Post by ellasae on May 20, 2016 15:37:31 GMT 1
After 18 months of work on and off its finally ready for the mot , I just hope the tester is a bit deaf as those TSA pipes aren't the quietest pipes I've ever had
Post by ellasae on May 20, 2016 17:12:21 GMT 1
This is the first time that this bike has seen daylight for over 7 years It's had a complete engine rebuild along the way so it'll need running in next, what's people's thoughts on this now ? The last time I ran in an lc was around 1986 , I seem to remember getting bored after about half an hour and just ragging it! To be fair it didn't seem to suffer any ill effects but I think I may show a little more restraint this time...
Post by arrow on May 20, 2016 17:21:14 GMT 1
Very nice. I bet that stops good too!
Post by ellasae on May 20, 2016 19:11:53 GMT 1
The full r1 brake system is probably a little ott , it does have a beautiful , better than new oil pump as well ........
Post by rigga on May 21, 2016 13:18:11 GMT 1
That's lovely
Post by ellasae on May 21, 2016 14:30:21 GMT 1
Thanks Rigga given the quality of your build that's nice to hear
Post by Yogi on May 21, 2016 14:36:10 GMT 1
Nice,,,and subtle Is the rear tyre oversize it looks big Matt
Post by yamman1066 on May 21, 2016 16:11:36 GMT 1
rear tyre looks like a 4.00
Post by ellasae on May 21, 2016 16:13:10 GMT 1
Thanks Matt, the tyre does look big in the pic but it's a 110 / 90 Avon , perhaps the sv650 Shock lifting the back end a little makes it look bigger in the pick To be honest when it's next to my R1 they look like a kids bicycle tyres
David
Post by unrealedd on May 24, 2016 20:11:02 GMT 1
Nice build and love the colour your right about the TSA pipes the do ring out don't they. So how tuned is this motor?
Post by ellasae on May 24, 2016 20:46:19 GMT 1
The motor is stock , but stripped and rebuilt with rebore , new pistons and rings , new oil seals , arrow oil pump and a rebuilt crank , it's got banshee coils , carbon reeds in flowed cages on 6mm spacers , pwk 28 carbs and no lid on the air filter and of course the tsa pipes It should go ok once it's run in I hope as this set up is based on muttsnutts advice on here , I'd reckon on mid fifties hp once set up on the dyno
David
Post by 4l04ever on May 25, 2016 17:14:14 GMT 1
I would lose the spacers.... Get your squish and volume setup correctly and a Zeel or Ignitech ignition. A little porting and 55+ is possible :-)
My LC has porting, squish/volumes done, zeeltronic ignition, YPVS reeds and inlet rubbers, standard 4L0 carbs, modified airbox, TSA pies, Thundercat radiator, and makes 57hp on a Dyna Pro dyno.
My Track LC has standard porting, squish and volumes done, 4L0 reed blocks with fibre reeds, Zeeltronic ignition, 31K carbs, Micron Exhausts, and makes 48hp.
Both bikes were setup on the dyno.
These will give you some ideas as to what power various mods can make.
Good luck with your project and keep up the modifying :-)
Post by 1966baz on May 25, 2016 19:26:31 GMT 1
Very tasteful LC. Enjoy it mate.
Post by ellasae on May 26, 2016 10:49:19 GMT 1
Thanks guys ,
Once the motor is run in i'll get it up on the dyno and decide where to go from there , after the battle i had getting the PWK 's into the carb rubbers with the reed spacers fitted i'm reluctant to remove them!
Post by marsbar350 on May 26, 2016 17:13:22 GMT 1
nice hooning bike you got regarding the rubbers on the pwks.i leave them clamped on and just remove from the airbox luckily the don't have to come off too often
