Post by Mr Kipling on Aug 29, 2017 10:46:35 GMT 1
Absolute stunner !!! Was hoping you,d pop the pic,s up after your post about trial fitting ,, that's a Proper Job !!!
Post by Tobyjugs on Aug 29, 2017 20:16:15 GMT 1
Yep that's one of the best paint schemes I've seen That's the first one i've wanted to copy
Post by veg on Aug 29, 2017 21:14:02 GMT 1
Yep that's one of the best paint schemes I've seen That's the first one i've wanted to copy You aren't the first. Wish I hadn't bloody posted it now 😀
Post by paulincayman on Aug 29, 2017 22:43:00 GMT 1
Great work Veg, you set a very high bar!
Post by veg on Sept 9, 2017 9:54:34 GMT 1
Won't be many updates coming as she is going off for mechanical anti dive to be fabricated shortly. All I need now is to find a pair of Frank Thomas paddock boots, and a Yamaha paddock jacket
Post by veg on Nov 13, 2017 16:58:55 GMT 1
Post by veg on Nov 13, 2017 17:07:35 GMT 1
SO the rear coolant pipe runs differently looked at getting a one off hose prohibitively expensive managed to find a hose that has a flexible core, then needed to grind away the cases where the expansion chambers sit but had to chop away my newly painted frame as well. The upper coolant hose to radiator also needed to be flexible due to how it runs obviously underneath a frame cross brace. Fitted up the expansion chambers ex Yamaha France early Tz 350 but they interfere with the main stand bracket that I didn’t remove but now will need to. Then got to fit oil feed to inlet rubbers, get the spannies altered because obviously the mounts are not in the right place at the back. Fit the wiring mount the new cdi and controller make a mounting bracket to run electronic speedo and tacho that fit in the standard clock surrounds ala true Brit and mutts nutts. Get it up to Dave for setting up then over to NK for the mechanical anti dive
Post by bezzer on Nov 21, 2017 20:37:11 GMT 1
Stunning build Veg, fabulous interpretation of the bike yamaha SHOULD have built!.
Post by veg on Nov 27, 2017 19:23:19 GMT 1
Speedo arrived awaits the tacho then onto fitting them in the std binnacle having nicked the idea from Dave and Dave
Post by dusty350 on Nov 27, 2017 19:29:57 GMT 1
Hi Veg Looking good mate. I would be interested in seeing the process for fitting those clocks into the Lc cases. I think they look great on Mutt's and Trubrits bikes Dusty
Post by veg on Nov 27, 2017 19:35:16 GMT 1
Dusty once I have the tacho I am going to do my best to fabricate the fitting for the standard binnacle I am planning to record it so hopefully others can learn from what no doubt will be my mistakes.
Post by loudpipes on Nov 27, 2017 19:37:33 GMT 1
Im on with this at the moment its a bit fiddly shame reset/adjuster buttons are on the bottom side otherwise they look great.
Post by jakethepeg007 on Nov 27, 2017 19:48:39 GMT 1
Looking really nice, keep up the good work👍🏻👍🏻
Got out to say I love the paint / carbon mix😄
Post by veg on Nov 27, 2017 19:51:07 GMT 1
Im on with this at the moment its a bit fiddly shame reset/adjuster buttons are on the bottom side otherwise they look great. How you getting on with it? I didn’t realise the setting buttons were located there until I bought them hey ho.
Post by dereckerick on Mar 3, 2018 10:54:15 GMT 1
Dusty once I have the tacho I am going to do my best to fabricate the fitting for the standard binnacle I am planning to record it so hopefully others can learn from what no doubt will be my mistakes. Did you record the fitting of the Koso gauges, I’d be interested to see the process 👍
Post by veg on May 29, 2018 11:06:02 GMT 1
Just finally got a picture not collected it yet
Post by Tobyjugs on May 29, 2018 19:11:40 GMT 1
That looks well made. Is it the same on both sides. I'd like to see this in the flesh
Post by veg on May 29, 2018 20:32:39 GMT 1
Single 320mm disc same as the old seven up LC from performance bikes back in the day
Post by donkeychomp on May 29, 2018 21:35:50 GMT 1
Bloody heck Veg that is the pups nuts and then some. Can't wait to see a pic of the bike finished!
Post by veg on Jun 2, 2018 14:19:58 GMT 1
Just collected it from NK I do sometimes get a little frustrated with Nigel because I’m an impatient git but the quality is amazing I mean speechless amazing it’s now back in the garage just got to do a few small jobs then it’s off to Dave for final fettling
Post by headcoats on Jun 2, 2018 16:28:59 GMT 1
Dusty once I have the tacho I am going to do my best to fabricate the fitting for the standard binnacle I am planning to record it so hopefully others can learn from what no doubt will be my mistakes. Looking forward to this Veggy :-)
Don't forget !
Post by veg on Jun 2, 2018 17:05:10 GMT 1
It’s next on the list 😀
Post by Mr Kipling on Jun 2, 2018 19:11:47 GMT 1
Just collected it from NK I do sometimes get a little frustrated with Nigel because I’m an impatient git but the quality is amazing I mean speechless amazing it’s now back in the garage just got to do a few small jobs then it’s off to Dave for final fettling Agreed Nigel sure makes u wait but the end result is well worth it !!! Looking superb now Veg , looking forward to the Final Fit !!!!
Post by dusty350 on Jun 2, 2018 19:19:14 GMT 1
Great work - that looks soo good Wont see too many set ups like that nowadays. You must have the finish line in sight now Veg ? Dusty
Post by veg on Jun 2, 2018 21:51:26 GMT 1
Thanks guys it’s been a long run and I have changed my mind constantly I’m hoping to have it done sooner rather than later. I’m going all out now. Will keep you updated.
Post by donkeychomp on Jun 2, 2018 22:04:04 GMT 1
I have NEVER seen mechanical anti dive on any bike. Proper job mate!
Post by Mr Kipling on Jun 7, 2018 23:01:35 GMT 1
I have NEVER seen mechanical anti dive on any bike. Proper job mate! Alex Not taking anything away from Veg or mean to hijack the thread in anyway as its proper one off old school and his is a beautiful build , he got it made in retro tribute of this one in this magazine I still have it here if fancy a read..... If I ever do an LC I,d follow Veg,s lead an go along the anti dive route too , Proper Job !!! now without further ado back to the build ...
Post by veg on Jun 8, 2018 8:37:12 GMT 1
Absolutely I was massively influenced by the 7up bike and met the owner many years ago when he had a katana for sale. My favourite part of performance bikes was always the readers special or the supplements they used to attach. This is my homage to them and what I would have built back in the day.
Post by donkeychomp on Jun 8, 2018 20:58:27 GMT 1
I have that mag!
Post by veg on Jun 20, 2018 16:34:39 GMT 1
Problem Knackered silencers that are hard to get hold of, and expensive and as they are on a set of hand made pipes none of the holes line up exactly (ex Yamaha France tz350 pipes bronze welded). Solution Aluminium tube eBay £8 and make my own v happy
