Post by kevsypvs on Jul 12, 2013 15:14:48 GMT 1
right here we go just stripped whats left of my old f2 , engine , tank and many other parts were sold years ago , so im starting with a bare frame ,front forks and wheel rear swing arm and back wheel , also have a complete rebuilt 31k engine that was overhauled a year ago by a mate this is it so far / frame looks ok but was poorly powdercoated 9 years or so ago so il be getting that done shortly along with the wheels and various other parts gona be a slow build so dont expect daily updates the bike is a 87 model on a D plate , progress so far
Post by kevsypvs on Jul 17, 2013 11:42:48 GMT 1
thought id start stripping the petrol tank full of dents but worse was yet to come
Post by kevsypvs on Jul 17, 2013 11:45:09 GMT 1
nitromors on old tin 15 yrs old stripped it in 10 mins
Post by kevsypvs on Jul 17, 2013 11:49:58 GMT 1
oh you fkn b-----d not good at all another one for the scrapheap the joys of restoring , may have to use another tank of a different model /make don't know what else will fit though problems arghhhhh
Post by kevsypvs on Jul 17, 2013 13:21:04 GMT 1
grinder with cutting disc coming out soon ,i want to see how bad these rust inside ,as ive sorced another tank from another model all will be revealed shortly
Post by kevsypvs on Jul 17, 2013 14:44:25 GMT 1
just thought youd like to see whats inside the average 30 plus year old petrol tank , I noticed many holes around the fuel tap outlet and the inside of the tap mounting plate was very corroded
Post by kevsypvs on Jul 17, 2013 14:46:14 GMT 1
Post by kevsypvs on Jul 17, 2013 14:49:03 GMT 1
the tank was holed on the tank mounting brackets at the front right where there welded on /total scrap got another tank coming in a week or so
Post by kevsypvs on Jul 26, 2013 13:53:14 GMT 1
well out with the grinder with cutting disc no messing about we have this
Post by kevsypvs on Jul 26, 2013 13:56:59 GMT 1
then this new tubes just laid in to see if I can make the new tank fit
Post by kevsypvs on Jul 26, 2013 14:00:30 GMT 1
more work required methinks copper pipe just there to see if I could improve on line of frame, shes gona be a single seat model so may just cut the back end off what do you think
Post by kevsypvs on Jul 26, 2013 14:02:18 GMT 1
tank is off a fz 400 if your wondering and is like brand new inside
Post by kevsypvs on Jul 26, 2013 16:21:24 GMT 1
yes got a far better solution now
Post by kevsypvs on Jul 26, 2013 17:20:56 GMT 1
one side nearly done more grinding tomorrow
matt7
Post by matt7 on Jul 26, 2013 19:06:43 GMT 1
Post by kevsypvs on Jul 26, 2013 20:12:32 GMT 1
yeh I might try ard for a seat unit at least theirs look good
Post by kevsypvs on Jul 27, 2013 20:39:53 GMT 1
sold off the f2 front forks and wheels and bought this for the backend nice eh
Post by dodgydoughnut on Jul 29, 2013 11:03:08 GMT 1
thats a nice project there. wonder how many tanks are rusty like that without ever leaking
Post by kevsypvs on Jul 29, 2013 20:06:23 GMT 1
yeh mate I know feeding your bike on rusty fluid cant do it much good ,thanks for the comment loads to do as im now gonna cut the whole back end off, after a bit thought its easier to fit a complete alloy subframe than modify existing , one step forward two back but im in no g8 rush to finnish , mock up first then strip down for paint etc
Post by kevsypvs on Jul 30, 2013 20:22:30 GMT 1
just waiting on the r6 rear subframe to arrive , looks like the std subframe mountings will be going in the bin as the r6 is quite a bit wider and spindle is 20mm , oh dear more problems but the grinder with cutting disc should help
Post by kevsypvs on Aug 1, 2013 14:40:30 GMT 1
this turned up today a complete 31k engine , so just waiting for rear subframe and swing arm b4 the cutting can finally get underway, engine pic
Post by kevsypvs on Aug 2, 2013 10:14:00 GMT 1
more problems swing arm is 53 mm too wide , just waiting on nigel getting back to me see if anything can be done
Post by kevsypvs on Aug 2, 2013 16:35:23 GMT 1
cut the back end off , can now start to mock up
Post by turbopresh on Aug 4, 2013 16:11:15 GMT 1
53 mm! thats some cutting.. that being said if it's protruding as much at the opposite side to what shown in the photo as well then you've loads of material to play with there.. get her lined up, hack sawed and reduce the middle spacer appropriately to accomodate the bearings.. you will more than likely need to get the swingarm inside diameter increased by the o/d and width of the bearing either side.. but if you know someone that can do with then you're sorted..
keep her going mate, you're doing well! don't suppose you're in northern ireland per chance.. could do with a project buddy lol
Post by molegripper on Aug 4, 2013 17:21:46 GMT 1
This is going to be interesting R6 rear what will the front end be?
Post by kevsypvs on Aug 4, 2013 17:34:50 GMT 1
53 mm! thats some cutting.. that being said if it's protruding as much at the opposite side to what shown in the photo as well then you've loads of material to play with there.. get her lined up, hack sawed and reduce the middle spacer appropriately to accomodate the bearings.. you will more than likely need to get the swingarm inside diameter increased by the o/d and width of the bearing either side.. but if you know someone that can do with then you're sorted.. keep her going mate, you're doing well! don't suppose you're in northern ireland per chance.. could do with a project buddy lol yeh im keeping going swing arm now cut and fitted temporary , and rear end mocked up , im in Scotland mate lol
Post by turbopresh on Aug 4, 2013 17:36:36 GMT 1
Day trip on the stena! I'll come over with the whip in my arseless chaps to keep you motivated.. You can teach me how to weld while you're at it lol
Post by kevsypvs on Aug 4, 2013 17:36:51 GMT 1
front end not decided yet probable tzr125 though well see what turns up
Post by kevsypvs on Aug 4, 2013 17:38:22 GMT 1
Day trip on the stena! I'll come over with the whip in my arseless chaps to keep you motivated.. You can teach me how to weld while you're at it lol pmsl arseless chaps lol
Post by kevsypvs on Aug 10, 2013 15:36:47 GMT 1
well after some carefull measuring and cutting,swearing ,bashing,calling it all the names under the sun ,more swearing, welding, vowing to never do this again ,my r6 subframe is on and the tank final position is set ,seat is on but needs trimming, reprofiling a bit but itl come right later on
