hrc43
Post by hrc43 on Apr 15, 2006 10:56:55 GMT 1
hi, i'm new to all this , i used to race a 250 lc in the 80's then numerous two strokes for 25 yrs. just deciced to re-live my youth and restore one,when i say just i mean 2 yrs ago,its nearly finished(arn't they all)but after seeingsome on here i might start again.i'm having a few problems with it running,keeps flooding / filling up the left hand exhaust with fuel even with tap off but after reading "puddle of petrol" thread i thinki know what it is. i need a few bits and pieces and a lot of advice so if it is alr ightwith you lot i might ask on here . cheers.
hrc43
Post by hrc43 on Apr 15, 2006 11:03:20 GMT 1
do you think the pics big enough.told you i was new to all this
Post by pablo on Apr 15, 2006 12:03:27 GMT 1
;D welcome mate...its a 'very' common theme on here this youth reliving...think there might be a minimum age soon... ;D
hrc43
Post by hrc43 on Apr 15, 2006 12:24:19 GMT 1
its mutch worse than that, all the hair as gone and i nearly put some clipons on the old girl and started racing again, we'll never learn
Post by pablo on Apr 15, 2006 12:34:49 GMT 1
looks like your gonna fit right in mate... ;D ;D ;D
Post by pablo on Apr 15, 2006 12:44:03 GMT 1
mines thin but who wants fat hair right? ;D
hrc43
Post by hrc43 on Apr 15, 2006 12:55:40 GMT 1
how can you have a full head of hair and be called wiggy
Post by mellow on Apr 15, 2006 14:54:53 GMT 1
OI OI ;D just popped in.........takin a break coz its started rainin HRC43 WELCOME [/size] [/color] [/i][/b] everyone is very helpful and friendly here..........and im sure between them all if u need any answers sum 1 will be able to help id just like to add im doin standard AND i chose to have no hair ok ;D
Post by wiggy on Apr 15, 2006 17:36:32 GMT 1
I think theres only Wiggy that actually has a full head of hair , I have most of mine....but the tide is going out fast ;D ;D ;D yes ive still got it all and extra just in case
hrc43
Post by hrc43 on Apr 15, 2006 18:11:51 GMT 1
right first question tap leaking on tank thought it was from oval o ring between tap and tank replaced it and its still leaking. looks like its coming thro the threads of the screws should there be a washer on the screws, copper maybe? also what size jets for a 350 with k&n's it says 4L1001 on carbs. cheers
Post by pablo on Apr 15, 2006 20:22:07 GMT 1
i couldnt get my screws done up very tight so i swapped them for bolts and put washers on at the same time...you can crank them a bit tighter but watch you dont over do it...as for the jets,i couldnt say for sure...i know you should go up a size or three from standard...someone on here will probly know more.theres loads of info on the home page...
Post by mellow on Apr 15, 2006 21:15:54 GMT 1
ok m8 i am currently pondering this one.mine had fibre washers on and i was considering puttin P.T.F.E tape on the bolts not sure if its petrol proof though
Post by chrismac on Apr 15, 2006 21:27:25 GMT 1
ok m8 i am currently pondering this one.mine had fibre washers on and i was considering puttin P.T.F.E tape on the bolts not sure if its petrol proof though PTFE is petrol proof, it also has the lowest friction of any meterial ( the thing you know
Post by mellow on Apr 15, 2006 21:30:46 GMT 1
r u sure Petro-Tetro-Flouro-Ethane tape is im gonna whack sum of that round the bolts then and have fibre washers. shouldnt leak then
Post by Norbo on Apr 15, 2006 21:56:38 GMT 1
Hi Mate and welcome to mad house . I hope you will fined it welcoming and feel free to post as much as you want about anything that takes you fancy. Do you have pipes on as well as filters. You have to go up 2 with pipes and 1 with filters A standard jet is 220 . you wont need to replace the pilot its a wast of time . PTF can help with the tap, but there should be a fiber washer underneth the 2 bolts .
Post by mellow on Apr 15, 2006 21:58:53 GMT 1
sorted ;D
hrc43
Post by hrc43 on Apr 15, 2006 22:16:54 GMT 1
8-)cheers dudes. i have tried ptfe but that didn't work. but couldn't see any washers in the old haynes manual. i'll try some fibre ones if i can find some.i think i need some new float valves and seats anybody have some?
Post by scott on Apr 15, 2006 22:29:31 GMT 1
i reckon some old gasket will do ya mate,just cut it to the shape u need,it's worked for me in the past.
Post by Norbo on Apr 17, 2006 9:35:09 GMT 1
8-)cheers dudes. i have tried ptfe but that didn't work. but couldn't see any washers in the old haynes manual. i'll try some fibre ones if i can find some.i think i need some new float valves and seats anybody have some? I have them in my carb repair kits the brass housing and the flote cut of needle with the O ring and the bole gasket . They are £10 each and £1 post if this helps.
hrc43
Post by hrc43 on Apr 17, 2006 12:50:47 GMT 1
ta. i'm going to make a list of bits i need to finish it then i'll give you a ring
Post by pablo on Apr 18, 2006 20:22:54 GMT 1
;D ;D ;D
z1nut
Post by z1nut on Apr 18, 2006 21:01:30 GMT 1
Glad you could join us - you sad old man,
Welcome to the fold,
Cheers
pj
hrc43
Post by hrc43 on Apr 18, 2006 23:54:03 GMT 1
hi z1 nut. i restored a z900 a couple of years ago as well, i'll dig a photo out for you if i can find one. but back to the lc, i want to repaint my standard exhausts any body know the best paint for a good match or can you get them coated (black chrome ?).cheers geezers!
loopy
Post by loopy on Apr 19, 2006 13:29:47 GMT 1
this might sound stupid but i recognise that fence it looks local to me and baggy ;D
loopy
Post by loopy on Apr 19, 2006 13:31:56 GMT 1
;D welcome mate...its a 'very' common theme on here this youth reliving...think there might be a minimum age soon... ;D how about mental age does that count? ?
hrc43
Post by hrc43 on Apr 19, 2006 15:29:43 GMT 1
THAT'S FUNNY COS' THAT BACKSIDE LOOKS FAMILIAR TO ME TOO
loopy
Post by loopy on Apr 19, 2006 15:34:08 GMT 1
its from a web page on the internet somewhere....dunno where it came from just saw it in dirtbags gif file...and thought mmmmm nice avitar...very different. ;D so where is that fence located then? i know yorkshire......... still looks local
hrc43
Post by hrc43 on Apr 19, 2006 21:00:16 GMT 1
why its in my back garden of course and its very local (to me)
Post by pablo on Apr 19, 2006 23:52:19 GMT 1
this might sound stupid but i recognise that fence it looks local to me and baggy ;D its a local fence for local people...we'll have no trouble here... ;D
Post by pablo on Apr 19, 2006 23:53:57 GMT 1
;D welcome mate...its a 'very' common theme on here this youth reliving...think there might be a minimum age soon... ;D how about mental age does that count? ? depends what age you went mental... ;D ;D ;D
