Post by bezzer on May 31, 2016 9:04:01 GMT 1
Hi folks,
Can anyone advise me of any pitfalls to note whilst carrying out refurbisment of my clockset?. I'm hoping to fit new clock face decals, and paint the needles, so any advice (especially on the best paint for the needles) and opening up the clocks would be very much appreciated.
Post by rdrob on May 31, 2016 9:17:35 GMT 1
Dont trying cleaning the wheels with the numbers that spin around I did that and made them worse.
Post by sp885 on May 31, 2016 9:44:17 GMT 1
Buy the new clock dials from Simon Wells instead of the decals, more money but a lot better IMHO  ?
Post by bezzer on May 31, 2016 10:02:21 GMT 1
Thanks chaps, Any input very much appreciated. SP, do you have contact details for Simon?
Post by dusty350 on May 31, 2016 11:12:58 GMT 1
Post by foxyjohn on May 31, 2016 11:37:53 GMT 1
Buy the new clock dials from Simon Wells instead of the decals, more money but a lot better IMHO  ? + 1 on that
Post by oldelsieboy on May 31, 2016 11:50:58 GMT 1
Post by bezzer on May 31, 2016 11:56:30 GMT 1
Thanks Dusty, It's really great to receive such useful advice, and can I also add what a fantastic job you have done rebuilding your bike - looks amazing!.
Post by dusty350 on May 31, 2016 12:22:57 GMT 1
Hi You're welcome  If I was doing it again I would buy those dial faces that OEB has linked for you. Easier than sticky backed faces. The most delicate part of the job is prising the needles off - be really gentle with them as they can break easily, but apart from that it's fairly straight forward. You'll be glad you did it when they are reassembled  Dusty
Post by stusco on May 31, 2016 15:36:57 GMT 1
Don't get white decals the shadows shine through in the dark also you can buy new needles off an xt 500
Post by shunter on May 31, 2016 22:34:58 GMT 1
I did mine and dustys advice was invaluable,my needle flew off and broke when it landed as I did it outside in the summer. I found out the early XT 500 needle is the same and still available I got them on eBay I think they were about £10 each.
Post by rostrumorhospital on May 31, 2016 22:58:08 GMT 1
I fitted 2 new needles as i broke one when removing, was very stuburn to remove, almost impossible without damaging in my opinion althought i did see in one of the threads a small tool to draw the needle off, this would be the way to go if your using the existing needles, the XT 500 needle is identical, these are what i used and just sprayed the temp pointer with a spray can a similar orange.
Post by shaunthe2nd on May 31, 2016 23:01:49 GMT 1
I suggest removing the needle with the clock inside a carrier bag as they do fly when they ping off, and i had one snap in half when it landed the other side of the kitchen!
Also use electricians tape on the jaws of your pliers when closing the clock rim up after opening to minimise marks on the clock.
And... just take your time, it's all quite straight forward I think. Good luck.
Post by muttsnuts on Jun 1, 2016 10:39:14 GMT 1
Simon offers a fitting service for £30 for the pair if you buy the backing plates off him (£45), for the sake of £75 if your not sure I'd just get Simon to do them for you, job done !
Post by wangwang on Jun 1, 2016 21:19:33 GMT 1
Simon offers a fitting service for £30 for the pair if you buy the backing plates off him (£45), for the sake of £75 if your not sure I'd just get Simon to do them for you, job done ! Ditto, Simon did a great job with mine.
Post by shunter on Jun 2, 2016 20:18:38 GMT 1
I wish I had known that,it's a no brainer that is the way to go.
Post by motorbiker on Jan 1, 2017 23:12:04 GMT 1
Hello Anyone knows where can I find the rubber cover for the trip reset on a 31k ypvs 83 bike?
expat
Post by expat on Jan 18, 2021 5:30:56 GMT 1
Does anyone have current contact info for Simon Wells? Is he still making the replacement clock faces? Also any reccomendations for needle paint or where to source replacements?
Post by jonw on Jan 18, 2021 6:45:47 GMT 1
Kateannwells on ebay, Simon5 on here i think and also he is Simon Wells on Fb.
Post by Shytalk on Jan 18, 2021 8:35:34 GMT 1
Does anyone have current contact info for Simon Wells? Is he still making the replacement clock faces? Also any reccomendations for needle paint or where to source replacements? If you read the whole post you’ll see the answers to your questions.
Post by Shytalk on Jan 18, 2021 8:37:56 GMT 1
Hello Anyone knows where can I find the rubber cover for the trip reset on a 31k ypvs 83 bike? The rubber boot around the reset button isn’t available as a separate part, best sourced from a damaged top cover. I might have a good one in my spares box.
Post by shaunthe2nd on Jan 18, 2021 9:05:55 GMT 1
^^^ 4 years is a long search!
Post by dusty350 on Jan 18, 2021 21:07:21 GMT 1
You can use a blind rubber plug for the reset button boot. I normally get an assortment from an autojumble (remember them !), and make a small hole just big enough for the reset shaft to pass through. They have a grooved outer edge so it fits either side of the casing of the instrument. Dusty
Gee
Post by Gee on Jan 18, 2021 22:33:48 GMT 1
I sent mine off to shaunthe2nd on here to do. Top job.
