Post by lovely on Jun 9, 2008 19:51:32 GMT 1
tried to get the rubber bungs out of my mark 2 125. drained em . tried braking and popping them out. finally screwed into them and tried to draw them out. no joy... any ideas anyone. dont matter that they are knackered. as replacing when i fill the forks again.
Post by mellow on Jun 9, 2008 22:15:39 GMT 1
rubber bungs as in top of forks should come str8 out.........its the caps under the bungs which usually rust in..n they are a bitch to get out once u got the circlip thingy out brute force m8 ;D
Post by lovely on Jun 10, 2008 19:25:36 GMT 1
got the circlip and rubber bung out from the top - just cant seem to get the cap inside out, any ideas as to drawing them out or loosening them without damaging the forks themselves???
Post by mellow on Jun 10, 2008 20:27:46 GMT 1
if i remember i did mine properly just muller it out n buy new ones ;D
Post by lovely on Jun 12, 2008 18:41:05 GMT 1
probably end up doing that as i remember the last lot were a b**gger to get out cheers mate
Post by mellow on Jun 12, 2008 22:21:24 GMT 1
no worries..........on a serious note...........i think i used a socket extension bar to froce the caps down to remove the clip then kinda worked the cap up n down then "persauded" them out ;D
Post by ozelsie on Jun 13, 2008 13:17:03 GMT 1
;D give em a good soak with some kero or diesel , over night , couple o gentle taps , clean the junk from around the top of them , work em , helps ;D
Post by racerd on Aug 28, 2008 23:45:39 GMT 1
when i had to get the fork seal out used a screw driver to prise them out then flatted and polish the top of the leg where i prised them out with a screw driver
