pete
Post by pete on Apr 19, 2006 10:30:30 GMT 1
Hi all It only works intermittenly Ive had it apart and cleaned it helped for a while and packed up again. Got me puzzed as it's only a magnet and bit that spins not much to go wrong but it does. Is there a way to fix it or do I have to get another one ? Pete
Post by Shytalk on Apr 19, 2006 12:51:06 GMT 1
Assuming that the cable is OK you can try a drop or two of light oil on the speedo mechanism - you can use carb cleaner but you have to be very careful as it can strip the paint from the clock surround.
Post by pablo on Apr 19, 2006 23:36:34 GMT 1
dont forget to check the other end mate...sometimes when the front wheel is put back in the little lugs that locate the speedo drive dont always line up properly...the drive itself could also need looking at...
Post by Norbo on Apr 20, 2006 9:26:51 GMT 1
dont forget to check the other end mate...sometimes when the front wheel is put back in the little lugs that locate the speedo drive dont always line up properly...the drive itself could also need looking at... Good point . My lc2 did the same bloody thing.
pete
Post by pete on Apr 21, 2006 9:00:16 GMT 1
thanks guys I's have another look at it Pete
pete
Post by pete on Apr 29, 2006 15:05:22 GMT 1
Fixed it got it sussed the mechanism was sticky inside cleaned it with electrical contact cleaner Pete
Post by pablo on Apr 30, 2006 15:53:13 GMT 1
;D ;D ;D
