bump
I can see my house from here...
Post by bump on Aug 31, 2006 15:52:02 GMT 1
Hey Norbo found that gallery pic (the one marked beautiful 350 right ?). The F2 pipes do look nice on an LC, and it did have a belly pan so presumably it fiited OK. Anyone else done this and can remember how it ran ? Worthwhile mod or not ? I think as long it don't lower performance I might give it a go, even if it's purely cosmetic.
Post by wiggy on Aug 31, 2006 17:59:54 GMT 1
when i first built my hybrid i used f2 pipes on mine the end cans were level with the back wheel and theyre heavy
bump
Post by bump on Aug 31, 2006 21:57:52 GMT 1
How'd it run, did you notice any change in performance ? Presumably you mean that the end cans were level with the rear spindle ? Was that a problem ? Seemed like a good idea, maybe not eh ?
Post by Norbo on Sept 1, 2006 10:07:46 GMT 1
They are long. and heavy but i didnt notice them being any worse then the lc standard ones . but i dont recal them being any better just the same . They may be long but i think they looked better then lc ones .
Post by wiggy on Sept 1, 2006 16:44:52 GMT 1
the cans came level with the tyre on the wheel couldnt tell you about performance its got a pv motor in so it was standard running to the engine
bump
Post by bump on Sept 4, 2006 11:46:57 GMT 1
Would I be able use standard LC hangers, or would the upsweep of F2 pipes foul the end of the hangers ? Been looking at gallery pics on various sites but can't decide. Norbo? Wiggy ? Anyone ?
munch
Post by munch on Sept 4, 2006 11:49:34 GMT 1
you can use the Lc hangers ,but you will have to re drill the hole on the chamber rear mount.
also you shouldn't need to re-jet
Post by wiggy on Sept 4, 2006 19:04:23 GMT 1
munch is right i just angle grinded the bracket and made it a slot ive still got the pipes.... just incase i get an ar$0le mot tester
munch
Post by munch on Sept 5, 2006 1:03:45 GMT 1
With the bracket at the top it sits above the rear set I just scribed it to the top of the set then cut it off .
bump
Post by bump on Sept 5, 2006 9:48:27 GMT 1
Right, think I'm with you Not going to do this til winter so I've got time to look for a decent set at sensible money. But if anyone comes across a set, give me a shout. Probably find I'll have to refurb an OK set.
munch
Post by munch on Sept 5, 2006 11:09:35 GMT 1
I HAD A GOOD SET BUT NEVER FITTED THEM EVEN HAD THEM CAUSTIC SODA TREATED,I FITTED THEM UP BUT DECIDED THE END CAN WAS TO LARGE AND THEY SEEMED TO FLARE OUT AT THE BACK RATHER THAN PARRALEL WITH THE REAR TYRE.A GOOD MOD WOULD BE TO CUT THE REAR CONE AND PUT A SMALLER STINGER ON.
Post by Norbo on Sept 6, 2006 10:04:47 GMT 1
I agree with munch. They do stick out a little at the back, but they are still better then standard lc pipes . But munch has a good point about the end cas you can get mr kimber to do it for you its a standard thing he has done before .
munch
Post by munch on Sept 6, 2006 13:25:48 GMT 1
He has done it before on chatting to him he didn't have at the time any feedback though
Post by Norbo on Sept 6, 2006 21:46:22 GMT 1
The f2 pipe does work very well as they are so it can only work better i would think and sound better. But its not a cheep mod is it .
munch
Post by munch on Sept 7, 2006 0:40:54 GMT 1
They are actually quieter than standard Lc pipes remembering to that these are factory de-tuned chambers,they are governed by flow reducers internally look like donuts.Now if you remove them ie cut of the last cone and knock em out with a long screwdriver,then reduce the stinger to around 20-25mm you would have a way better chamber than standard.
bump
Post by bump on Sept 10, 2006 20:50:43 GMT 1
These F2 pipes seem even rarer than 4L0 pipes. Very few about, and most of them in pretty awful nick. Perhaps they were lower build quality originally, so haven't lasted as well ?
Post by Norbo on Sept 11, 2006 8:42:40 GMT 1
No they are as good build quolity but becourse they stick out at the back they get rashed all the time even in a light crash. I have loads with rashed cans but it is hard to fined a good set un marked . Becourse of the faring people dont clean down the down pipes so they do seem to get a far bit of corashon on them lc pipes get wiped down after a ride out i fined cos they are simple to get to .
bump
Post by bump on Sept 17, 2006 10:36:07 GMT 1
Post by Norbo on Sept 17, 2006 10:50:06 GMT 1
They are not special edition pipes at all they are RZ250 pipes i have a set they are standard fitment on some RZ's .
Post by mellow on Sept 17, 2006 21:56:34 GMT 1
see.................now i never knew that i took it they were from a special edition like the bloke says ...............just goes to show ya dont it.nice one norby
Post by bryan on Sept 22, 2006 2:05:20 GMT 1
you can get a set of bare metal large can from Gibson for £235 and paint them black and polish the ends.
bump
Post by bump on Oct 2, 2006 13:44:18 GMT 1
These F2 pipes seem even rarer than 4L0 pipes. Very few about, and most of them in pretty awful nick. A very nice set went for ££££ssss yesterday on e-bay, couldn't touch em. The problem is the end cans on OKish sets. The pipes themselves will just need lots of elbow grease, but what do you about dented & scuffed end cans ? Anyone ever restored a set of cans ? or know somewhere/one that can do it ?
zebrd
Time for Bed!!
Post by zebrd on Oct 2, 2006 15:31:32 GMT 1
Nigel Kimber can put his own end cans on F2 pipes and they do look smart.
Post by scott on Oct 2, 2006 16:07:09 GMT 1
the pair of f2 pipes i've got have had the original outer can removed and replaced with a new piece of ally pot-riveted on,can't be hard to do m8
Post by scott on Oct 2, 2006 16:11:31 GMT 1
heres a piccy of an lc with f2 pipes on,which is on ebay at the mo but it has the pv engine.
Post by pablo on Oct 3, 2006 8:39:28 GMT 1
too long for my taste
bump
Post by bump on Oct 3, 2006 9:59:39 GMT 1
heres a piccy of an lc with f2 pipes on,which is on ebay at the mo but it has the pv engine. Looks nice Scott. Didn't know if the outer can was easy replace, thanks for that. Means I can look for a set to do up
Post by alibongo on Oct 3, 2006 13:09:29 GMT 1
Tasty colour on the wheels.
Post by mellow on Oct 3, 2006 16:04:32 GMT 1
too long for my taste thats wot all de ladies say to me 2 ;D
Post by pablo on Oct 3, 2006 18:35:44 GMT 1
