Post by Norbo on Oct 9, 2007 17:49:22 GMT 1
What bearing do you use . Do you just invert the ssy125 ones
Post by nikko on Oct 9, 2007 18:33:44 GMT 1
Yes Sir !!
Nikko
Post by tonkatoy on Oct 10, 2007 21:31:11 GMT 1
What bearing do you use . Do you just invert the ssy125 ones original ypvs fit just fine mate
Post by Norbo on Oct 11, 2007 13:54:26 GMT 1
With a spacer as well. Just so i know for sure.
Post by tonkatoy on Oct 11, 2007 21:18:32 GMT 1
With a spacer as well. Just so i know for sure. yes mate you still need the 5mm spacer on the bottom stem before you fit the bearing
Post by scott on Oct 11, 2007 21:33:07 GMT 1
With a spacer as well. Just so i know for sure. yes mate you still need the 5mm spacer on the bottom stem before you fit the bearing thanks m8 ,i've got to get 1 of them
Post by Norbo on Oct 12, 2007 9:30:44 GMT 1
I have now had 5 of them made as a bloke in Oz wanted one with his bearings.
