daveg
ProClassic
Post by daveg on Aug 6, 2007 9:46:46 GMT 1
I will be fitting the following on my standard 31K, anyone any idea where to start on the jets? Gibson mid-range pipes Carbon reeds Stan Stephens Race tuned barrels and head
I am currently running standard 240's
Any recommendations?
Post by Dirtbag on Aug 6, 2007 10:00:22 GMT 1
I'd go up 2 jet sizes....as a starter point . 260's should do the trick or possibly a size either way. I have loads of jets....all the way upto 300's.........if you need any
Post by sheep911uk on Aug 6, 2007 10:02:40 GMT 1
Sorry to hijack your thread same question but 350 lc,allspeeds,boysenn reeds and standard airbox?
Post by Dirtbag on Aug 6, 2007 10:06:22 GMT 1
You shouldnt really need to upjet with standard airbox and Allspeeds....officially Personally I'd go up one size , and open up the oil pump slightly..........to be on the safe side
Post by Norbo on Aug 6, 2007 10:26:51 GMT 1
As dean says. Not much i can add to this i agree witht he above.
Post by sheep911uk on Aug 6, 2007 11:48:11 GMT 1
So best to do plug chop just to check?
daveg
ProClassic
Post by daveg on Aug 6, 2007 12:25:12 GMT 1
Great thanks for the recommendations. I will try with 260's Thanks.
Dave
Post by Dirtbag on Aug 6, 2007 21:15:57 GMT 1
Great thanks for the recommendations. I will try with 260's Thanks. Dave Increase your oil pump slightly too mate.......when you're doing the plug chop it needs to be Digestive biscuit colour........NOT light tan !, better to be running slightly rich than too lean
daveg
ProClassic
Post by daveg on Aug 8, 2007 9:47:16 GMT 1
I am running it on pre-mix at 30:1 which I think is OK.
Thanks,
Post by sheep911uk on Sept 3, 2007 10:20:23 GMT 1
Stupid question but whats the next jet size up from standard on a 4l0?
Post by Dirtbag on Sept 4, 2007 6:58:15 GMT 1
Stupid question but whats the next jet size up from standard on a 4l0? 230's
daveg
ProClassic
Post by daveg on Sept 6, 2007 13:31:01 GMT 1
Well I started slowly. I fitted my Gibson pipes first. I bought the mid range pipes, and I am a little dissapointed at the build quality, I had to file the flanges flat, (there was a lot of weld splatter), secondly I ordered a race pipe, and they still welded a centre stand plate on the pipes, and finally the silencer cans are pretty shabby, they are made of aluminium, and even after cleaning they don't look new.... Anyway I used them in anger this last weekend, and I do think the bike is crisper, quicker to rev. I had to go up to 250 main jets, after a (too) brief plug chop on the track. The anodes were powder white, although the base of the insulation didn't really have a colour - people I race with are telling me it is MUCH more difficult to adjust the carburation by looking at the plugs because it is the LEAD in the petrol which colours the plugs and now we use unleaded..... Comments? Next change will be the reeds.....and then this winter I will change the barrels and head.
Post by Dirtbag on Sept 6, 2007 13:48:11 GMT 1
Each bike will differ slightly , I agree with you on the build quality of the Gibsons.......not as good as the old Allspeeds are they ?
Jetting is always gonna be a grey area....different bikes have different tolerances. If your's has white deposits on the plugs - its running too lean . Also even though petrol is unleaded you should still get some kind of beige deposit.
