Post by holty on May 22, 2015 21:52:45 GMT 1
hi folks, just a small questoin about engine mounting anti-vibration washers, firstly which way round do they go, and secondly do i use 2, or 4 washers altogether, cheers
Post by kostas on May 22, 2015 21:58:26 GMT 1
Two mate.
Aft right side and fwd left.
Rubber to face the engine block..
Kostas
Post by holty on May 22, 2015 22:36:22 GMT 1
many thanks kostas
Post by JonW on May 27, 2015 0:02:41 GMT 1
One my whiteboard in the garage it has "FL / RR", (front left, rear right), in big letters, probably something we should all have in big on the wall of our workshops
murp
Post by murp on May 28, 2015 7:33:27 GMT 1
this is a timely thread..... checking over my lc earlier this week i noticed only one of these damper washers on left front... i promptly ordered a pair from norbo.....i have a 4mm gap between engine block and frame bracket on front right of engine..... this dont seem right to me..... my haynes manual is very vague on this and does not show any damper washers at all.....
surely that 4mm gap on right hand side is not correct ?
dave
Post by oldelsieboy on May 28, 2015 12:38:29 GMT 1
this is a timely thread..... checking over my lc earlier this week i noticed only one of these damper washers on left front... i promptly ordered a pair from norbo.....i have a 4mm gap between engine block and frame bracket on front right of engine..... this dont seem right to me..... my haynes manual is very vague on this and does not show any damper washers at all..... surely that 4mm gap on right hand side is not correct ? dave The engine mount plates, loose & frame mounted, do not bolt up tight to the engine cases but to the central sleeve of the rubber mounted bush which protrudes approx 4mm from the crankcase. The anti vib washer fills the gap on the sides as previously stated & prevents the motor twisting anticlockwise, as viewed from above, thus helping to alleviate stress on the exhaust mounting flanges. HTH OEB
murp
Post by murp on May 28, 2015 17:05:18 GMT 1
Thanks for that. I've had the plates off this afternoon. Yes I understand what's happening now
Sent from my GT-I9300 using proboards
stevep
Post by stevep on Jun 3, 2015 8:34:13 GMT 1
Good info which I need in a few day
Post by Gunny on Mar 6, 2021 19:05:00 GMT 1
Would it be beneficial to fit 4 ?
Post by Yogi on Mar 6, 2021 19:13:59 GMT 1
What it be beneficial to fit 4 ? You only need 2 to stop it twisting under tension from chain when giving it the beans 🙈
Post by midlifecrisisrd on Mar 6, 2021 19:20:17 GMT 1
Was it not recommended on early non tie bar frames to use 4
Post by JonW on Mar 7, 2021 0:55:50 GMT 1
Use the banshee ones, more rubber on em.
