Post by Dirtbag on Oct 31, 2006 14:22:33 GMT 1
Most of you have seen the swingarms I've made , well now I'm gonna have a bash at making some upswept F2 pipes to fit my LC.......gonna come out of the tail end similar to the RG500......with any luck. Bought 2 sets of pipes off ebay for a pittance so if I f**k the job up I've still got a useable set. It will also give me chance to knock the restrictor plates out I have also been in touch with Nige Kimber about making some slip-on covers for the F2/R end cans...........for those of us who have dented/scraped cans , it will prove to be an inexpensive answer to rashed pipes. Watch this space
Post by scott on Oct 31, 2006 19:13:46 GMT 1
i'll be watchin very carefully m8 as i've got to make a pair for my f2 project
minesatwin
well nurse it went... sky, ground, sky, ground ..Black!
Post by minesatwin on Oct 31, 2006 19:29:01 GMT 1
i'd b interested in a pair of slip ons........................................................... ooo errrr
bump
I can see my house from here...
Post by bump on Oct 31, 2006 23:07:53 GMT 1
Ditto the interest in the F2 can slip ons. as I just got a set of well used F2 pipes today. But a question; The rust and pitting on the pipes should be recoverable, but what can you do with dents Is there any metal based filler to use on pipes that'll stand the heat and vibration ?
Post by Dirtbag on Nov 1, 2006 6:42:27 GMT 1
You could drill a hole in the middle of the offending dent and pull it out using a slide hammer or drift.............then weld the hole back up and flat it off then respray it.
Post by vin on Nov 1, 2006 18:17:06 GMT 1
I think pabs did some repairs on exhausts if my memory serves me He'll help I'm doing the F2 mod also,Just bought a pair of nice carbon Lomas end cans from Tony at Links Engineering, and I'm in the process of making the bolt on bit that welds onto the expansions and then fit um! I'm doing a practice run on some scabby pipes first before I cut up me nice un's
Post by Dirtbag on Nov 7, 2006 8:39:48 GMT 1
Just had a look at your photos Vin....... those pipes will look well nice when finished
Post by vin on Nov 7, 2006 19:32:12 GMT 1
Cheers donk Hope to get them welded soon and then try them out ;D The ones in the picture are the scabby ones I'm trialling it out on!
Post by Dirtbag on Nov 8, 2006 9:39:06 GMT 1
Dont suppose you've had a go at cutting the restrictor plates out have ya ? I'm hoping that they are just spot-welded in
Post by vin on Nov 13, 2006 23:40:36 GMT 1
I didn't go any further than the double skinned part near the end can! so not sure about the restricting plates Are they inside the expansion
Post by Dirtbag on Nov 14, 2006 10:47:13 GMT 1
Apparently so.......I hope they dont effect back-pressure too much
Post by Dirtbag on Dec 16, 2006 20:46:47 GMT 1
Didnt find any restrictor plates in my expansion chambers.......however there is a restrictor in the tapered part immediately before the end cans......this cannot be knocked out......its welded all the way round , so I'm gonna have to make my own tapers. I'll post some pics soon.
Post by mellow on Dec 16, 2006 22:07:40 GMT 1
I'll post some pics soon. cool pics of wot m8 ur holiday ur sexual encounters ;D
Post by pablo on Dec 16, 2006 23:20:56 GMT 1
Didnt find any restrictor plates in my expansion chambers.......however there is a restrictor in the tapered part immediately before the end cans......this cannot be knocked out......its welded all the way round , so I'm gonna have to make my own tapers. I'll post some pics soon. thought they would be finished by now...slacker
Post by Dirtbag on Dec 17, 2006 12:04:18 GMT 1
I dont know .....you southern jessies dont know the meaning of work. Pabs is the most part-time part-timer I've ever met , and Mellow just sleeps on a grass cutter all day. Some of us work for a living ;D.......so there . I might take things slowly...but at least it gets done....eventuallly
Post by mellow on Dec 17, 2006 12:49:01 GMT 1
oi 'SCUSE ME i been to work this mornin 7am wanderin ro9und frozen fields n puttin up footy nets
Post by pablo on Dec 17, 2006 15:06:31 GMT 1
yeah! n ive got a coff
Post by tonkatoy on Dec 17, 2006 15:12:39 GMT 1
yeah! n ive got a coff ;D ;D ;D
Post by vin on Dec 17, 2006 18:05:11 GMT 1
Apparently so.......I hope they dont effect back-pressure too much I haven't had chance to try it out yet but what affects would it cause All I did was remove the outer skin so wouldn't it at worst be the same as the standard set up but just a bit louder
loopy
Post by loopy on Dec 17, 2006 23:15:30 GMT 1
yeah! n ive got a coff pabs you always got a coff..... try not sniffing halfords primer.... that'll cure it ;D ;D ;D lol
loopy
Post by loopy on Dec 17, 2006 23:16:43 GMT 1
I dont know .....you southern jessies dont know the meaning of work. Pabs is the most part-time part-timer I've ever met , and Mellow just sleeps on a grass cutter all day. Some of us work for a living ;D.......so there . I might take things slowly...but at least it gets done....eventuallly er....bathroom, started it in january........ when the shower getting put in??? flooring laid...tiling finished? ? or is that an eventually as well??/?
Post by pablo on Dec 17, 2006 23:20:24 GMT 1
yeah! n ive got a coff pabs you always got a coff..... try not sniffing halfords primer.... that'll cure it ;D ;D ;D lol im out in all weathers me,in n out of places all day breathing every buggers germs n farts ...wonder im able to get out of bed at all ;D
loopy
Post by loopy on Dec 17, 2006 23:31:12 GMT 1
poor pabs...... you tried using a mask........like they do in ER and casualty.
they call that kink off near us...... got to put your thermals on else you'll get kink off....or a broken rib like deans got.
Post by pablo on Dec 17, 2006 23:40:01 GMT 1
;D nah no mask...i'd look like michael jackson...chamone! ;D
loopy
Post by loopy on Dec 17, 2006 23:43:38 GMT 1
how about one of them tube things they shove up ya nose then?
or strepsils sore throat and blocked nose?
Post by pablo on Dec 17, 2006 23:50:18 GMT 1
;D nah...i'll just snot everywhere for a few days then back to normal
loopy
Post by loopy on Dec 18, 2006 0:08:03 GMT 1
oh get a hankie...... dont think everyone else would want your snot.
Post by mellow on Dec 18, 2006 0:13:48 GMT 1
Post by pablo on Dec 18, 2006 0:19:40 GMT 1
;D yeeeeeee eeeeeeeh!!!! ;D looka ma bad self
Post by nuttytart350 on Dec 18, 2006 17:52:35 GMT 1
how about one of them tube things they shove up ya nose then? or strepsils sore throat and blocked nose? recon that would do it........if u wanna blocked nose....stick a strepsil up it.... ;D
