Post by scott on May 7, 2006 12:37:44 GMT 1
what size pistons do i need for barrels that mesaure 65mm chaps,
Post by scott on May 8, 2006 17:09:18 GMT 1
there's apair on ebay at the moment,0.5 oversize,shall keep me eye on em.me bike shop round ar way can do me 2 pistons,pins,rings,circlips & small ends for £100 .is this any good.
Post by pablo on May 8, 2006 21:10:40 GMT 1
what size pistons do i need for barrels that mesaure 65mm chaps, standard bore size is 64mm...65mm would be 1mm oversize... piston should be marked +1.0mm
Post by scott on May 8, 2006 21:28:19 GMT 1
cheers pablo,only bin measurin with a crap b & q tape.would it be best to get them measured properly.thinkin about it,it looked more like 64.5mm so this would be 0.5 oversize,is this wright.
Post by scott on May 8, 2006 21:44:15 GMT 1
just looked at norbo's stuff m8,did'nt see them before,cheers
Post by scott on May 8, 2006 22:19:17 GMT 1
evnin pal.get em measured properly.internal micrometer should do the trick. will do m8 cheers
Post by Norbo on May 8, 2006 22:28:34 GMT 1
You need to get them sized right first. You dont want to get pistons quorter mill to small or big do you.
Post by pablo on May 9, 2006 2:22:47 GMT 1
if anything you should recruit a good machine shop and have them measure then hone the bores to properly suit the pistons...dont forget to chamfer the ports slightly afterwards...some places do this for you...most dont...give the rings a easier life
Post by pablo on May 9, 2006 2:42:35 GMT 1
dunno mate...they do all sorts of bore plating nowadays though...ceramics too...google it ...you wont be able to see the chrome once youve built the engine you know ;D ;D ;D
Post by pablo on May 9, 2006 2:48:31 GMT 1
;D ;D ;D doh...i know mate ;D ;D ;D i was jesting bout the bling thing ;D ;D ;D...f**k me its late...i'll have to charge you doubletime norbs...
