr 25, 2017 22:46:29 GMT 1
Hi mate How do you find all the trick parts so quickly Shaping up to be another stunner already Are you up for selling the 31k tank? Atb Matt Thanks Matt I'm flat out on ebay mate lol plus I haggle for the best prices to help with the spend ive got most of the parts now so can concentrate on makeing them fit...I need exhauts clocks headlight+brackets radiator+grill and rearsets....no probs if you want the tank dont know what they are worth? Its in very good nik let me know chap 👍
Post by Topman350 on May 11, 2017 20:05:56 GMT 1
Started a little work on the swinger early this morning see pics... Got everything to make it fit just need the middle section removed 50mm and the ends trimmed will have my engineer friend Adrian to sort it for me, going to see him next Tuesday, not just the swinger i have a list of things to alter clip ons bored out to 58mm to fit the forks, stem nut to be made and spindle needs replacing rear wheel hub needs narrowing by around 8/10mm lots to do roll on next wk 😉👍 Hi, I've shared 1 photo via Photobucket for Samsung. Please click the link to view photos: share.photobucket.com/shareprofile/indexshare.php?id=Nzg2Mjg=Hi, I've shared 1 photo via Photobucket for Samsung. Please click the link to view photos: share.photobucket.com/shareprofile/indexshare.php?id=Nzg2Mjc=Hi, I've shared 1 photo via Photobucket for Samsung. Please click the link to view photos: share.photobucket.com/shareprofile/indexshare.php?id=Nzg2NDk=Hi, I've shared 1 photo via Photobucket for Samsung. Please click the link to view photos: share.photobucket.com/shareprofile/indexshare.php?id=Nzg2NDg=Hi, I've shared 1 photo via Photobucket for Samsung. Please click the link to view photos: share.photobucket.com/shareprofile/indexshare.php?id=Nzg2NTY=Hi, I've shared 1 photo via Photobucket for Samsung. Please click the link to view photos: share.photobucket.com/shareprofile/indexshare.php?id=Nzg2NTQ=Hi, I've shared 1 photo via Photobucket for Samsung. Please click the link to view photos: share.photobucket.com/shareprofile/indexshare.php?id=Nzg2NTM=Tape on the links to view pics been still having issues with photobucket 😠
Post by Topman350 on May 16, 2017 20:12:21 GMT 1
Managed to get the swingarm in today happy with the results...didnt get to see my engineer earlier he was far to busy have to wait till next wk now for the yokes 😉 Hi, I've shared 1 photo via Photobucket for Samsung. Please click the link to view photos: share.photobucket.com/shareprofile/indexshare.php?id=NzkzNjY=
Post by essexblue on May 19, 2017 21:57:23 GMT 1
My Missus would go nuts if I started putting bike bits on the kitchen worktops! Lol
Post by Topman350 on May 19, 2017 23:19:17 GMT 1
Post by Topman350 on May 31, 2017 9:04:40 GMT 1
These are the fixing points for the subframe...not done much else Mrs in hospital between work and visiting no time but she cones 1st 😀👍
Post by Topman350 on Jul 28, 2017 19:05:08 GMT 1
Post by dusty350 on Jul 28, 2017 19:56:09 GMT 1
Hi mate Sorry to hear you've both been through the wars Good to hear you are both on the up It's amazing how many "younger" people have heart attacks. When I was co responding to medical calls, it was frightening how many younger people had them. Sobering stuff. God luck to both of you for your recovery. Best wishes Dusty
Post by copper99 on Jul 28, 2017 20:00:22 GMT 1
Glad you and the good lady are on the mend ...and that your able to continue enjoying life and the bike build of course!
Post by doohanno1 on Jul 29, 2017 18:49:54 GMT 1
Jeez, thats scary stuff.. Not the heart attack but not seeing your builds.😉
Healthy recovery to you and yours...
Post by Topman350 on Jul 29, 2017 23:16:27 GMT 1
Thanks lads means a lot 😀👍 its a shame photobucket is letting us all down is there an alternative to help post pics???
Post by Topman350 on Jul 29, 2017 23:24:07 GMT 1
Hi mate Sorry to hear you've both been through the wars Good to hear you are both on the up It's amazing how many "younger" people have heart attacks. When I was co responding to medical calls, it was frightening how many younger people had them. Sobering stuff. God luck to both of you for your recovery. Best wishes Dusty Cheers Dusty we are both good and will make a full recovery it was all very scary though!!! on an important note lol what do we do about posting pics
Post by Topman350 on Jul 29, 2017 23:27:21 GMT 1
Glad you and the good lady are on the mend ...and that your able to continue enjoying life and the bike build of course! Thanks mate it was a close one so glad its over for us glad to be building again 😀👍
Post by rigga on Jul 30, 2017 5:23:38 GMT 1
Thanks lads means a lot 😀👍 its a shame photobucket is letting us all down is there an alternative to help post pics??? Hope you and the better half have a smooth recovery, how much bad luck us that for both if you to fall ill. As an alternative to photo f**kit a lot have started to use flikr, mark Hoopy has made an excellent guide on how to use it, as its not quite as intuitive as photo fukit was rdlccrazy.proboards.com/thread/40559/setting-using-flikr-pics-posts
Post by Topman350 on Jul 30, 2017 20:39:36 GMT 1
Thanks lads means a lot 😀👍 its a shame photobucket is letting us all down is there an alternative to help post pics??? Hope you and the better half have a smooth recovery, how much bad luck us that for both if you to fall ill. As an alternative to photo f**kit a lot have started to use flikr, mark Hoopy has made an excellent guide on how to use it, as its not quite as intuitive as photo fukit was rdlccrazy.proboards.com/thread/40559/setting-using-flikr-pics-postsHey thanks bro i hope thats it now for this year at least 😉👍 will defo look into that link mega 👍👍👍
Post by headcoats on Jul 30, 2017 22:05:03 GMT 1
You and your good half take it easy
Post by Topman350 on Aug 17, 2017 21:47:05 GMT 1
Trial flicker
Post by Topman350 on Aug 18, 2017 12:56:21 GMT 1
Managed to get a rolling chassis together to see how it sits also the rear shock came now tring to find the best fixing points...back wheel at the enguneers for the hub to be narrowed 😀👍
Post by Topman350 on Aug 25, 2017 19:16:46 GMT 1
Post by Topman350 on Aug 31, 2017 1:02:42 GMT 1
