Post by vin on May 3, 2006 21:01:31 GMT 1
Some more info please I have a spare engine that has ypvs barrels on and 4L1 cases, excuse my ignorance but I take it that someone has put power-valve top end on a LC cases My question is will a LC crank fit into a 1WT cases as I have some of theses also but the crank is f--ked!! I would like to make a complete matching numbers motor from a ever learning LC/YPVS fan. vin
Post by vin on May 3, 2006 21:49:26 GMT 1
OK dirtbag I will do that thanks.
Post by mellow on May 3, 2006 22:38:05 GMT 1
VIN......................can i have an easy question plz m8 ;D
Post by pablo on May 3, 2006 22:43:38 GMT 1
;D heres one...bran flakes or rice corpses...
Post by mellow on May 3, 2006 22:46:07 GMT 1
rice KRISPIES
Post by mellow on May 3, 2006 22:46:37 GMT 1
geez u 2 r on it tonight aint ya ;D
Post by pablo on May 3, 2006 22:47:03 GMT 1
Post by mellow on May 3, 2006 22:48:56 GMT 1
BRAN.........................will u 2 slow down...........gotta get to other posts yet ;D
Post by mellow on May 3, 2006 22:58:17 GMT 1
where am i time for the last bit of the matrix...............il catch up after that
Post by vin on May 4, 2006 18:42:39 GMT 1
;D ;D ;D
Post by pablo on May 4, 2006 22:19:05 GMT 1
Some more info please I would like to make a complete matching numbers motor from a ever learning LC/YPVS fan. vin i think a matching numbers motor refers to the engine number matchin the frame number which matches the numbers on the log-book...its what the purist fellas want...this what you mean vin?... ???on a 350 LC for example,they would all need to start with 4LO...as opposed to 4L1 for the 250...31k for the early valves n so on...
Post by mellow on May 4, 2006 22:21:43 GMT 1
pabs is right............. matching numbers is where the frame and engine number are the same and there are sum goons who take it to the extreme that if they dont match it aint real its a shmae after all my work that to them it aint a real F2
Post by pablo on May 4, 2006 22:25:08 GMT 1
Post by mellow on May 4, 2006 22:25:44 GMT 1
who told u ;D
Post by pablo on May 4, 2006 22:26:55 GMT 1
...........................here mate...then i went.................................
Post by mellow on May 4, 2006 22:27:27 GMT 1
to engine numbers
Post by vin on May 4, 2006 22:33:02 GMT 1
Urrrrrr your right guys I did know that just having one of those senior moments that seem to happen now and again Any of you guys heard from norbo? as I have PM'ed him regarding the crank issue Vin
Post by mellow on May 4, 2006 22:33:51 GMT 1
no m8 i was just askin where he is u foned him?
Post by vin on May 4, 2006 22:36:21 GMT 1
no m8 i was just askin where he is u foned him? Not yet, I will give it a day or two then I will. Thanks Vin
Post by mellow on May 4, 2006 22:37:05 GMT 1
did u sort ur powervalves
Post by pablo on May 4, 2006 22:37:39 GMT 1
i dunno what the 1wt cases are mate...i do know however that the LC and valve cranks,although similar,are different...loads of info on the home page...one of the specials is an LC with a valve crank fitted...nice colour,black i think ...needs the LC cases machining i think...valve crank is a bit more beefy
Post by vin on May 4, 2006 22:42:42 GMT 1
did u sort ur powervalves No mellow I still have the rear end out to fit my metmachex once I get it polished, I here your an expert at polishing, not getting your rear out Vin
Post by mellow on May 4, 2006 22:44:46 GMT 1
both ;D metmachex r normally polished aint they
Post by vin on May 4, 2006 22:47:21 GMT 1
I got this one secondhand and it needed some weld filling were the chain wears a groove in it Common fault I believe
Post by mellow on May 4, 2006 22:49:55 GMT 1
5 minute job m8
Post by pablo on May 4, 2006 22:53:51 GMT 1
vin,how much did you give for the swinger if you dont mind me asking?
Post by vin on May 4, 2006 22:59:04 GMT 1
E-bay as a bundle ;D I only wanted the swinger but found gold also New power valves, excellent condition 31K exhausts,31k tank and plastics and much more All for £226 ;D ;D who says E-bay isn't great
Post by mellow on May 4, 2006 23:03:03 GMT 1
me u want a crap f2 tank to go with it?
Post by vin on May 4, 2006 23:06:19 GMT 1
No thanks m8 E-bay again Excellent tank,panels and long can microns £200 posted ;D
Post by pablo on May 4, 2006 23:08:38 GMT 1
;D...i only window shop....
