Post by Yogi on Mar 6, 2014 22:12:04 GMT 1
[/quote] Ill bring mine round for some help with strippin her so you dont get bored waiting lol[/quote] You know where I am
Post by Yogi on Mar 15, 2014 17:53:13 GMT 1
Update Gang Went to BOYZ TOYZ Monday and had a moan about there lack of progress on my panels and wheels,I gave until today or else I would take them else where,, Hey presto the wheels were done and the panels were nearly ready for the final design BBCode (message boards & forums)
Post by Yogi on Mar 15, 2014 17:56:42 GMT 1
Still waiting on the crank but can see light at the end of the tunnel BBCode (message boards & forums)
Post by Yogi on May 11, 2014 16:41:19 GMT 1
Hi gang,quick update I sent my rebuilt crank back last week to be checked,,I got it back Friday with a note saying,,NOTHING WRONG WITH CRANK,,ANYMORE PROBLEMS SPEAK TO YOUR ENGINE BUILDER,,, well as I build my own I couldn't ,,so I put it back in the same cases, with all the same parts and hey presto it's ok,lying b*****ds
Post by Yogi on May 17, 2014 16:01:48 GMT 1
At last my panels are done BBCode (message boards & forums)
Post by Yogi on May 17, 2014 16:03:14 GMT 1
4 months later BBCode (message boards & forums)
Post by Yogi on May 17, 2014 16:04:42 GMT 1
I think they were worth the wait BBCode (message boards & forums)
Post by Yogi on May 17, 2014 16:06:32 GMT 1
And the £600 BBCode (message boards & forums)
Post by Yogi on May 17, 2014 16:09:49 GMT 1
Bit more tinkering, then mot ,then the open roads,,can't wait
Post by stfocus on May 17, 2014 21:51:41 GMT 1
That is looking f..king sh..t hoooooot I love it my next build is going to be a hybrid just hop I can pull it off just like that :)muuuuuuuu
Post by Yogi on May 17, 2014 22:17:27 GMT 1
That is looking f..king sh..t hoooooot I love it my next build is going to be a hybrid just hop I can pull it off just like that :)muuuuuuuu Cheers Stfocus, its nice that someone appreciates all the work that goes into building a hybrid
Post by Eyrey1 on May 17, 2014 23:31:51 GMT 1
i like it ,paint job makes it look more modern ! have you been round the block on it matt ?
Post by agustanz on May 18, 2014 5:29:53 GMT 1
Now that's got style plus. Very nicely done. The paint design adds to the look very well. I would have that in my shed in a second. Regards Gavin
Post by dusty350 on May 18, 2014 6:55:31 GMT 1
Yep, really really nice Hybrid. Well done. Dusty
Post by Yogi on May 18, 2014 19:20:29 GMT 1
i like it ,paint job makes it look more modern ! have you been round the block on it matt ? Not yet mate,the back brake won't bleed
Post by Yogi on May 18, 2014 19:22:28 GMT 1
Cheers for the nice comments guys
Post by muzz350 on May 19, 2014 8:50:44 GMT 1
It looks like what a modern YPVS should be built like if you know what i mean? Its a top build.
Post by JonW on May 19, 2014 13:32:39 GMT 1
Really nice, I have most of the same bits to do my 31k in a similar vein, been collecting for years, quite surprised at what id got actually. Anyway, lovely bike!
Post by nicki46 on May 20, 2014 21:25:53 GMT 1
That looks really nice!
Post by Yogi on May 20, 2014 21:57:16 GMT 1
:)Cheers Gang can't wait to get out on it
Post by mouse on May 21, 2014 6:56:08 GMT 1
Really nice, looks great
Mouse
Post by Norbo on May 21, 2014 7:51:24 GMT 1
Loving this bike mate looks trick as hell . that paint makes it realy stand out as a special should . excellent bike truly lovely
Post by Yogi on May 21, 2014 17:20:06 GMT 1
Loving this bike mate looks trick as hell . that paint makes it realy stand out as a special should . excellent bike truly lovely Cheers Norbo High praise indeed from the Rd god himself
Post by lukey1965 on May 21, 2014 18:43:31 GMT 1
Stunning ....
Post by ojay on May 29, 2014 21:46:38 GMT 1
Yogi
have you had any problems with clearance between the rear master cylinder and the banana swing arm? Mine appears to have come together at some point chipped the master cylinder and swing arm and deposited a load of brake fluid onto my swing arm. :-( Is this something which you or other members who re running this set up have come across?
cheers
OJ
Post by Yogi on May 30, 2014 18:42:38 GMT 1
Yogi have you had any problems with clearance between the rear master cylinder and the banana swing arm? Mine appears to have come together at some point chipped the master cylinder and swing arm and deposited a load of brake fluid onto my swing arm. :-( Is this something which you or other members who re running this set up have come across? cheers OJ Funny you should say OJ,I had trouble bleeding the back brake so I bought a brembo off an R6 and when I changed it I noticed a small gouge in the arm,when I fitted the brembo one I had to space the bottom hole with 2 washers and now the clearance seems ok, I'm taking for an MOT tomorrow so I will check again when I get home, ill let you know the outcome, cheers,Matt
Post by midlifecrisisrd on Jun 1, 2014 19:12:21 GMT 1
Yogi have you had any problems with clearance between the rear master cylinder and the banana swing arm? Mine appears to have come together at some point chipped the master cylinder and swing arm and deposited a load of brake fluid onto my swing arm. :-( Is this something which you or other members who re running this set up have come across? cheers OJ Funny you should say OJ,I had trouble bleeding the back brake so I bought a brembo off an R6 and when I changed it I noticed a small gouge in the arm,when I fitted the brembo one I had to space the bottom hole with 2 washers and now the clearance seems ok, I'm taking for an MOT tomorrow so I will check again when I get home, ill let you know the outcome, cheers,Matt It hits on all YPVS with banana arm so needs spaced out to clear Steve
Post by Yogi on Jun 1, 2014 19:38:20 GMT 1
Seams ok now I've spaced it out
Post by ojay on Jun 1, 2014 19:41:48 GMT 1
Cheers steve . I read the rgv conversion thread in the tech section after matts post above . Having checked my bike sure enough there are no washers to space it out. Another thing to add to the to do list! OJ
Post by blastcoat on Jun 9, 2014 18:59:52 GMT 1
Looks amazing,love the colours
