Post by easytripperthethird on Jul 28, 2013 14:28:18 GMT 1
hi everyone hope your all well
I am looking to fit a hydraulic clutch to my ypvs special i have seen one fitted but do not no what slave they used, if anyone can help it will stop me going crazy looking for the bike
thank you wayne
Post by midlifecrisisrd on Jul 28, 2013 15:04:55 GMT 1
If you look for nikfubar in the finished or rebuild section you will find his 3rd hybrid build which had a hydraulic clutch.
Post by midlifecrisisrd on Jul 28, 2013 15:05:57 GMT 1
Post by nikfubar on Jul 28, 2013 15:48:03 GMT 1
Post by wallcraft on Jul 28, 2013 19:22:53 GMT 1
Has anyone fitted one of those kits to a 4 LO?
Post by nikfubar on Jul 28, 2013 19:54:59 GMT 1
Has anyone fitted one of those kits to a 4 LO? How the hell ya gonna do that, the clutch operates in a different way, would be quite easy though with a different kind of slave cylinder bolted to the outside of the side casing.
Post by Roofmonster on Jul 28, 2013 20:04:33 GMT 1
Perhaps you could bolt a Bandit slave cylinder like this to a 4LO casing.
Post by nikfubar on Jul 28, 2013 21:09:51 GMT 1
Yup that would work with a longer push rod
Post by dusty350 on Jul 29, 2013 7:02:04 GMT 1
Hi, I did a hydraulic clutch conversion on an Rd400e.Same sort of clutch actuation as an Lc. It needed a 3mm steel mounting plate, Triumph slave cylinder with a master from a YZF750. The pushrod length can take some working out/trial and error, so I made an adjustable rod, by welding a threaded insert on the end of the pushrod, so a shorter rod could be screwed in or out as necessary; The Rd400 cylinder head bolt was a spare that I cut down to use as the threaded boss to be welded on the end of the pushrod. Dusty
Post by dusty350 on Jul 29, 2013 7:09:44 GMT 1
Just to add, I had to remove 1 of the mounting castings off the slave cylinder to make it fit, but it was a relatively easy mod to do; Dusty
Post by Norbo on Jul 29, 2013 9:13:59 GMT 1
I think that's look just ace mate very nice indeed. looks factory the way you have it .
Post by easytripperthethird on Jul 29, 2013 17:15:15 GMT 1
cheers lads thanks for the help
wayne
