Post by mellow on Feb 16, 2016 19:40:05 GMT 1
If it helps my F2 is standard apart from TSA pipes and it runs very rich according to the one dyno run it had. Still waiting to get it to mr farnham to be set up
Post by muttsnuts on Feb 16, 2016 22:19:16 GMT 1
Are you running pods or Ramairs with the PWK's on those settings? foam filters
Post by wallcraft on Sept 23, 2016 7:52:56 GMT 1
ok checked some of my notes, for my track bike (running POD filters) and 1UA carbs, I had 330's and standard pilots in, with a shortened needle, engine has full race tune on, TSA pipes and an ignitech, that ran pretty good. I've now got PWK's on it, it has 135 mains, 52 pilots and JJH needles in, its not been tested yet, but seems pretty happy with what's in it HTH Hi mutts trying to fine tune mine, was this a final set up for you? Thanks for any help. Mark.
Post by muttsnuts on Sept 23, 2016 8:57:17 GMT 1
Hi Mark, I'll need to check, but I don't think I moved far away from the above TBH
Post by wallcraft on Sept 23, 2016 9:01:56 GMT 1
Hi Dave that would be great, getting an order in today at Allens.
Post by JOHN-DYNOSTAR on Sept 23, 2016 9:48:53 GMT 1
I would advise caution if you are having to run as big as 330 mains . may be ok for short flat out blasts but not sustained high speed . In my opinion
what colour are your plugs when you do a plug chop ? that is a good way to check. and easier than guessing off a forum
Post by wallcraft on Sept 23, 2016 10:28:46 GMT 1
Thanks John, point taken very true, just using as a rough guide at the mo , will be getting it on a Dyno to make sure belt and braces. Mark.
Post by akhil2212 on Oct 7, 2016 16:31:40 GMT 1
Hi,
Are standard carbs on F2 good enough for TSA pipes with the right jetting or does one need to consider bigger carbs ?
Thanks
Akhilesh
Post by midlifecrisisrd on Oct 7, 2016 18:24:00 GMT 1
Hi, Are standard carbs on F2 good enough for TSA pipes with the right jetting or does one need to consider bigger carbs ? Thanks Akhilesh If you are using the airbox the f2 cars are fine but they don't like pod filters Standard carbs have been known to give up to 70hp on tuned motors Steve
Post by akhil2212 on Oct 7, 2016 21:08:00 GMT 1
Thanks Steve.
I will seek your inputs soon.
Akhilesh
