Post by veg on Sept 10, 2016 17:14:16 GMT 1
From this To this
Post by veg on Sept 10, 2016 17:15:56 GMT 1
With more stuff done more money spent Just to pretend I'm 18 again
Post by veg on Sept 10, 2016 19:00:30 GMT 1
Frame and ancillary painted not powder coated, got to do the satin black parts next top yoke horns switchgear etc Not going for a standard concourse rebuild want it to look like what I would have done had I had the dosh 30 yrs ago Undecided on paint scheme thinking Akai White sheene scheme, will be using the 4lo motor but will get it blueprinted and tuned, wheels possibly astralites rear sets from NK , just a work in progress
Post by KevtheRev on Sept 10, 2016 20:11:35 GMT 1
Are those Allspeeds Veg ?
Post by veg on Sept 10, 2016 20:15:25 GMT 1
JL copies bud brand new but bought used half the price of gibsons but stainless not chromed
Post by Topman350 on Sept 11, 2016 9:11:26 GMT 1
Will be a nice bike mate had allspeeds on mine in the 80's small can though nice crisp sound :-)
Post by stusco on Sept 11, 2016 14:48:42 GMT 1
I like the exhaust hanger
Post by paulincayman on Sept 24, 2016 12:58:21 GMT 1
Nice project...What swing arm is that?. I have a 4l0, putting f2 forks on, keeping original clocks and wheels, not sure what to do with the back end.. Cheers
Post by veg on Sept 24, 2016 18:24:08 GMT 1
Metmachex original got lucky thanks to Dave (Trubrit) I'm still messing with ideas about wheels got my caliper and master cylinder upgrade. Bought grimeca copies of ap Lockheed brakes
Post by paulincayman on Sept 24, 2016 18:40:25 GMT 1
Very nice too.. I've got triumph 4 pots on the way, looking forward to seeing yours done.
Post by TZ750D on Oct 5, 2016 5:42:27 GMT 1
Very nice work - I'm new here but what's the largest tire you can fit in that metmachex swing arm? Love the astralites and lookheed lookalikes - takes me back!
Post by veg on Oct 5, 2016 6:29:52 GMT 1
Change of plan, i am going for wire wheels with gold rims, having spoken to Trubrit helped me decide. I did consider Campags but at £1800 plus fittings I had to have a word with myself. I think it is a 130 that can just fit the swing arm. Just waiting for bits to come back from Nick Chambers. Got my AP lockheed look a like Grimecas and master cylinder, got my Gully seat and a new White Power rear shock.TDR rear hub on its way and once I have a front hub its off for wheels to be made to fit then off for lacing up. New TZ discs and adapter plates for the callipers. I don't have the facilities to mill or turn so I am reliant on others to do this.
Post by icarus001 on Oct 6, 2016 6:37:40 GMT 1
I was going to put spoked wheels on my LC, I had a look at Kineo, but I don't think they do them in sizes that would fit properly. I'm also struggling to get TDR hubs as you know, they're pretty thin on the ground.
Post by veg on Oct 6, 2016 7:44:09 GMT 1
I spoke to Talon to see if they would make a set of one off bespoke hubs, they no longer do them and the only hub that is a twin disc is for a KTM 990 which will be too wide. Struggling to find someone to make them.If i get lucky I will let you know.
Post by icarus001 on Oct 6, 2016 8:17:28 GMT 1
I spoke to Talon to see if they would make a set of one off bespoke hubs, they no longer do them and the only hub that is a twin disc is for a KTM 990 which will be too wide. Struggling to find someone to make them.If i get lucky I will let you know. Thanks. Bespoke hubs would be silly money though, my old KTM Talon wheels cost me loads (about £600 if I remember correctly) and that was almost 10yrs ago. My 350LC has a TDR125R front wheel on, with a single disk and TZR2502ma caliper, it's easily powerful enough, so you could get away with single disk no problem. I've asked my mate in Japan to have a look around for me, when they come up there they're normally really cheap, a full wheel is normally about £50, but there are none about at the moment.
Post by icarus001 on Oct 6, 2016 8:35:42 GMT 1
Post by Tobyjugs on Oct 6, 2016 10:25:12 GMT 1
I spoke to Talon to see if they would make a set of one off bespoke hubs, they no longer do them and the only hub that is a twin disc is for a KTM 990 which will be too wide. Struggling to find someone to make them.If i get lucky I will let you know. What about BMW hubs, a lot of the cafe-racer lads use these.
Post by veg on Oct 6, 2016 10:31:11 GMT 1
They do, I am trying to retain Yam parts were possible as I am fitting tz discs, if I can't get a suitable one i will look at other makes, the BMW hubs look quite a bit bigger than yam ones i am also trying to keep weight down. ideally It would be a tz hub as I am going to fit an electronic speedo and tacho but in the lc clock surrounds.
Post by veg on Oct 11, 2016 18:44:57 GMT 1
So managed to get an xs650 front hub, and the TDR250 rear hub has arrived but obviously it is too wide for my metmachex swinging arm, so now i need to speak to Nigel Kimber about what can be done and whether I get him to build me a one off or he adapts the metmachex which I thin is unlikely, when he gets back from his holiday. Never was going to be easy.
Post by dusty350 on Oct 11, 2016 19:54:37 GMT 1
Post by veg on Oct 11, 2016 20:17:41 GMT 1
Thanks dusty really after a disc hub.
Post by dusty350 on Oct 11, 2016 20:32:14 GMT 1
Ah, ok, I will keep an eye out Dusty
Post by jon on Oct 12, 2016 8:10:34 GMT 1
Veg, just a thought, but why don't you get Nigel to modify an arm for you rather than build from scratch or modify the Metmachex?
Sell the Metmachex to fund it (as you've hinted in another thread).
He did a 2MA one for me. The wider TZR wheel with 3.5 rim fits fine.
I believe the TDR to be the same swingarm?
Everything would slip straight in and line up, including caliper and bracket with the disk, rear wheel spindle etc.
Post by veg on Oct 12, 2016 8:23:06 GMT 1
Good thought matey. I am just waiting for him to return from holiday and will pop round he is only 25 minutes away from me so will pick his brain. Thanks for all the advice boys much appreciated.
Post by richclare on Oct 12, 2016 19:00:59 GMT 1
Hi Veg,
Would be interested to buy the metmachex if you decide to sell it......
Rich
Post by veg on Nov 3, 2016 17:07:26 GMT 1
All change again. Met Nigel Kimber today to decide on the direction of my build and ended up buying some wheels from him. Going to use my metmachex swing arm, and go single disc so will be selling some more parts again soon. Have also sent off my Guiliara seat to have a cover made. The company doing it are borrowing the seat as a pattern to start offering new covers. Waiting on the return of other parts from RD bitz so I can finally start building the bike.
Post by veg on Dec 9, 2016 17:50:22 GMT 1
Post by veg on Dec 9, 2016 17:53:44 GMT 1
So spent past few days building and cleaning, fitted new or refurbed everything , ordered more stuff as well as arranging my motor to be built by Mick abbey as well as my pipes thanks to Yamark for that, trying to source a good painter, and still waiting for NK to finish my wheel fitment and get my swing arm and wheels in place progressing nicely.
Post by ellasae on Dec 9, 2016 18:52:40 GMT 1
Looking good veg , it appears Santa came a little early this year..
Post by veg on Dec 9, 2016 19:32:19 GMT 1
Looking good veg , it appears Santa came a little early this year.. Im hoping he will keep giving until spring time
