Post by bertiemollie on Sept 18, 2007 12:35:52 GMT 1
Hi All, Is there any chance one of you kind fellow forum members could stick up a picture of the frame where the coil mounts. Mine seems to have been damaged in battle . One of the lugs seems to be missing. Does the frame have weld nuts? Perhaps there is someone out there who has a bike stripped to the frame? Mine looks a little sad at the mo .
Post by mellow on Sept 18, 2007 16:09:53 GMT 1
erm.............i got 2 bare frames here.no coil on em not much help i know
Post by twostroker on Sept 18, 2007 18:05:28 GMT 1
it looks like your going to have to weld some brackets on your existing frame for a coil to bolt on or if its a complete restoration it might be worth getting a secondhand frame,your right about it looking a bit sad at the mo mate.
Post by bertiemollie on Sept 21, 2007 15:07:19 GMT 1
it looks like your going to have to weld some brackets on your existing frame for a coil to bolt on or if its a complete restoration it might be worth getting a secondhand frame,your right about it looking a bit sad at the mo mate. I have the pic I need now. I will fabricate a tab and weld it on. I won't be changing the frame as it has matching numbers ;D. It will look better once it is powder coated.
Post by Norbo on Sept 21, 2007 16:01:57 GMT 1
You wont even see its had a bit welded on when its all together.
