Post by tonkatoy on Sept 13, 2006 21:51:43 GMT 1
hey just joined ! can anyone help me need to know how much of a job it is to do ? pictures would help ! but if any ones got info i would be gratefull
Post by pablo on Sept 13, 2006 23:15:18 GMT 1
;D hi mate...i think young hooligan is doing this very conversion... see 'hooligans VFRD' thread ;D
Post by Norbo on Sept 14, 2006 9:43:44 GMT 1
Hi mate . Wwelcome to the mad house . Have a look in the rebuild section . Like Paps said hooligan is doing just this mod so will be of grate help to you . He has just started aswell so if you offer him some dosh he may make 2 of anything he has to make to make the ends fit if you see what i mean . If he has the time that is you will have to ask but it woud save time and stress if he can .
Post by hooligan on Sept 14, 2006 11:26:30 GMT 1
Hi Tonkatoy
I'm doing a similar conversion at the moment if you look in the rebuild part of the forum you will see my posts. bellow are some of the things you will need to do
1, the VFR front end is easy to fit you just need a spacer and a bush making for the vfr stem to allow you to run RDLC bottom taper bearings at both ends.
2, speedo drive, the cable needs a bit of modification so you can connect it to the LC clocks
3, Rear end the NC24 swinger is 30 mm wider than a LC frame and 22mm wider than a valve. You need two bushes making up and a long centre bush to fit between the lugs of the NC24 swing arm
4, Frame there are several things you need to do first you need to make new swingarm mounts and move them outwards on the frame you may also need to remove some tubing on the inside of the mounts to allow the swinger to move.
5, Rear Shock. the NC24 rear shock is offset so you need to cut off the shock mount and reweld it in the correct place.
6, Front sprocket. You need a 8mm offset front sprocket to line the chain up with the back wheel. or you can mill the rear sprocket carrier to get the same effect.
All in all its possible but unless you have access to a lathe milling machine tig welder or live near me its going to be very expensive.
Post by hooligan on Sept 14, 2006 12:57:22 GMT 1
also forgot to mention that you may need to make rearsets and weld brakets on the frame for the remote shock adjuster and the rear master cylinder. but how said building a special was easy If I wanted easy I would get an RGV front and rear but who wants a bike that looks like every second LC at Ashbourne
Post by tonkatoy on Sept 14, 2006 22:04:54 GMT 1
thanks lads ! hooligans reply is a great help to me , he knows his stuff ! done the rgv conversion & i like a challenge ? got the 31k frame off "evil bay" £26 with v5 ! & the nc24 too £275 so it looks like i've got myself a project ? don't have access to the machinery but got some contacts & a great mate who is great with anything ! so when i find how to post pictures ! i'll post some? thanks again & hooligan creep, creep, !!!!!!!!!!!!!!!!!!!!!
Post by hooligan on Sept 14, 2006 22:41:47 GMT 1
Hi Mate
No problems no need to creep, where are you in the UK Im in Notts if thats not too far away your welcome to pop up and have a look
Post by tonkatoy on Sept 15, 2006 9:04:34 GMT 1
that would be great mate i'm not that far away ! Leek ,Staffs which is not far from Ashbourne ? i'm displaying my email so if you want to send your address & number to that its up to you ! once again thanks , Dave
Post by tonkatoy on Sept 15, 2006 9:42:53 GMT 1
my L.C.
Post by tonkatoy on Sept 15, 2006 9:44:37 GMT 1
my ypvs/rgv
Post by mellow on Sept 15, 2006 17:45:33 GMT 1
that lc is very nice well done
Post by tonkatoy on Sept 15, 2006 21:12:48 GMT 1
thanks mate ! it's been a labour of love but it was worth it ?
Post by hooligan on Sept 15, 2006 22:53:49 GMT 1
HMMMMMMMMMMM NICE ( Said in you best Jazz Voice)
Post by tonkatoy on Sept 15, 2006 23:04:16 GMT 1
Post by tonkatoy on Sept 15, 2006 23:10:26 GMT 1
Post by pablo on Sept 16, 2006 10:27:37 GMT 1
;D you look like you know what youre doing to me tonk! ;D
Post by pablo on Sept 16, 2006 10:28:31 GMT 1
HMMMMMMMMMMM NICE ( Said in you best Jazz Voice) nutter ;D...go n pick your bike up,i think i heard it fall over again
Post by Norbo on Sept 16, 2006 13:09:26 GMT 1
very nice mate . You have to much time on you hands . how about coming round my house and doing something on one of my bikes!!
Post by tonkatoy on Sept 16, 2006 15:19:44 GMT 1
always keepin myself busy boys (much to my wife's dispare)! not finished my rgv conversion & i'm getting the pieces of my next one ? can't take all tha credit for my bikes ! my mate "Will" (thats his name ) helps me so much with them (proper mate) !
Post by tonkatoy on Sept 16, 2006 15:25:34 GMT 1
Post by tonkatoy on Sept 16, 2006 15:51:46 GMT 1
Post by tonkatoy on Sept 16, 2006 15:52:42 GMT 1
Post by tonkatoy on Sept 16, 2006 15:53:55 GMT 1
Post by tonkatoy on Sept 16, 2006 16:07:56 GMT 1
Post by tonkatoy on Sept 16, 2006 16:09:00 GMT 1
Post by tonkatoy on Sept 16, 2006 16:09:54 GMT 1
Post by tonkatoy on Sept 16, 2006 16:13:28 GMT 1
Post by tonkatoy on Sept 16, 2006 16:15:22 GMT 1
some more pics ? getting the hang of this now!
Post by pablo on Sept 17, 2006 14:15:21 GMT 1
Post by scott on Sept 17, 2006 17:32:43 GMT 1
thats a very smart lc m8,hope mine turns out as good as that
