Post by veg on Apr 6, 2019 13:34:25 GMT 1
Thanks dusty Yes I know itβs a popular scheme, I am now planning my next build which I am hoping will be a flat tracker 1970βs style either air or lc not sure just yet depends on availability of bits got to pick up the frame from Norbo to start with. Thanks again for the kick up the arse been times when I could thrown it in the skip π
Post by Yogi on Apr 6, 2019 15:15:09 GMT 1
Very nice mate,you must be over the moon
Post by veg on Apr 6, 2019 16:00:49 GMT 1
I am Matt really really pleased. π
Post by philmill on Apr 6, 2019 16:22:43 GMT 1
Looks really good, I do like that colour scheme. You should be proud, lovely bike.
Phil
Post by donkeychomp on Apr 6, 2019 22:32:44 GMT 1
Feckin' superb. Love all the thought that has gone into every single part. Paint, anti dive, wheels it all just gels like no other bike.
I doff my hat sir.
Post by bid on Apr 6, 2019 23:37:00 GMT 1
awesome just YESSS, πππππ€ͺ
Post by bezzer on Apr 7, 2019 11:28:59 GMT 1
Tim, Many congratulations on such a beautifully turned out bike.
You have built your vision, and despite the teething troubles, youβll get it sorted and useable. IMHO the mechanical anti-dive is a work of art mate, you can be justifiably proud of what youβve created overall.
Stick with it. bezzer.
Post by midlifecrisisrd on Apr 7, 2019 15:11:59 GMT 1
Looks ace, love the paint
Post by Tobyjugs on Apr 7, 2019 15:25:50 GMT 1
Absolutely gorgeous bike Tim. One of the best I've seen and the standards are high on this forum.
What size master cylinder are you using for the front brake? and how does it feel?
Post by muttsnuts on Apr 8, 2019 18:48:23 GMT 1
and I've nearly done the design for your new pipes without the need to take your engine apart to map it, but I will need to take the exhausts off to verify if the barrels are early 4 transfer ports, or later 6 transfer ports, unless you happen to know, if you do then I can finalise the design while I am laid up
Post by muttsnuts on Apr 8, 2019 18:49:27 GMT 1
BTW - change that bloody side stand, it frightens me to death everytime I put the bike on it, I had a piece of wood tied to it in the end as I kept thinking it was going to fall over !
Post by veg on Apr 8, 2019 18:51:08 GMT 1
Thanks tony itβs been a long road but well worth it. Dave glad to see your ok π. I will check on pics and paperwork and see if I can find out. No stress though.
Post by oldelsieboy on Apr 9, 2019 18:06:18 GMT 1
Dave glad to see your ok π. I will check on pics and paperwork and see if I can find out. No stress though. The numbers cast on the rear of the cylinders will identify which type you have, 409 probably. OEB
Post by veg on Apr 9, 2019 18:29:01 GMT 1
You are a star thanks Nigel, so does 409 refer to 4 port?
Post by veg on Apr 9, 2019 18:33:00 GMT 1
Its 40900 so i will try and find out whether that's a 4 or 6 port. Thanks
Post by jspooner on Apr 9, 2019 18:39:16 GMT 1
Dave glad to see your ok π. I will check on pics and paperwork and see if I can find out. No stress though. The numbers cast on the rear of the cylinders will identify which type you have, 409 probably. OEB I think its the numbers after the 409 that will determine what cylinder it is.
Post by veg on Apr 9, 2019 18:42:06 GMT 1
Just done some research the 40900 refers to early tz700 barrels so it will be a 4 port then.
Post by Tobyjugs on Apr 9, 2019 20:36:34 GMT 1
A cheap endoscope inserted through the plug hole will definately clear up any confusion on how many ports
Post by oldbritguy on Apr 9, 2019 23:13:49 GMT 1
Superb Veg. A work of art and a true special indeed. I'm sure when Dave is back up to speed and sorts out a bespoke exhaust system for you, that will do it..........NOT!!!!!! I am sure you will find other things to adapt/change/ evolve as with all specials, and this forum demonstrates this constantly. Need to see if that paint scheme can be incorporated onto a YPVS and look as good too Well done mate.
Post by veg on Apr 10, 2019 9:09:05 GMT 1
Long term I think itβs going to have 38 mm marzzochi forks ( the forks to have circa 1985) 5 spoke campagnolo/marchessini wheels ala rg500 twin tz discs and twin anti dive unless of course I sell it and start again π
Post by donkeychomp on Apr 10, 2019 22:11:09 GMT 1
Now that I would like to see. DO IT!  (Please) Alex
Post by Tobyjugs on May 24, 2020 10:49:23 GMT 1
The paintwork on this bike is definitely my favourite.
Post by veg on May 24, 2020 10:59:28 GMT 1
Thanks Tony will be a similar paint job on the flat tracker. Bike has changed a little as well ditched the ace bars and got a pro am fairing which may or may not make it on there. The Bakker would look good in a similar scheme. π
Post by stusco on May 24, 2020 11:25:36 GMT 1
Shame about the ace bars i like them
Post by veg on May 24, 2020 11:26:59 GMT 1
So did I stu then tried riding the feckin thing, Iβm 50 not 20 π
Post by flames on Jun 21, 2020 22:58:45 GMT 1
That sir, is a work of art. 30kg is a hell of weight saving to boot. That paint scheme is spot on.
Post by veg on Jun 21, 2020 23:09:41 GMT 1
Thanks very much itβs my baby, spent a long long time designing the paint job sheβs not finished and constantly evolving.
Post by Yogi on Aug 17, 2020 20:22:58 GMT 1
