Yamagamma
Nov 13, 2015 7:39:25 GMT 1
via mobile
Post by unrealedd on Nov 13, 2015 7:39:25 GMT 1
Defiantly an old school sponson/Harris vibe going on there. How's the suspension feel?
Post by gammaguy21 on Nov 13, 2015 16:42:58 GMT 1
It's really come together! Looks very nice.
Post by steeley on Nov 13, 2015 20:04:50 GMT 1
yes looks very good . I like the rgv tank on that frame ,but it looks odd on the sides at the rear.
Post by rostrumorhospital on Nov 13, 2015 22:28:52 GMT 1
Some bikes just look right and this is one of them, hard to put your finger on it, but its definitely got the X-factor!
Super photos detailing the engineering in your build, keep up the good work
matt7
Post by matt7 on Nov 14, 2015 21:32:57 GMT 1
Thanks for comments guys Stubby full stop, it,s about 2" shorter than a stock valve, could handle like a broke shopping trolley ?... Suspension feels good from static check. Not ridden it yet so time will tell, probably a steering damper will get sorted next. I'm happy with it shape wise- understatement - I flippin love it ! , may go black frame with marlborough orange colours, thinking fluro orange wheels Cheers Matt
Post by mikee on Sept 4, 2018 21:35:38 GMT 1
How’s this going now Matt ? Looks brilliant
Mike
matt7
Post by matt7 on Sept 7, 2018 13:18:05 GMT 1
How do Mike, it got a late TZ seat unit & revised back light, then buried in shed due to an enforced house move - just getting workshop up & running now 2 odd years down the line - it'll be on the road at some point in next year - still not painted. Hope your keeping good matey. Cheers Matt
robw
Post by robw on Sept 7, 2018 15:54:58 GMT 1
I have a mk1 fairing, side panels and a belly pan, all need work, if you need any. Also mk1 tank which will need a dent removed. Left over from my Gamma build. Rob
Post by rgbargey on Sept 8, 2018 21:22:39 GMT 1
I might be interested in the tank. Where are you based?
Post by mikee on Sept 9, 2018 13:34:47 GMT 1
How do Mike, it got a late TZ seat unit & revised back light, then buried in shed due to an enforced house move - just getting workshop up & running now 2 odd years down the line - it'll be on the road at some point in next year - still not painted. Hope your keeping good matey. Cheers Matt Hi Matt. Keeping okay at the moment , finally got my yammagamma on the road , beet fettling it since , had to change the front wheel as the other one was badly buckled , which meant making new spacers and fitting different bearings and stuff was supposed to be the same wheel but not the same as it turned out The sidestands been a real faff as the gamma one was too short and styled by stevie wonder , so I adapted a Mito one , that was more faffing about than it should have been , still not happy with it The cylinder head leaked , but being an lc motor it’s a Cnut to get the top end off , you need to unbolt the motor to clear the sleeve nuts , turned out it was the old issue of threads bottoming out , so some washers fitted to the studs and it seems okay at the moment Think I’ll fit the oil tank and pump , getting fed up with pre-mix Also the tank leaks from the oil tank mount holes , took a while to find that one Will get some colour on it over the winter too
