Post by noonster on Jun 27, 2016 20:54:13 GMT 1
When i turn the ignition switch on.Turn lights on with switch. Headlight comes on,but not rear light or clock lights. Brake light works.
When i turn ignition switch to second position on ignition switch,rear light works,lights in clock light up.
infact everything works perfect.
But i would have thought this should work soon as the ignition is switched on and not on second turn of ignition switch. thought this should have been just for a parking light.
Any ideas please.
Post by muttsnuts on Jun 28, 2016 20:33:22 GMT 1
yes, summat up with that, could be one of 2 things
1. wrong ignition switch (has a D model one fitted instead of a E/F which are different) 2. Wired incorrectly in the headlight (most likely candidate)
I could sort it for you if you could get it across to me
Post by noonster on Jun 28, 2016 20:40:47 GMT 1
Hi Dave The bike a fews weeks of yet and it would be nice to finally meet you and thank you personally for sorting my carb issue on lc. New bike (not as many issues,fingers crossed)
Hopefully take you up on that dave.
Give you a ring to message next month.
Post by muttsnuts on Jun 28, 2016 20:48:06 GMT 1
ok, no problem, keep me posted
