Post by case on Jun 14, 2006 22:30:06 GMT 1
Post by case on Jun 14, 2006 22:54:22 GMT 1
ok new gasket it is . was just worried head was warped or something. the bikes head that is cheers.
Post by pablo on Jun 15, 2006 0:13:00 GMT 1
if your gonna pull the head off...the bikes one that is...you can have a go at checking its flat by lobbing it on a FLAT surface like a sheet of glass or summit...
Post by case on Jun 15, 2006 15:37:04 GMT 1
Cheers pablo off with its head its still leaking so will try your flat surface trick. New gasket on route. Still got to get it going yet aswell.
Post by Norbo on Jun 15, 2006 22:00:54 GMT 1
Allways use some instant as well it helps bond and i have never had a head gasket leek ever and allways use instant .
Post by pablo on Jun 16, 2006 22:25:23 GMT 1
if you find its a bit wonky,you can tape a sheet of fine emery paper on the sheet of glass and give it a little 'home-skim'...just do it enough to get a nice dull finish all over the head...dont go mad with some rough stuff...make sure you wash it thoroughly after though...
Post by case on Jun 18, 2006 17:16:51 GMT 1
a mate of mine sugested something the same with 320 wet n dry on a flat surface. will let you know what happens soon. been too busy to do owt last few days.
Post by pablo on Jun 18, 2006 18:27:12 GMT 1
as for what,if anything,to put on the gaskets at rebuild time...i think its a matter of personnal taste...i sometimes use a thin smear of grease to make it easier to get the old gaskets off,but if summit leaks persistently,i go with a bit of hylomar...blue or red,i cant remember which... ...norbos thinking of the cooling system i reckon...could be wise advice ...beats taking it off again...just dont go too mad with sealent coz it can sqeeze out when you torque down...gets in places it aint sposed to...
Post by jacobeana on Jun 18, 2006 19:17:05 GMT 1
If you want to make sure your head and barrels are flat use a mirror and grinding paste compound as used for seating valves, u can get it from any car parts shop. put paste on the mirror then rub the cyl head in a circular pattern. When you lift the head you will see if you have a level head by the pattern in the paste. in my opinon you should only grease your new gaskets before fitting then they will come off easy when it comes to stripping the engine down, and in most cases the gaskets can be re used ;D
Post by case on Jun 26, 2006 16:50:00 GMT 1
thanks to all fetled her now with home skim and new gasket, head just had some tiny pitting at front used 120 grade wet n dry taped to a nice flat mirror and three million revolutions later (my arms fell off) she was smooth.
Post by pablo on Jun 26, 2006 21:09:35 GMT 1
...is it running yet mate?
Post by case on Jun 27, 2006 18:18:20 GMT 1
no not yet thats an whole new ball game theres currently no spark but i havnt properly delved into that surely wont be much will it???
Post by pablo on Jun 27, 2006 20:15:04 GMT 1
hard to say...i'd start by doing the cheapest n easiest first mate...n swap bits if you have em...
Post by case on Jun 28, 2006 14:43:15 GMT 1
i thats what will do have 250 thats running are coils , cdi , etc the same
Post by pablo on Jun 28, 2006 19:36:49 GMT 1
i thats what will do have 250 thats running are coils , cdi , etc the same yeah mate they'll be fine to swap to get it running...so much easier to swap bits for ones you know work... ;)cheaper too :Pthat can only be good in my book... ;D
Post by case on Jul 3, 2006 22:13:33 GMT 1
its running now twas a knackered stator plate or probably one of the wires . found a new one at a bike jumble yip hee . front brake fixed too
Post by pablo on Jul 3, 2006 23:45:55 GMT 1
;D
