Post by cb250g5 on Jun 14, 2018 21:48:41 GMT 1
They sound to have improved since issue 1. My LC was in, promised all sorts, received nowt. Sort of spoiled things for me, never bought the mag since, and doubt I ever will.
This comment will be deleted by Norbo soon, he doesn't allow negative comments about this mag, for some reason of his own.
Post by donkeychomp on Jun 14, 2018 21:55:25 GMT 1
WOW! On the front cover! You officially now have a pin up bike lol. Seriously though well done Mark. Still never seen a bike quite like it.
ps did the 550 side panel decals come off an XJ550?
Post by yamark on Jun 19, 2018 16:06:51 GMT 1
They sound to have improved since issue 1. My LC was in, promised all sorts, received nowt. Sort of spoiled things for me, never bought the mag since, and doubt I ever will. This comment will be deleted by Norbo soon, he doesn't allow negative comments about this mag, for some reason of his own. That is a shame, I can only assume things must have been chaotic for the first issue. Everybody at PSB has been professional and helpful, I can't praise them enough.
Post by yamark on Jun 19, 2018 16:25:36 GMT 1
WOW! On the front cover! You officially now have a pin up bike lol. Seriously though well done Mark. Still never seen a bike quite like it. Alex ps did the 550 side panel decals come off an XJ550? Thanks Alex, it still doesn't seem real, the article is first class. I would have liked a couple of engine build photo's for people that don't visit this Forum and haven't seen the build thread. There must be a number of people who bought the mag wanting to know how it was done. The decals were made by Image Works. Mark Cordwell paints, then Image Works make and fit the decals (exactly to order), and then Mark lacquers the paint set. Mark is well organised and a pleasure to deal with.
Post by donkeychomp on Jun 19, 2018 22:43:42 GMT 1
Heard nothing but great stories about Mark Cordwell. I have a client's bike coming in soon, I will get in touch with him and see if he can beat the quote I got from a local guy, his prices are insane. I only used him once so far, to lacquer a tank, he said it would be a drink. Must be a total piss head as he charged me Β£100!!
And thanks for the Image Works tip I will contact them about a decal idea I have.
Post by yamark on Jul 22, 2018 10:55:59 GMT 1
I've had very little time to work on the triple, but finally did some "man hours" in the "man cave".
I had the centre cylinder re-welded and checked it held pressure. I figured my next problem is replacing the centre base gasket (I always change them if a barrel is disturbed) as the new gasket will be uncompressed, while the two outer base gaskets are compressed. These outer gaskets were also seated with a thin smear of Hylomar, so the cylinders shouldn't move.
So, to compress the middle base gasket, I cut up some copper tube and bolted the barrel down using head bolts/washers.
SDC11518
I checked with a steel rule that all was flat, but there was a tiny step between 1 and 2 cylinders. I can only assume this is cause of the gas escape pointed out by Tobyjugs. I hand lapped all three cylinders once the bolts could come out and the cylinder was set in position.
SDC11520
Permatex applied (I also annealed the head gaskets) and a five stage tightening sequence had the top end back together. I pressure tested the water system - First test with my leakdown bungs in place, it held 6PSI for 1/2 hour. Then with the leakdown bungs removed, no loss of pressure for 1/2 hour, so that proves water passageways to cylinders are sealed
SDC11521
Next the clutch slip-
I then took the clutch cover off and saw the clutch mushroom had NO freeplay, this was a surprise, there was no play in clutch actuator. This was set to 1/8th of a turn back - it's as if the clutch plates have compressed and removed the freeplay. So I made up some 1mm shims to tension the springs a touch more, (remember I'm using FZ600 springs) and then readjusted the clutch freeplay.
Carbs, radiator and exhausts back on. I used high temp silicone on the exhaust collars
The bike will be filled of fluids once I get back from holiday I'm feeling fairly confident that all the niggles are sorted and hope to get some miles done before the Ace CafΓ© in September.
