Post by yamark on Dec 9, 2016 21:08:36 GMT 1
Looking superb Veg Great work
Post by steve h on Dec 9, 2016 22:40:51 GMT 1
Put the Jack the right way up veg!
Post by veg on Dec 10, 2016 3:39:55 GMT 1
To a blind man it is
Post by veg on Dec 10, 2016 3:40:50 GMT 1
Looking superb Veg Great work Compared to yours it's a bolt together but thank you
Post by dusty350 on Dec 10, 2016 8:59:27 GMT 1
Hi mate Looking good - I love this stage of the build process Regards a painter - Mark Cordwell cant be far from you - he is in Derbyshire, and has a very good rep and is a nice fella too. I saw a used paint set on ebay that he had painted - spoke to him on the phone at length, and I ended up with a new Norbo tank and new panels that he is spraying this week. It sort of escalated but I know it was the right thing to do - even my missus agreed !! I am supplying the front Rgv guard - was gonna give him the carbon one but he said that after time, the carbon weave may bleed through the paint, so I will supply the one off the 385. Just something to consider with the carbon. I' sure if you speak to him he can explain the options. Good luck with it. Dusty
Post by veg on Dec 11, 2016 17:25:49 GMT 1
Thanks dusty never heard of that before will bear it in mind. Be interested to see the result . My paint job is going to be a little different to standard
Post by veg on Dec 22, 2016 20:11:39 GMT 1
Still waiting for my front and rear end to be returned so not content with 1 build today I bought an lc2 frame and will start collecting bits for a hybrid lc2 banshee. No real rush on this one it will be an as and when build
Post by dusty350 on Dec 22, 2016 20:22:50 GMT 1
Sounds good Veg. Forum member "Mouse" is gonna do the same. I think the Lc2 will look great with the right mods. I did an F2 based hybrid and found a 3 spoke wheel from a Tzr125 Belgarda bolted into a Ypvs arm easily, and the forks went straight in too with a 5mm spacer under the bottom bearing, so if you are thinking of uprating the running gear, the Belgarda is a cheaper option than Rgv parts. Good luck Dusty
Post by icarus001 on Dec 23, 2016 4:25:27 GMT 1
Sounds good Veg. Forum member "Mouse" is gonna do the same. I think the Lc2 will look great with the right mods. I did an F2 based hybrid and found a 3 spoke wheel from a Tzr125 Belgarda bolted into a Ypvs arm easily, and the forks went straight in too with a 5mm spacer under the bottom bearing, so if you are thinking of uprating the running gear, the Belgarda is a cheaper option than Rgv parts. Good luck Dusty The Belgarda wheels are about as versatile as it gets, they slot straight into an LC (with standard swingarm) with a slight mod to spacers. If ever they come up cheap it's worth grabbing a set just to keep for the future in case you ever want to build anything.
Post by dusty350 on Dec 24, 2016 13:30:19 GMT 1
This is a Belgarda front end and rear wheel in a Ypvs; Dusty
Post by veg on Dec 24, 2016 16:07:32 GMT 1
Thanks dusty looks good I'm watching a set of fzr400 front n rear end
Post by dusty350 on Dec 24, 2016 16:43:47 GMT 1
Hi Veg The Fzr gear makes for a tried and rested conversion for sure The only thing I didn't like about the Belgarda parts was the single front disc. Don't get me wrong, that single disc and caliper are more than man enough for stopping the bike, but I much prefer the twin discs from a "looks" point of view - just seems more balanced and purposeful imo. Good luck with whatever you decide to use Dusty
Post by oldelsieboy on Dec 24, 2016 16:56:42 GMT 1
Thanks dusty looks good I'm watching a set of fzr400 front n rear end Aren't FZR400 rear wheels 18"? OEB
Post by veg on Dec 24, 2016 17:00:48 GMT 1
Fz maybe I think fzr are 17 but will check
Post by oldelsieboy on Dec 24, 2016 17:07:53 GMT 1
Fz maybe I think fzr are 17 but will check IIRC only the FZR400 3TJ model was fitted with a 17" rear wheel OEB
Post by Tobyjugs on Dec 24, 2016 23:27:58 GMT 1
Hi veg i thought you were after classic rims. Another rim which is easy to fit is the SZR from Yamaha there is lots of meat on the sprocket carrier for machining purposes. In my opinion the only draw back is the skinny wheel spindle. I think its the same diameter as a 4LO spindle. You can then fit a 150 tyre.
