Post by typer196 on Oct 8, 2007 19:23:07 GMT 1
Does anyone know whether the europeon rd125lc mk3 full power has the same CDI as the restricted UK rd125lc mk3, as i'm looking to try and set up my mk3 to working powervalve and have all the kit needed, just not sure about the CDI fitted to my bike, as i'm led to believe that even if the CDI fitted to my bike operates the powervalve, i will not be getting the full potential. I have seen a CDI on ebay where the seller is saying that the UK 125lc mk3 had a different CDI to the europeon one. The CDI on ebay has the code: 1GU-MO 50302. I have taken some pics of my CDI however some of the code has faded, so looking for some help of you lads before i go and purchase another one. The beggining of my CDI says: 1GU - then i cant make out anymore. Thanks Scott
Post by Dirtbag on Oct 8, 2007 20:25:02 GMT 1
I'd put money on the fact that the de-restricted full power LC will almost certainly have a different CDI unit to the U.K. one..............save your money
Post by Deleted on Oct 8, 2007 20:27:20 GMT 1
well.... i have the import dt125lc mk3 with full working power valve. when i got it and put it in my 80 i could not get it to start, so after much thinking/deduction i worked out that the cdi was faulty. i ordered from a breaker a uk mk3 cdi which was all he had and put that on and guess what it worked! the p/v does its start up turns and when its running it works fine. there is a lot of talk on rd125lc forum about which things make the euro ones work and which don't, due to my experience i think that you need a euro wiring loom and control box and servo, the cdi does not matter (in my case it didn't anyway).
just checked the fiches for both and; rd125lc cdi = 1GU-85540-MO comp box = 1GU-85830-MO dt125lc cdi = 34X-85546-MO comp box = 57U-85825-MO
don't know if this helps but check out the rd125lc forum they have loads of threads on the subject (some of mine in there too).
there are a few guys on there with import models for which you can check the parts with. thanks Jamie.
Post by typer196 on Oct 8, 2007 21:04:05 GMT 1
Thanks everyone, will make a bracket for servo motor at work tommorow, and put it all back on once received seal for valve.
Scott
Post by Norbo on Oct 10, 2007 10:30:34 GMT 1
They will run with a uk loom as all the blocks are there for it to work you should just be able to plug it in and go. depending on what controle box you have you may have to chop the wires a bit to get it t i work right but i do know they will and you dont have to chainge the loom.
I have been toled that when they do work with out a bush on the cable side you get a lot of oil coming out so a bush will need to be bade with an O ring. I think one from a ypvs could be modered to do the job .
Post by typer196 on Oct 10, 2007 16:38:30 GMT 1
Norbo, I know where you are coming from with the leak as it happened with mine, however should there be a special powervalve seal on the housing end to prevent the leak?, it does not show the seal in the haynes manual, however i have ordered one to find out. If it doesnt work i will have a groove machined in and fit a o- ring.
Post by Deleted on Oct 10, 2007 17:59:56 GMT 1
the o ring is there in the fiche i sent you, part no. 93210-30640, just checked is the exact one on the 350 ypvs there you go. bloody helps having all these fiches you know.
Post by Norbo on Oct 11, 2007 13:24:58 GMT 1
You know i still never any fishes come threw J. Did you send them
Post by Deleted on Oct 11, 2007 18:20:12 GMT 1
You know i still never any fishes come threw J. Did you send them i have sent them twice now norb's. have you got another email address i can send them to?
Post by Norbo on Oct 12, 2007 9:29:16 GMT 1
lc.engineering@yahoo.co.uk Try this one if the rdlccrazy2005@yahoo.com will not take them. May be my spam filter is blocking your mails .
Post by Deleted on Oct 12, 2007 16:30:21 GMT 1
lc.engineering@yahoo.co.uk Try this one if the rdlccrazy2005@yahoo.com will not take them. May be my spam filter is blocking your mails . sent as off date and time above ok