Cheers, Mark
Post by dusty350 on Jul 22, 2018 11:02:25 GMT 1
Great work mate , I knew you would get it sorted. Be great to see her up at the Ace Have a good holiday Dusty
Post by Tobyjugs on Jul 22, 2018 12:31:34 GMT 1
Hopefully some trouble free riding ahead. Have a nice holiday and Happy Birthday
Post by yamark on Jul 22, 2018 18:59:23 GMT 1
Great work mate , I knew you would get it sorted. Be great to see her up at the Ace Have a good holiday Dusty Thanks mate, I wouldn't have got this far without your help
Post by yamark on Jul 22, 2018 19:01:54 GMT 1
Hopefully some trouble free riding ahead. Have a nice holiday and Happy Birthday Cheers, for all your positive, constructive comments throughout the build, and thanks for noticing the birthday
Kind regards, Mark
Post by dusty350 on Jul 22, 2018 19:34:49 GMT 1
Didn't realise it's your birthday mate - happy birthday Mark Dusty
Post by donkeychomp on Jul 22, 2018 21:13:52 GMT 1
It is? Hippo Birdy matey!
Post by 0h5h1t on Jul 23, 2018 6:29:57 GMT 1
Hey happy birthday Mark mate. It'll be great to see you and the bike at the Ace so hopefully it doesn't conflict with Cadwell park.
Post by Topman350 on Jul 23, 2018 11:43:57 GMT 1
Happy birthday fella hope you have a great day π ππ π»π» π»
Post by Dangerous on Jul 23, 2018 14:52:05 GMT 1
Happy birthday mark have a great day. The treads been excellent.πππ
Post by dono on Jul 23, 2018 15:21:29 GMT 1
Happy birthday Mark, hope you have a great one :-)
Post by yamark on Jul 24, 2018 7:37:34 GMT 1
Cheers chaps, I had a great day. Sunday got even better when a coil cover came up on Ebay for not too many "beer tokens" on a buy it now. It's been one of those parts that I've struggled to get at reasonable money, and is one of the last of the hard parts to find to complete the RD700's shopping list. I'll start a build thread soon.
Cheers all, Mark
Post by Topman350 on Jul 26, 2018 23:05:31 GMT 1
Well done Mark on the build and the mag you have patients of a saint and deserve all the great comments by so may talented builders on here, will be watching your next for sure ππ
signal
Post by signal on Jul 27, 2018 8:20:07 GMT 1
Congratulations a well deserved magazine article. I am very keen to see your RD 700 take shape, I am guessing it is an air cooled, but just as eager to see how a LC is done. Thanks for posting.
Post by yamark on Jul 27, 2018 17:35:17 GMT 1
Congratulations a well deserved magazine article. I am very keen to see your RD 700 take shape, I am guessing it is an air cooled, but just as eager to see how a LC is done. Thanks for posting. Hi Signal, and welcome to the Forum mate.
The RD700 will be an LC, 4 cylinder. 4 cylinder LC's have been done a few times before, and probably easier than the triple to do.
Cheers, Mark
malc
Post by malc on Aug 8, 2018 13:28:46 GMT 1
Looking forward to your next build , if itβs half as good as this one it will be stunning and really enjoyed reading about the build.
Will it look like a standard lc like your last one?
Post by yamark on Aug 12, 2018 10:43:48 GMT 1
Looking forward to your next build , if itβs half as good as this one it will be stunning and really enjoyed reading about the build. Will it look like a standard lc like your last one? Thanks Malc, yes the 700LC will look fairly standard - just a bit bigger
Cheers, Mark
firebird67
2 strokes forever πππ
Post by firebird67 on Oct 9, 2018 7:17:21 GMT 1
What a fantastic read and congratulations on winning look forward to seeing the 700lc keep up the good work π
Post by yamark on Dec 29, 2019 21:29:13 GMT 1
Just bumping up this thread for the new guys. I do get the occasional PM asking what else I've built!
Post by Topman350 on Jan 7, 2020 23:43:53 GMT 1
Congratulations Mark on a superb build and the magazine did it more than proud you must be over the moon well done you are a credit to all builders.... And to top it off it sounds fantastic πππππ
Topman350 Chris
denver
Post by denver on Jan 18, 2020 18:04:33 GMT 1
Awesome work, holy shit
Post by yamark on Jan 19, 2020 20:18:13 GMT 1
Congratulations Mark on a superb build and the magazine did it more than proud you must be over the moon well done you are a credit to all builders.... And to top it off it sounds fantastic πππππ Topman350 Chris Chris, I saw your majestic bike in PSB this month, so back at ya fella. Just so bespoke, awesome vision
Cheers, Mark
Post by yamark on Jan 19, 2020 20:18:59 GMT 1
Cheers Denver
Post by chequeredflagracing on Sept 27, 2021 12:23:49 GMT 1
Post by chequeredflagracing on Sept 27, 2021 12:25:31 GMT 1
Any videos of it running?