Post by veg on Dec 25, 2016 0:22:45 GMT 1
Ha for my 4lo I am and I'm sorted but the 31k is different
Post by icarus001 on Dec 25, 2016 7:34:20 GMT 1
Belgarda wheels in my LC...
Post by Tobyjugs on Dec 25, 2016 10:23:25 GMT 1
Belgarda wheels in my LC... Nice bike icarus001 i like this syle bike.
Post by 4l04ever on Dec 25, 2016 14:20:15 GMT 1
Belgarda wheels in my LC... That rear wheel looks more like a 4FL wheel as the spokes are thinner on 4FL than 4DL (Belgarda). The 4DL wheels are Brembo wheels. I have both. The 4FL are lighter and look more OEM. I have a 4FL rear wheel in my LC :-) Front wheel is a TZR125 3PC wheel.
Post by 4l04ever on Dec 25, 2016 14:33:40 GMT 1
Fz maybe I think fzr are 17 but will check IIRC only the FZR400 3TJ model was fitted with a 17" rear wheel OEB 17" by 4.5". Same Rim size as 3XV, but bigger hub.
Post by icarus001 on Dec 25, 2016 15:01:27 GMT 1
That rear wheel looks more like a 4FL wheel as the spokes are thinner on 4FL than 4DL (Belgarda). The 4DL wheels are Brembo wheels. It's a Brembo wheel for certain, I'm told it was from a Belgarda, but I'm not an expert so didn't really look into it that hard. It definitely has Brembo on the wheel though.
Post by veg on Dec 25, 2016 16:33:46 GMT 1
Fz maybe I think fzr are 17 but will check IIRC only the FZR400 3TJ model was fitted with a 17" rear wheel OEB 3 guesses who was right again 😀. Thanks for the heads up
Post by dusty350 on Dec 25, 2016 16:34:46 GMT 1
Hi That rear wheel is definitely different to the one I used; Dusty
Post by icarus001 on Dec 25, 2016 20:57:03 GMT 1
Yeah it certainly looks like wider spokes. I'm not at home so I can't check, but I could have sworn it says Brembo on the wheels.
I thought they were the same wheels as my TZR-3XV and I'm sure they say Brembo on as well??
I also seem to remember they say Yamaha on too, or is my mind playing tricks?
Post by veg on Dec 25, 2016 21:20:32 GMT 1
My old 900ss and 851 both had brembo cast wheels
Post by 4l04ever on Dec 25, 2016 23:37:45 GMT 1
3XV wheels are not Brembo ones... The ones on Dusty's bike look like the 4DL Brembo ones I have.
Post by veg on Mar 3, 2017 16:43:45 GMT 1
Post by veg on Mar 3, 2017 16:44:19 GMT 1
Just back from limbers some £1000 lighter but v happy the plan now is to get swing arm satin black coated, wheels crack tested and painted, dry build swing arm and forks etc new tyres, strip the motor and get cases vapour cleaned etc etc etc got my rear sets on order with NK. He may have taken 4 months not the 2 weeks he first quoted but the quality is amazing. V happy
Post by dusty350 on Mar 3, 2017 18:59:54 GMT 1
Hi mate That looks awesome Love the wheels - wont see too many of them in an Lc. NK has done a great job - the sprocket spacer looks awesome- a long wait but worth it. Dusty
