Post by veg on Jul 25, 2018 9:13:24 GMT 1
Only 13.5 stone Veg ? Bloomin lightweight ! - you've gotta try harder and eat more pies  Dusty  Doughnuts not pies
Post by 1966baz on Jul 25, 2018 18:04:54 GMT 1
Why is nothing simple? Got Tz 350 pipes, the brackets in the wrong place so I fab some bolt on ones that don’t work so I have not got to fab some to be welded on then I order 4 rubber exhaust gaskets that cost me £28 and they don’t fit and the Tz exhaust springs are far too long so had to cut them done to size to fit I am at the point of smashing the feckin pipes to pieces 🤬 As I work such long hours and I’m generally away all week in hotels I can’t just pop in to the garage The hydraulic brake switches are now on back order I have lost my 1mm steel plate I bought for my clock bracket and I have just realised I haven’t ordered the temp gauge. No wonder so many projects are sold at 95% finished. Buggery bollocks Yeah , I've been there but you will get there. Often the last few fiddly jobs can take time but the end result will be way more satisfying than buying a brand new whatever from a big dealer.
Post by veg on Jul 28, 2018 15:48:28 GMT 1
 Splash guard for the power dynamo controller  Made from the remnants of my carbon fibre chainguard   Exhausts now finished including home made alloy cans Drilled and tapped so I can rebuild them   Carbon fibre bracket mount for the rear brake reservoir  First alloy bracket for mounting my kosos in the LC clock binnacle Busy day
Post by oldelsieboy on Jul 28, 2018 16:24:24 GMT 1
Splash guard for the power dynamo controller Made from the remnants of my carbon fibre chainguard  Busy day Very neat, I fitted mine in place of the OEM LC reg/rec on the rear of the fuse box. OEB
Post by veg on Aug 4, 2018 18:54:24 GMT 1
 Alloy plate made into a box to mount the cdi under the tank not yet finished  Both speedo and tacho mounts so I can fit my koso into the LC clock binnacle Productive day
Post by veg on Aug 5, 2018 16:18:13 GMT 1
Post by tipfinchy on Aug 6, 2018 23:16:07 GMT 1
clocks look good and I forgot all about wanting some of them micron bars back in the day
Post by veg on Aug 12, 2018 9:39:24 GMT 1
Post by morgy on Aug 12, 2018 10:17:44 GMT 1
I see you have a carbon headlight surround.. what light unit did you choose may i ask as i am still looking for one that will fit into the bowl without to much hassle
Post by veg on Aug 12, 2018 10:33:11 GMT 1
Std bowl in carbon from norbo and I then bought a new headlight unit from norbo.
Post by yamark on Aug 12, 2018 11:06:40 GMT 1
Great fabrication on all the brackets Veg. Clocks look very smart. This conversion will become more popular as the originals are getting rare and silly money. Someone should post up (in the how to do section) a step by step guide.
Looking forward to more progress mate
Post by veg on Aug 12, 2018 11:36:24 GMT 1
Thanks mark All i did was work out the depth i needed, the spacing of the bolts from the clocks and the spacing needed for the original bracket bolts it was a tad off but you can't see it. It actually wasn't as daunting as i thought. My fabrication skills aren't great and all i have is a pillar drill, bunch of files a jig saw and hack saw.
Post by morgy on Aug 12, 2018 11:58:18 GMT 1
Std bowl in carbon from norbo and I then bought a new headlight unit from norbo. Oh ok.. i bought one off Norbo as well.. thought it was bigger than standard one for some reason as it was much bigger than the crap aftermarket unit that came with the bike.. Do you know the size off hand? If his standard ones fit this carbon bowl i will order one..
Post by veg on Aug 12, 2018 12:18:48 GMT 1
Exact replacement for the standard one so I sold my std one and got a replacement one will measure it shortly for you.
Post by dusty350 on Aug 12, 2018 14:16:24 GMT 1
Great work on the clocks Veg  I do like the look of the modern clocks in the Lc cases. Dusty
Post by oldelsieboy on Aug 12, 2018 14:25:40 GMT 1
  Aluminium plate made into a box mounting the control unit, mounted under the tank. Lined with foam hopefully to isolate vibes with retaining strap fabricated and the screwed into place having tapped a hole   It’s all small fiddly jobs herein Is this an Ignitech CDI? OEB
Post by veg on Aug 12, 2018 14:43:53 GMT 1
Post by veg on Aug 12, 2018 14:46:59 GMT 1
Not sure Nigel bought it as a kit from Dave go on your going to tell me it is and it won’t work with the power dynamo stuff. Please please don’t piss on my parade just lie to me like a cheap whore
Post by oldelsieboy on Aug 12, 2018 15:28:37 GMT 1
Not sure Nigel bought it as a kit from Dave go on your going to tell me it is and it won’t work with the power dynamo stuff. Please please don’t piss on my parade just lie to me like a cheap whore If it didnt work Dave wouldnt have sold it to you. OEB
Post by veg on Aug 12, 2018 15:37:59 GMT 1
Still to do Fit front brake line and set up brake Fit rear stop light switch and bleed brake Fit speedo sensor Fit temp gauge Fit oil lines and connectors to inlet stubs Wire the speedo and tacho Complete the wiring to the ignition etc Fit new battery Fit a new chain Get Dave to set it up on the dyno Fit bodywork Register it and the rag the arse out of it 👍
Post by donkeychomp on Aug 12, 2018 22:05:48 GMT 1
Love this build. The attention to detail is beyond reproach.
Post by veg on Aug 12, 2018 22:29:01 GMT 1
Thanks alex I am not a particularly discerning builder but if I make something and it highlights another problem I will change it. It has taken so long because I have wanted it to be right and I don't have a huge pot of cash that I can just throw at it.
Post by donkeychomp on Aug 13, 2018 1:13:02 GMT 1
Hey mate no worries. I totally get the no cash scenario lol. What you've done (and on a limited budget) beggars belief. And that anti dive...in 3 years time it'll still work, unlike some of the manufacturers out there who's units stopped working after a few months lol.
Post by veg on Sept 5, 2018 19:13:18 GMT 1
    Spent the day fitting my new brake lines and brake switch I can only fit one to the front and not the rear not sure of the legality of it but hey ho. Spent feckin hours trying to bleed the brakes still not done for some reason they will not bleed properly. Then lock wired the front end and front and rear calipers I now Know that I have bought the wrong chain for my rear sprocket however Dave will be fitting new when she goes for setting up nearly there now.
Post by dusty350 on Sept 5, 2018 19:20:52 GMT 1
Looking great mate  That lock wiring looks a work of art !! Is it hard to do ? Dusty
Post by veg on Sept 5, 2018 19:23:57 GMT 1
I bought the kit from Venhill when I ordered my brake lines watched a video on you tube did a couple of practice runs and actually it is fairly easy to do. I love the look of it. I just think it looks right.
Post by dusty350 on Sept 5, 2018 21:16:55 GMT 1
Yea, I agree, it looks great. May try it on mine when I get a bit further ahead. Dusty
Post by Tobyjugs on Sept 5, 2018 21:52:52 GMT 1
Hi Veg i like the small back brake. Do the pads make full contact with the disc?
Post by veg on Sept 5, 2018 22:34:07 GMT 1
Yes they do just the angle of the photo, the caliper is a copy of the ap racing one from the late 80’s made by gb moto
Post by donkeychomp on Sept 6, 2018 0:24:05 GMT 1
Can you show a pic of the entire bike Veg? Love the lock wires, very trick and suits the bike I think.
